Ray Griffith
Joined: 03 Dec 2008 Posts: 7 Location: Albuquerque, NM
Posted: Tue Apr 24, 2012 1:21 pm Post subject: Poor Man's Battery tester |
I built the poor mans tester Figure 2-4 in AeroElectric Connection. My only modification was I have three bulbs in parallel to simulate the load I have on the battery that I estimate at 11amps to run my fuel pump, ECU, and Ignition. The problem is when I connect the test to the battery and have all three bulbs on the tester kicks off at 13 volts with one bulb it kicks off about 10.5 Volts and with 2 bulbs it kicks off at 12 volts. I have rebuilt the unit with new 10v Zener and I get the same results. Does anyone have any suggestions what I have done wrong is do I need to change the resistor size between the load (bulbs)?
Ray
Posted: Tue Apr 24, 2012 9:11 pm Post subject: Poor Man's Battery tester |
Ray
Ray, I thought I had responded to this query. I think
I was in OKC. In any case, there's something fishy about
the shift in shut down voltages you cited. Irrespective
of how many load bulbs are on the tester, it should drop
out at some voltage below 11 volts. When a battery drops
below 10.5 volts, it's 98% used up.
The description of your experiments don't prompt any
thoughts as to what's happening.
If you'll mail your electronics assembly to me I'd
be pleased to troubleshoot it.
Box 130, Medicine Lodge, KS 67104-0130
Joined: 28 Mar 2008 Posts: 1946 Location: Riley TWP Michigan
Posted: Wed Apr 25, 2012 9:38 am Post subject: Re: Poor Man's Battery tester |
Ray said, | Quote: | | "Does anyone have any suggestions what I have done wrong is do I need to change the resistor size between the load (bulbs)?" |
No resistors go between the bulbs. The electronic circuit and the lamp circuit are connected in parallel and thus are completely separate and independent circuits, sharing only the battery and relay contacts and connecting wires.
Maybe I misinterpreted what you meant by "between the load (bulbs)". In that case, the problem might be the battery. Is it small or old and weak? Are the voltage measurements taken at the instant that the relay opens or later after the battery has had a chance to recover? Perhaps the battery can recover easier from a short term heavy load compared to a long term light load. I suspect that the circuit opens at the same voltage regardless of the load. But the battery will recover to different voltages depending upon the rate of discharge during the test.
Joe
_________________ Joe Gores |
