iflyhawaii2(at)yahoo.com Guest
Posted: Sun May 28, 2006 10:33 pm Post subject: Whining Radio |
I'm chasing down a new noise in the headset on my 60 hour RV-6A with the Z-11 architecture. The whine starts when I turn the radio on and will go off when the alternator switch is turned off (or, of course, if the radio goes off), and is RPM dependent.
The noise is not load dependent, i.e. after the battery is topped off ( I have an ammeter) the whine is still the same intensity. The funny thing is that after an hour flight the noise intensity is much less (maybe only 1/3 the level) than the first 10-20 of flight. Is the alternator is now "warmed up" and producing less noise?
I'm thinking the source is the alternator (#$%&* Van's special) and the victim is the radio, but how and where is the RF leaking and absorbing?
More Info:
B & C linear regular inside the cockpit.
All fat wire seperated from skinny wires.
Recently did some work on the brake hoses and could have bumped a wire.
On day one of this machine I did have a very mild whine on the intecomm that went away with battery top off. (new noise is not affected by intercomm settings.)
Should I be thinking about wire routings, loose connections, grounds first? Then check the power wire from a clean source?
Please help.
Dumfounded in Honolulu.
Greg
lhelming(at)sigecom.net Guest
Posted: Mon May 29, 2006 6:18 am Post subject: Whining Radio |
Like you report, I too developed a whine --and-- within a month my
alternator failed. This all happened shortly after I did my night flights
where I stressed my alternator to 90% of its limit by having all my
electronics on while doing the required take offs and landings. I plan to
install a larger alternator that will have a rating about twice what my
maximum draw need will be. I was able to replace the 30A Vans alt. with the
same type that I purchased at the local AutoZone store. I believe my
original 30A came from a Suzuki of some sort about 1987. For now with
replaced alt. I do not turn all the lights on at one time.
It is in the archives somewhere and I believe Sam Buchanan made a post about
it.
Larry in Indiana
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon May 29, 2006 7:43 am Post subject: Whining Radio |
On May 28, 2006, at 11:23 PM, Greg Grigson wrote:
<iflyhawaii2(at)yahoo.com>
In all probability one or more diodes in your alternator have failed.
This is usually a precursor to total alternator failure. Pull your
alternator and get it checked at an alternator shop.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
Posted: Mon May 29, 2006 8:59 am Post subject: Whining Radio |
Wow. I replaced the first Van's alternator at 10 hours due to amps jumping from + 32 amps to - 32 amps. I would hate to just replace the second alternator. Is there a way to test it on the plane?
Greg
Feel free to call! Free PC-to-PC calls. Low rates on PC-to-Phone. Get Yahoo! Messenger with Voice
brian
Posted: Mon May 29, 2006 10:19 am Post subject: Whining Radio |
On May 29, 2006, at 9:56 AM, Greg Grigson wrote:
Yes. Put it under some kind of load and look at the output with an
oscilloscope. Just connect the o-scope to the main distribution bus
where the alternator B-lead connects. Do you have a 12VDC power jack
for your GPS? That will work too and it is very easy to get to.
An alternator with all three phases working will have almost ripple-
free output. An alternator that has lost a diode will lose the phase
associated with that diode. The result will be greatly increased
ripple in the bus voltage. (That ripple is what you are hearing in
your comm radio.) Some automotive test meters have an "alternator
test" scale that just measures the amount of ripple and gives you a
"good/bad" reading which accomplishes essentially the same thing.
And if you have lost one diode it means that the load is being
carried on only two of the three phases. This means that the
remaining phases are now carrying 50% more load (each) for the same
output from the alternator. That is why I said that losing a diode is
a precursor to losing the whole alternator since most people don't
think to reduce the load on the alternator by 1/3.
I wish I could give you better news. This is why it is probably
cheaper to buy a really good alternator that is "hot rated" to run at
its full rated output. Not having to fix it several times is worth a
fair amount of money.
mprather(at)spro.net Guest
Posted: Mon May 29, 2006 12:34 pm Post subject: Whining Radio |
Hey Brian,
Seems like you could use the AC setting on a DVM to see how much ripple
there is (if you don't have easy access to an Oscope)..
Also, I think diode packs are usually pretty easy to replace. And for
MUCH less money than a completely new alternator will run you.
And finally, does anyone have any temperature data on this kind of
installation? Does this airplane have a blast tube directed at the
alternator. It might be as simple as adding one to the cooling baffle to
keep the temperature in check when you've got it running flat out. If the
alternator IS overloaded, and not dieing from some other cause, keeping it
cooler will be to its benefit. When plumbing a blast tube into the
baffling, it might be worth considering adding it to the side (above one
of the valve covers) instead of at the back. Pulling air from the side
may allow for a bit of 'inertial seperation' which may help keep the
alternator drier when flying through rain..
Matt-
<brian-yak(at)lloyd.com>
brian
Posted: Mon May 29, 2006 6:19 pm Post subject: Whining Radio |
On May 29, 2006, at 1:29 PM, Matt Prather wrote:
<mprather(at)spro.net>
Hey Brian,
ripple
That is possible but it must be an AC-only mode (cap coupled) and not
measuring AC+DC.
You can do that. The alternator shop can do that pretty quickly. Of
course, the question is now why he has had TWO alternator failures.
