		Dan Wilde
				 Posted: Sun Apr 29, 2012 6:18 pm    Post subject: Evans Coolant |
				I am doing my 200 hour Rotax checklist and find that they recommend
 draining the Evans coolant, flushing with the magic fluid and then
 reinstall new Evans.  My question is why?  The Evans container says it
 is good for the lifetime of the vehicle.
 I don't mind doing this but there should be a good reason.
 Dan Wilde
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		tomrv4(at)me.com Guest
				 Posted: Sun Apr 29, 2012 7:04 pm    Post subject: Evans Coolant |
				As an aside to this question...I have a (never been opened) gallon of Evans NPG+ coolant I bought from AC Spruce that I won't be using. Will part with it for less than half price...$15.00 plus shipping...
 Tom
 Rans S-7S
 On Apr 29, 2012, at 9:17 PM, Dan Wilde <stolpilot.wilde(at)gmail.com> wrote:
  I am doing my 200 hour Rotax checklist and find that they recommend draining the Evans coolant, flushing with the magic fluid and then reinstall new Evans.  My question is why?  The Evans container says it is good for the lifetime of the vehicle.
  Dan Wilde
		rampil
				 Posted: Wed May 02, 2012 6:10 am    Post subject: Re: Evans Coolant |
				The chemicals in the Evans may not decompose, but the fluid does pick
 up dirt and swarf over the years and should be drained every few years to
 prevent clogs.
 PS Are you SURE you want to be using that nasty stuff instead of DexCool?
		BARRY CHECK 6
				 Posted: Wed May 02, 2012 7:40 am    Post subject: Evans Coolant |
				That does not sound like a bad deal.  If it does pick up dirt - you are making the engine cleaner.  Where would the swarf come from?  Doesn't the manufacture clean their product before shipping?  And even if it does pick up these items - That is a good thing.. You could always filter the them out.
 Barry
 On Wed, May 2, 2012 at 10:10 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
 [quote] --> RotaxEngines-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
  prevent clogs.
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=372270#372270
  -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
  le, List Admin.
		ronlee
				 Posted: Wed May 02, 2012 11:31 am    Post subject: Re: Evans Coolant |
				I vote to leave it in as the Evans manufacture recommends. It has been in my Rotax for about the same amount of time as yours and it is clear as can be. I live in the AZ desert and it cools my engine just fine. I have never overheated or had to add a drop yet. If you read about the hot spots (steam pockets around the combustion area) it can prevent in a Rotax I don't understand why anyone would want to use anything else, especially since Rotax recommends its use. If it can keep the old Ford flat head engines cool and keep the block from cracking between the valves it has to be good.
 The only drawback I can think of is if it does get low on coolant to maintain its integrity Evens has to be added. I carry a pint with me.
 Remember, Ron Lee and Roger Lee are two different persons. Roger is the certified expert on Rotax engines.
  _________________ Ron Lee
Tucson, Arizona |
		bob(at)fly-ul.com Guest
				 Posted: Wed May 02, 2012 11:57 am    Post subject: Evans Coolant |
				On 12:31 PM 5/2/2012, ronlee wrote:
 If one does the good ol' Rotax 5 year replacement of all rubber parts, seems to me it wouild still be best to just replace the coolant at the same time (instead of draining it into some container, where its likely to get contaminated anyway)
 Bob Comperini
 e-mail: bob(at)fly-ul.com
 WWW: http://www.fly-ul.com
		rampil
				 Posted: Sun May 06, 2012 11:18 am    Post subject: Re: Evans Coolant |
				The debris in the coolant comes from a variety of sources including vibrational fretting of the hoses, heat and ozone induced decomposition
 of the hoses, vibrational gasket wear, wear in the water pump and other
 moving parts, oxidation of the aluminum radiator, etc.
 By definition, if the hoses change at 5 years, so does your coolant.
		Dan Wilde
				 Posted: Sun May 06, 2012 12:57 pm    Post subject: Evans Coolant |
				On 5/6/2012 12:18 PM, rampil wrote:
 I guess I will change it next year when I get to 5 years in service.
 If you have used Evans from the start, do you need to flush the system
 with Evans flush after replacing hoses or can you just refill with new
 Evans?
 Dan Wilde
		klinefelter.kevin(at)gmai Guest
				 Posted: Sun May 06, 2012 4:29 pm    Post subject: Evans Coolant |
				You can just replace the Evans.
 Kevin
 On May 6, 2012, at 1:56 PM, Dan Wilde <stolpilot.wilde(at)gmail.com> wrote:
  I guess I will change it next year when I get to 5 years in service.   If you have used Evans from the start, do you need to flush the system with Evans flush after replacing hoses or can you just refill with new Evans?
  Dan Wilde
