Fuel vent modification
carl.froehlich(at)verizon
PostPosted: Sun Apr 29, 2012 1:55 pm    Post subject: Fuel vent modification Reply with quote
Here is a simple way to keep mud-dabbers from clogging your fuel vent.  I think more than one RV has collapsed a fuel tank from a clogged vent.
Take a few inches of 3/8” aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material.  Once the JB Weld is cured, clean up the edge on a ScotchBrite wheel or similar.  Do a ¾” cut in the other end for a hose clamp, then slide this over the now somewhat shortened standard ¼” vent tubing.  Have the ¼” tubing extend well past where the clamp goes.
Carl
RV-8A (800 hours)
RV-10 (FSDO comes to inspect May 23rd)
 Filesize:  83.03 KB
 Viewed:  7530 Time(s)
dlm34077(at)q.com
PostPosted: Sun Apr 29, 2012 2:45 pm    Post subject: Fuel vent modification Reply with quote
A simpler solution; just drill a size 50 hole inside the intersection fairing on the back side of the vent tube. It will also prevent impact ice from sealing a vent.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, April 29, 2012 2:54 PM
To: rv10-list(at)matronics.com; rv8-list(at)matronics.com; rv-list(at)matronics.com
Subject: Fuel vent modification
Carl
RV-8A (800 hours)
dmaib@me.com
PostPosted: Sun Apr 29, 2012 5:21 pm    Post subject: Re: Fuel vent modification Reply with quote
That looks like a great solution, Carl. I have tried to use JB Weld to glue a similar piece of window screen on the existing vent, and it is so small that it is difficult to get the screen to stay in place.
It seems to me that the #50 hole on the back of the tube inside the wing root would work as a way to prevent ice from blocking your vent tube, but couldn't a mud dauber go past the hole and do it's thing? I also think I would prefer not to have a vent inside the fairing because of the potential for fumes or avgas venting inside the fairing.
David Maib
RV-10 #40559
New Smyrna Beach, FL
JohnCiolino(at)carolina.r
PostPosted: Sun Apr 29, 2012 11:46 pm    Post subject: Fuel vent modification Reply with quote
An alternate method: flare the end of the tube, cut a circular patch of flexible fiberglass screening and make radial cuts leaving center ¼” uncut.  The cuts will allow you to wrap the screen around the tube overlapping the cut pieces. Secure the screen with a piece of shrink tubing.
Easy to do, lasts a long time (2 years so far on my -Cool but can be easily replaced if necessary.
John Ciolino
RV-8
N894Y
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Sunday, April 29, 2012 5:54 PM
Carl
RV-8A (800 hours)
PostPosted: Mon Apr 30, 2012 3:00 am    Post subject: Fuel vent modification Reply with quote
Yep, the 1/4" tubing is just too small to do this. I think I will add the small hole for the ice issue.
I've had this vent mod on my 8A for 10 years - works fine.
Carl
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=372110#372110
michael(at)sausen.net
PostPosted: Mon Apr 30, 2012 5:20 am    Post subject: Fuel vent modification Reply with quote
For anyone that lives in an area where these critters are common, I highly recommend you do something to keep them from blocking your vent. I had one block the crankcase vent on my motorcycle years ago and it took me two trips to the dealership to try and figure out why I had oil coming up the clutch cable before one of the guys said check your breather for mud daubers and sure enough, it was plugged tight. Couple of good raps on the tube and a whole lot of dirt later and the problem went away. I’m confident that one of these guys could cause a tank collapse from the vacuum.
Michael
Sent: Sunday, April 29, 2012 4:54 PM
Carl
RV-8A (800 hours)
Kellym
PostPosted: Mon Apr 30, 2012 5:56 am    Post subject: Fuel vent modification Reply with quote
There just might be some pitot tube covers that would do the trick. Old
aircraft from the post WWII era had pitots that were just 1/4" tubing,
like the Cessnas of that era. Reminds me, should check with airport
maintenance...they collect pitot covers by the dozens off the runways.......
Michael
Checked by AVG - www.avg.com
Kelly McMullen
KCHD
Tim Olson
PostPosted: Mon Apr 30, 2012 7:35 am    Post subject: Fuel vent modification Reply with quote
You'd still have to protect the hole from Mud Daubers if you
are in an area where that is something that can happen, but,
there is a way to do a vent in the wing root that shouldn't
cause fume issues:
http://www.myrv10.com/N104CD/upgrades/20090525/index.html
I have a one-way checkvalve in there so that if the vent
ices over, I can't have a vacuum collapse on the tank.
I saw this one from the Lancair builders.
David Maib
RV-10 #40559
Transition Trainer
dlm34077(at)q.com
PostPosted: Mon Apr 30, 2012 8:07 am    Post subject: Fuel vent modification Reply with quote
Another area for blockages is the end of the fuel quick drains; at 1H0 I
left the Glastar overnight and returned the next day to an egg sac inside
the hole where the fuel cup pin is inserted. Gasoline takes a while to clean
it out; usually quicker to change drains and soak the fitting in acetone or
gasoline overnight.
deej(at)deej.net
PostPosted: Mon Apr 30, 2012 12:04 pm    Post subject: Fuel vent modification Reply with quote
Here is another simple and cheap way to keep mud daubers out of your vent:
http://deej.net/glastar/pics/measure/photo7.jpg
I think I paid $0.99 for a pack of 100:
http://www.walmart.com/ip/Kids-Craft-100pk-Fuzzy-Sticks-Neon/19525338
1) Take one fuzzy stick and cut it in half.
2) Take one of the halves and fold in two forming a "V".
3) About 2 inches from the base of the "V", bend each side out 90
degrees. You will end up with a shape like _/\_
4) Stick the end of the "V" into your vent.
5) Add it to your checklist to remove during pre-flight. If you do
happen to forget to remove them, they do allow some air to pass. You
could use the whole fuzzy stick per vent if you wanted to make them
longer and stick out more to be more noticeable for a low wing plane.
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
nukeflyboy
PostPosted: Tue May 01, 2012 10:41 am    Post subject: Re: Fuel vent modification Reply with quote
Here is another suggestion.
I bought a small ball check valve from Grainger. It has a 1/4 NPT fitting and is small, about the size of an AN fitting. I used a Tee to splice it into the vent line inside of the gap. It acts as a vacuum breaker in the event that the vent is blocked for any reason. It also keeps the small positive pressure on the fuel tank.
I can send details later if anyone is interested.
Dave Moore
RV-6 built and sold
RV-10 built and flying
