Landing gear shimmy
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
Bill Strahan
PostPosted: Mon Apr 30, 2012 9:36 pm    Post subject: Landing gear shimmy Reply with quote
Hey, I've talked about this before, haven't I? I've had 3 big changes I wanted to make for a long time: 1) Fix fuel distribution issue. 2) Make some short wingtips. 3) Eliminate the landing gear shimmy.
I installed the flow straightener tube and vanes that Nick sent me about a year ago. That did an amazing job. Perfect? No. Good enough that I'm not considering installing fuel injection? Yep. So #1 is adressed.
I still need to make short wingtips, but my passenger yesterday asked "Why does it shake like that after you land?" GRRRRR.
So I bought an axe handle and started chatting with neighbors here on the airport about cutting and shaping it. I figured I'd buy a 1.125" ball cutter and put a radius in it. Kept putting that off because it didn't sound like fun.
Then it hit me: I really just need it stiffer in fore/aft flexing. And whatever stiffener I make needs to glue to the gear leg so it needs to be a very good fit. Nothing fits better than fiberglass built in-place!
I decided I would tape off the gear and lay up 3 laminations of 7oz cloth directly onto the back of the gear leg. I did that tonight, and it's curing. Tomorrow I'll sand the back of that and use some flock and 5 minute epoxy to attach a 1/8" thick piece of balsa wood that extends about 1.5" behind the gear. Once that's cured I'll lay up about 6 layers of cloth on both sides of the balsa, overlapping onto the section that's on the gear. So the gear shouldn't end up much stiffer since it only has 1/8" thickness between the 6 layer lamination, but it should be SUPER stiff across the 1.5" section.
So I should get that done tomorrow, and let it cure overnight. Then I'll pop it off the gear, trim it, and glue it onto the landing gear leg.
Any thoughts? Nick, any suggestions on the best adhesive to attach to the gear? Should I remove the paint or glue to the paint?
When I glue it I'll put a couple of zip ties around it to hold it while it cures, and leave them on just in case it ever comes loose.
Fingers crossed, I can report in a few days that I have eliminated the dang shimmy once and for all.
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
dwwilt
PostPosted: Tue May 01, 2012 4:30 am    Post subject: Landing gear shimmy Reply with quote
It would be nice to see some pictures of the stiffener as you built it and as you complete the installation.
Dennis
N616DW (Arion Lightning S/N 132)
Dennis
Clive J
PostPosted: Tue May 01, 2012 5:25 am    Post subject: Landing gear shimmy Reply with quote
Hi Dennis, I don’t think you could stick anything to a gear leg that wouldn’t come off when the leg flexed. Where wood has been fitted before wasn’t it held on with hose clips?
To hold the wood in place without hose clips I would have thought you would need to ‘bandage’ it on with fibreglass tape. As you say, good fit and glued but held all along so it has to flex with the leg.
For sticking things to aluminium there is a primer chemical, nasty stuff, I don’t know what it’s called, some kind of chromate maybe, needs painting on and curing with heat.
Interestingly I have Lighting gear legs on my Esqual but no shimmy, even with the great big RV spats (which I took off, anyone want to buy them?). Different wheels and brake discs though.
Just about to fit 6 ply tyres so maybe that will change Sad
Good luck, regards, Clive
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Dennis W. Wilt
Sent: 01 May 2012 13:29
To: lightning-list(at)matronics.com
Subject: Re: Landing gear shimmy
Dennis
dwwilt
PostPosted: Tue May 01, 2012 5:45 am    Post subject: Landing gear shimmy Reply with quote
Clive,
I don't think I am really interested in putting this modification on my Lightning, but the concept was interesting and I would like to see how it is done. I have the LSA gear on my Lightning and do not have a shimmy.
Have a wonderful day,
Dennis
Dennis
checkpoint2(at)comcast.ne
PostPosted: Tue May 01, 2012 6:15 am    Post subject: Landing gear shimmy Reply with quote
Hi Dennis, I missed your message re. gear shimmy. When does it occur, can you isolate it as far as main or nose
wheel? Bob Haas S/N 00071 N330BH.
Sent: Tuesday, May 01, 2012 9:45 AM
To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Clive,
Dennis
-----Original Message-----
To: lightning-list <lightning-list(at)matronics.com>
Sent: Tue, May 1, 2012 9:25 am
Subject: RE: Landing gear shimmy
#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b td{color: black;} (at)font-face {font-family:calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} (at)font-face {font-family:tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} (at)font-face {font-family:consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msonormal,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msonormal,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msonormal {margin:0cm; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b h1 {mso-style-priority:9; mso-style-link:"Heading 1 Char"; margin-top:24.0pt; margin-right:0cm; margin-bottom:0cm; margin-left:0cm; margin-bottom:.0001pt; page-break-after:avoid; font-size:14.0pt; font-family:"Times New Roman","serif"; color:#365f91;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b h2 {mso-style-priority:9; mso-style-link:"Heading 2 Char"; margin-top:10.0pt; margin-right:0cm; margin-bottom:0cm; margin-left:0cm; margin-bottom:.0001pt; page-break-after:avoid; font-size:13.0pt; font-family:"Times New Roman","serif"; color:#4f81bd;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msotitle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msotitle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msotitle {mso-style-priority:10; mso-style-link:"Title Char"; margin-top:0cm; margin-right:0cm; margin-bottom:15.0pt; margin-left:0cm; mso-add-space:auto; border:none; padding:0cm; font-size:26.0pt; font-family:"Times New Roman","serif"; color:#17365d; letter-spacing:.25pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msotitlecxspfirst,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msotitlecxspfirst,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msotitlecxspfirst {mso-style-priority:10; mso-style-link:"Title Char"; mso-style-type:export-only; margin:0cm; margin-bottom:.0001pt; mso-add-space:auto; border:none; padding:0cm; font-size:26.0pt; font-family:"Times New Roman","serif"; color:#17365d; letter-spacing:.25pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msotitlecxspmiddle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msotitlecxspmiddle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msotitlecxspmiddle {mso-style-priority:10; mso-style-link:"Title Char"; mso-style-type:export-only; margin:0cm; margin-bottom:.0001pt; mso-add-space:auto; border:none; padding:0cm; font-size:26.0pt; font-family:"Times New Roman","serif"; color:#17365d; letter-spacing:.25pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msotitlecxsplast,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msotitlecxsplast,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msotitlecxsplast {mso-style-priority:10; mso-style-link:"Title Char"; mso-style-type:export-only; margin-top:0cm; margin-right:0cm; margin-bottom:15.0pt; margin-left:0cm; mso-add-space:auto; border:none; padding:0cm; font-size:26.0pt; font-family:"Times New Roman","serif"; color:#17365d; letter-spacing:.25pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msosubtitle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msosubtitle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msosubtitle {mso-style-priority:11; mso-style-link:"Subtitle Char"; margin:0cm; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif"; color:#4f81bd; letter-spacing:.75pt; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b a:link,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msohyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b a:visited,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msohyperlinkfollowed {mso-style-priority:99; color:purple; text-decoration:underline;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b em {mso-style-priority:20; font-family:"Arial","sans-serif"; font-weight:normal;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b pre {mso-style-priority:99; mso-style-link:"HTML Preformatted Char"; margin:0cm; margin-bottom:.0001pt; font-size:10.0pt; font-family:"Courier New";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b tt {mso-style-priority:99; font-family:"Courier New";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msoacetate,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msoacetate,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msoacetate {mso-style-priority:99; mso-style-link:"Balloon Text Char"; margin:0cm; margin-bottom:.0001pt; font-size:8.0pt; font-family:"Tahoma","sans-serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msonospacing,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msonospacing,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msonospacing {mso-style-priority:1; margin:0cm; margin-bottom:.0001pt; font-size:11.0pt; font-family:"Arial","sans-serif"; mso-fareast-language:en-us;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msolistparagraph,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msolistparagraph,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msolistparagraph {mso-style-priority:34; margin-top:0cm; margin-right:0cm; margin-bottom:0cm; margin-left:36.0pt; margin-bottom:.0001pt; mso-add-space:auto; font-size:12.0pt; font-family:"Times New Roman","serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msolistparagraphcxspfirst,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msolistparagraphcxspfirst,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msolistparagraphcxspfirst {mso-style-priority:34; mso-style-type:export-only; margin-top:0cm; margin-right:0cm; margin-bottom:0cm; margin-left:36.0pt; margin-bottom:.0001pt; mso-add-space:auto; font-size:12.0pt; font-family:"Times New Roman","serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msolistparagraphcxspmiddle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msolistparagraphcxspmiddle,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msolistparagraphcxspmiddle {mso-style-priority:34; mso-style-type:export-only; margin-top:0cm; margin-right:0cm; margin-bottom:0cm; margin-left:36.0pt; margin-bottom:.0001pt; mso-add-space:auto; font-size:12.0pt; font-family:"Times New Roman","serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msolistparagraphcxsplast,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msolistparagraphcxsplast,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msolistparagraphcxsplast {mso-style-priority:34; mso-style-type:export-only; margin-top:0cm; margin-right:0cm; margin-bottom:0cm; margin-left:36.0pt; margin-bottom:.0001pt; mso-add-space:auto; font-size:12.0pt; font-family:"Times New Roman","serif";} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msoquote,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msoquote,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msoquote {mso-style-priority:29; mso-style-link:"Quote Char"; margin:0cm; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif"; color:black; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b p.msointensequote,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b li.msointensequote,#aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.msointensequote {mso-style-priority:30; mso-style-link:"Intense Quote Char"; margin-top:10.0pt; margin-right:46.8pt; margin-bottom:14.0pt; margin-left:46.8pt; border:none; padding:0cm; font-size:12.0pt; font-family:"Times New Roman","serif"; color:#4f81bd; font-weight:bold; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msosubtleemphasis {mso-style-priority:19; font-family:"Arial","sans-serif"; color:gray; font-weight:normal; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msointenseemphasis {mso-style-priority:21; font-family:"Arial","sans-serif"; color:#4f81bd; font-weight:bold; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msosubtlereference {mso-style-priority:31; font-family:"Arial","sans-serif"; font-variant:small-caps; color:#403152; text-transform:none; text-decoration:underline;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msointensereference {mso-style-priority:32; font-family:"Arial","sans-serif"; font-variant:small-caps; color:#5f497a; text-transform:none; letter-spacing:.25pt; font-weight:bold; font-style:normal; text-decoration:underline;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.msobooktitle {mso-style-priority:33; font-family:"Arial","sans-serif"; font-variant:small-caps; text-transform:none; letter-spacing:.25pt; font-weight:bold; font-style:normal;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.heading1char {mso-style-name:"Heading 1 Char"; mso-style-priority:9; mso-style-link:"Heading 1"; font-family:"Arial","sans-serif"; color:#365f91; font-weight:bold;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.heading2char {mso-style-name:"Heading 2 Char"; mso-style-priority:9; mso-style-link:"Heading 2"; font-family:"Arial","sans-serif"; color:#4f81bd; font-weight:bold;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.titlechar {mso-style-name:"Title Char"; mso-style-priority:10; mso-style-link:title; font-family:"Arial","sans-serif"; color:#17365d; letter-spacing:.25pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.subtitlechar {mso-style-name:"Subtitle Char"; mso-style-priority:11; mso-style-link:subtitle; font-family:"Arial","sans-serif"; color:#4f81bd; letter-spacing:.75pt; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.quotechar {mso-style-name:"Quote Char"; mso-style-priority:29; mso-style-link:quote; font-family:"Arial","sans-serif"; color:black; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.intensequotechar {mso-style-name:"Intense Quote Char"; mso-style-priority:30; mso-style-link:"Intense Quote"; font-family:"Arial","sans-serif"; color:#4f81bd; font-weight:bold; font-style:italic;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.htmlpreformattedchar {mso-style-name:"HTML Preformatted Char"; mso-style-priority:99; mso-style-link:"HTML Preformatted"; font-family:consolas; mso-fareast-language:en-gb;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.balloontextchar {mso-style-name:"Balloon Text Char"; mso-style-priority:99; mso-style-link:"Balloon Text"; font-family:"Tahoma","sans-serif"; mso-fareast-language:en-gb;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b span.emailstyle41 {mso-style-type:personal-reply; font-family:"Calibri","sans-serif"; color:#1f497d;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b .msochpdefault {mso-style-type:export-only; font-family:"Calibri","sans-serif"; mso-fareast-language:en-us;} (at)page wordsection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt;} #aolmsgpart_1_2baaa63f-3981-47b7-8ff3-456e8202641b div.wordsection1 {page:wordsection1;} Hi Dennis, I don’t think you could stick anything to a gear leg that wouldn’t come off when the leg flexed. Where wood has been fitted before wasn’t it held on with hose clips?
From: owner-lightning-list-server(at)matronics.com (owner-lightning-list-server(at)matronics.com) [mailto:owner-lightning-list-server(at)matronics.com? ([email]owner-lightning-list-server(at)matronics.com?[/email])] On Behalf Of Dennis W. Wilt
Dennis
dwwilt
PostPosted: Tue May 01, 2012 6:18 am    Post subject: Landing gear shimmy Reply with quote
Bob,
I have not had a problem with gear shimmy, yet.
Dennis
Dennis
wb2ssj(at)rochester.rr.co
PostPosted: Tue May 01, 2012 6:31 am    Post subject: Landing gear shimmy Reply with quote
Interesting subject:
I have reduced the amount of shimmy with better tires, but have not cured it entirely. Maybe Nick can elaborate on the reasons for the new gear on the Lsa, as it might give us with the older gear some ideas on things to try.
Tex,
n45bm(at)yahoo.com
PostPosted: Tue May 01, 2012 6:53 am    Post subject: Landing gear shimmy Reply with quote
The way I would do it would be to clean thoroughly the bare aluminum gear leg, then wrap two layers of 3" wide glass cloth on the gear, in a spiral manner. After cured, sand the rear of the glass and flox/epoxy a shaped pine wood (or similar wood) shape to the rear. I would then wrap the gear and fairing with another three layers of glass cloth. You could then attach the factory fairings over that or finish the glass cloth. Heck, even better would be to do it to all three gear legs. (Or maybe you may not have any shimmy problems at all with the standard setup).
Bernardo
--- On Tue, 5/1/12, Bill Strahan <bill(at)gdsx.com> wrote:
Subject: Landing gear shimmy
Date: Tuesday, May 1, 2012, 12:36 AM
--> Lightning-List message posted by: "Bill Strahan" <[url=/mc/compose?to=bill(at)gdsx.com]bill(at)gdsx.com[/url]>
http://forums.matronics.com/viewtopic.php?p=372188#372========================http://www.matronics.cs.matronics.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution [quote][b]
Bill Strahan
PostPosted: Tue May 01, 2012 11:49 am    Post subject: Re: Landing gear shimmy Reply with quote
Here are a few pictures.
Attachment5, the 3 layers on the landing gear (covered in tape) before I pried it off this morning.
Attachment8, the half-tube of fiberglass once it was pried off.
Attachment7, I went with 1/16" X 1" bass instead of 1/8" balsa, attached with 5 minute.
Attachment6, a shot down the length of the tube. Once I've laid up several layers on both sides and trimmed it, it should flex okay in one direction, and be super stiff going against the 1" length of bass/fiberglass.
Bill Strahan
PostPosted: Tue May 01, 2012 5:08 pm    Post subject: Re: Landing gear shimmy Reply with quote
Okay, the stiffeners are built. I'm waiting on an adhesive test I did to choose which adhesive I use to bond them to the back of the gear legs.
FWIW, they're stiff. I can barely flex them in the direction the landing gear SHOULD flex, and they won't budge in the other axis. Makes sense. Hopefully they're not TOO stiff. Somewhere in there is a joke about being 18 again, but I'll skip it. Smile
Here are two pictures.
stephenbehn(at)bigpond.co
PostPosted: Tue May 01, 2012 11:44 pm    Post subject: Landing gear shimmy Reply with quote
This is just a thought, run thin rigging wire secured at the axle weldment
square plate up through the bottom of the fuselage on the line of the gear
leg and so that they would lie inside the fairings. Inside the fuslage they
could be tensioned against the floor or spar box using compression springs
This would stiffen up the entire system not only the leg and you could apply
the minium force required to aliviate the shimmy. Rigging wire would have to
have fastenings crimped on all available at any good marine chandlery
regards
Steve Behn
Lightning 69
still a long way to go.
Bill Strahan
PostPosted: Mon May 07, 2012 5:09 pm    Post subject: Re: Landing gear shimmy Reply with quote
Well, some possible egg on my face. Smile First, I finished my stiffeners and instead of adhesive, clamped them to the legs with 3 hose clamps.
I grabbed the gear leg prior, and yanked it back and forth on the ground. Then clamped the stiffener on and did it again. It made an incredible difference. I'll try to get some pictures up tomorrow.
I was excited to try them out with a high speed taxi, so I jumped in fired up. From my hanger to the main taxiway at F69 is grass, and in that short section I could immediately tell a difference. The plane just felt much more stable on the grass without some of the wiggling, and back and forth springing of the gear that occurs when you're slow taxiing over clumps of grass. Encouraging.
Did my high speed run and as I slowed to 20 or so, there was the same old shimmy. Risking being told that the word doesn't mean, what I think it means...inconceivable!
A bit dejected, I taxied back and pulled in the hanger. Again I noted a much better feel on the grass taxiway. My wife came out from the house and asked if they worked, and as I was explaining what happened, I realized it was very unlikely that the stiffeners would make NO difference at all! Hmmm. I had heard the nose gear was pretty immune to shimmy, but maybe...
First I lifted the nose up and the noticed the nose wheel was free to flop back and forth. Certainly no damping action there. And upon closer inspection I could see dents in the aluminum at the edges of the slot that provides the limits to rotation via the bolt and spacers. I don't slam the thing around, yet the dents in the aluminum were substantial where the washers on the bolt were digging into the aluminum at both extremes of rotation. I could easily envision multiple stop to stop impacts creating the dents in the aluminum.
So perhaps I have the best grass-taxiing Lightning in existence, but that wasn't really my goal. I'm going to rig up a video camera and do what I should have done in the first place, video the gear and find out exactly what is causing the shimmy. Then I'll fix it.
If it's not the main gear I may leave the stiffeners on anyway. Total weight of stiffeners and clamps is 9 oz. I'll fly it up to a grass strip I frequent and decide after I have the shimmy gone.
Bill Strahan
PostPosted: Mon May 07, 2012 5:15 pm    Post subject: Re: Landing gear shimmy Reply with quote
Here are the pics: One pic of the stiffeners, and a strip of rubber that I decided to clamp between the stiffener and gear leg.
Next is a pic of the stiffener clamped in place
Bill Strahan
PostPosted: Tue May 08, 2012 1:36 pm    Post subject: Re: Landing gear shimmy Reply with quote
Okay, no egg on my face I suppose. Finally got a video camera to check things out. It's clearly the main gear.
It should be on youtube here: http://youtu.be/rzb_eeyhLJU in a few minutes.
This clip makes it pretty visible starting at 0:28 on the landing roll. I don't use the brakes much to try to discount that influence, and I let the nose drop the moment I land so I can see if it's the nose or mains.
On taxiing back, I decided to accelerate and test it again, and the second shimmy can be seen at 1:28.
It may not look like much on a video camera, but that's a serious bit of wiggling in the cockpit.
I'm astounded that the stiffeners don't make an impact on it. I can't flex them by hand at all in that direction.
This is a big deal for me because I fly into some pretty busy places and it occurs right at the speed I'd be doing on a long runway to hurry up and make a turnoff. That, and I don't like passengers looking a little freaked out and asking what the heck that was. And it can't be good for the whole plane to violently shake like that.
For the record, I've balanced tires, changed to 6 ply tires, balanced those, and now the fiberglass stiffeners. No relief yet. Not sure what comes next.
wampam
PostPosted: Tue May 08, 2012 2:18 pm    Post subject: Landing gear shimmy Reply with quote
Bill,
I have been plagued with similar problems. I tried most of what you have done, except for stiffeners, with little or no effect. I did notice an improvement when I remove the landing gear fairings. I did a lot of research on the subject at one time. There are number of papers on the subject on the NASA web site. These papers go back to the 1940's up to the 80's and 90's. There are just to many variables for a simple fix. Things like tire pressure, runway surface material, the kind of rubber used on the tire, flexing of the airframe, shape of the gear, weight on the tire, toe in and toe out and the list keeps going on. Even modern transports have problems at times and I been on some where the shimmy was very noticeable.
A FULL-SCALE INVESTIGATION OF THE EFFECT OF
SEVERAL FACTORS On THE SHIMMY OF CASTING WHEELS
April 1940, Langley Aeronautical Laboratory.
TECHNICAL NOTE 3632
CORRELATION, EVALUATION, AND EXTENSION OF LINEARIZED
THEORIES FOR TIRE MOTION AND WHEEL SHIMMY
Langley Aeronautical Laboratory, Langley Field, Va.
Washington
June 1956
TECHNICAL NOTE 4001
SOME CONSIDERATIONS OF HYSTERESIS EFFECTS
ON TIRE MOTION AND WHEEL SHIMMY
Washington
June 1957
REPORT No. 686
STABILITY OF CASTERING WHEELS FOR AIRCRAFT LANDING GEARS
REPORT 1299
CORRELATION, EVALUATION, AND EXTENSION OF LINEARIZED THEORIES FOR TIRE
NATIONAL ADVISORY COMMITTEE FOR AERONAUTICS
TECHNICAL MEMORANDUM 1378
DETERMINATION QF THE ELASTICC CONSTANTS
OF AIRPLANE TIRES
Washington
November 1954
TECHNICAL MEMORANDUM 1337
Analytical Study of Shimmy of Airplane Wheels
Washington
September 1952
NASA/TM- 1999-209143
ARL-TR- 1976
An Overview of Landing Gear Dynamics
Langley Research Center, Hampton, Virginia
May 1999
Shimmy of Aircraft
Main Landing Gears
September 2000
ISBN 90-9014104-9
Copyright 2000 by I.J.M. Besselink
mark(at)flylightning.net
PostPosted: Tue May 08, 2012 2:32 pm    Post subject: Landing gear shimmy Reply with quote
Hi Bill,
I'm sure you've already looked at this but what is your tire pressure?
We've also just experienced a case where the gear shimmied with no pants on
and then the shimmy was almost next to nothing with the wheel pants back on.
Go figure.
Also, I don't remember what setting we used when we set the toe in for your
gear. Double check that as well.
Best regards,
Mark
JamesL(at)Lugoj.com
PostPosted: Tue May 08, 2012 2:46 pm    Post subject: Landing gear shimmy Reply with quote
Looks like a bit of resonance kicking in. Not sure, but it looks like maybe each
leg alternates in vibration; that is as one vibrates forward the other is going
backward.
I'm not a mechanical engineer and don't play one on TV, but my uninformed guess
is that when one of the legs flexes, the leg geometry may be such that it can't
help but cause the wheel to change its toe-in or toe-out angle. In this case as
one of the legs starts to bend it may be causing a toe-out condition in the
wheel, which causes even more bending and more toe-out. This would likely cause
the plane to pull to one side, causing the other wheel to experience a relative
toe-out condition, setting up the same thing there. Energy starts swapping sides.
Swept-back gear legs _might_ have an inherent geometry problem due to how they
rotate the axis of the wheels when they flex due to loads. So the toe-angle
would also change with changes in how much you load the airplane.
Perhaps gear legs straight out (right angle to the average direction of motion)
would flex mostly only up or down, changing the camber angle of the wheels but
not the toe-angle.
But as I said, I am not an engineer and the above might not be valid observations.
PostPosted: Tue May 08, 2012 4:09 pm    Post subject: Landing gear shimmy Reply with quote
Bill, great video, thank you for your effort. Tex
vettin74(at)yahoo.com
PostPosted: Tue May 08, 2012 4:29 pm    Post subject: Landing gear shimmy Reply with quote
What about a different materal for the leg all together?
We dont have the problem on the lsa gear that often if at all. But the overlay angle or sweep of the gear is not as pronounced.
Have thought about the use of titanium gear legs. That material is said to be "dead" material due to make up. It does flex but does not spring back with as much pep. Sonex uses this for their main legs, it is a bit more expensive but may be a solution. Let me look into it.
Nick
Sent from my pocket
On May 8, 2012, at 7:06 PM, "Tex Mantell" <wb2ssj(at)rochester.rr.com> wrote:
barnett6088(at)msn.com
PostPosted: Tue May 08, 2012 7:19 pm    Post subject: Landing gear shimmy Reply with quote
Bill
There is a natural resonance in my landing gear around 8 to 10 miles per hour.  If you are slower or faster there is no vibration but when you hit that speed the wheels bounce pretty good.  By adding or subtracting weight (Wheel pants etc.) you just change the resonant frequency.  With a resonance problem in your landing gear the wheels can be perfectly balanced but the slightest excitement from a bump in the runway or an out of balance tire, at the right speed, will get it going
Try this, jack a wheel off the ground and using an air gun with a lot of pressure, in the area of the tread spin the wheel up to see if you have a balance problem or out of round tire.  Make sure you warm up the tire first by a few landings and then before it cools off jack it up and let it sit for an hour to stabilize (reach it's natural shape).  Then test it.  You may need to put a padded support under the area of the fuselage so the gear can flex freely during the test.  If the tires are allowed to cool after a flight while the plane is sitting on them they will develope a flat spot that will lead to wheel bounce no matter what you do.
 Gary Barnett N335AL Sn 133.
Date: Tue, 8 May 2012 14:36:50 -0700
--> Lightning-List message posted by: "Bill Strahan" <bill(at)gdsx.com>
http://forums.matronics.com/viewtopic.php?p=372654#372654
Archive Search & Download, 7-Day Browse, Chat, FAQ,
&gt========================
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
Page 1 of 3
You cannot download files in this forum
