1planeguy(at)kilocharlie. Guest
Posted: Thu May 24, 2012 1:14 pm Post subject: Cheap covering job |
Well I have a semi off topic post. Can't think of anywhere where I am more likely to get an intelligent answer than here so hang on...
I have had an odd job thrown in my lap. I have a CNC router table and got ask to make a fairly large scale Gee Bee R1 racer display model. Hanging from the ceiling will be as close to "airworthy" as it will ever need to be...so certified procedure and design went out the window. I am about done cutting the pieces out and will start assembly tonight, but I am going to have to cover this rascal. I don't want to waste "Poly-stuff" on a display plane so thought I would use dacron (sold by Aircraft Spruce for "peel-ply", because it is cheap and heat shrinkable) and I plan to just do latex house paint for color. What would work good for a glue to attach this to wood?
KiloCharlie KiloCharlie 5 10 2011-09-01T15:23:00Z 2011-09-01T15:31:00Z 1 18 103 1 1 120 12.00 <![endif]--> 89 Clean Clean false false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} <![endif]--> <![endif]--> <![endif]-->
Jeremy Casey
KiloCharlie Detailing, Inc.
Jeremy(at)kilocharlie.us (Jeremy(at)kilocharlie.us)
Mike Welch
Posted: Thu May 24, 2012 1:33 pm Post subject: Cheap covering job |
Jeremy,
I think the lightest-weight non-certified polyester fabric that Aircraft Spruce sells might be
a better choice the the peel-ply. The peel-ply has sort of a coating on it, which is why it peels
off fiberglass resin so well. IIRC, ACS has 1.7 oz stuff that would work fine, or maybe the 2.7 oz.
Since we are talking display model ONLY, I think if it were me, I'd try a hot glue gun and an iron.
If the heat of the hot glue makes it difficult to work with, then the next stuff I'd try is that yellow
Carpenter's Glue that they sell at all the lumber stores. It dries pretty quickly.
Lastly, the fact is, the Poly Tac cement would probably work very well, too. So would the clear
PVC glue, which is obviously a very close chemical formula to the Poly Tac. Since a small can
is only $3, give the PVC glue a try.
Mike Welch
On May 24, 2012, at 4:13 PM, 1planeguy wrote:
[quote] Well I have a semi off topic post. Can't think of anywhere where I am more likely to get an intelligent answer than here so hang on...
Jeremy Casey
russk50(at)gmail.com Guest
You should be talking to the model makers -- they'll likely have answers.
Jeremy Casey
rickofudall
Posted: Thu May 24, 2012 2:25 pm Post subject: Cheap covering job |
Mike, Sorry buddy but you're full of BS about peel ply. Here's the Spruce part number for DACRON FULL WIDTH PEEL PLY 1.8 OZ #611 listed under Composites / fabric, p/n 09-00100 and the part number for 1.8 oz. polyester fabric under Covering Materials / fabric p/n 09-00100. Same stuff, no magic coatings, epoxy just doesn't stick to polyester.
Rick Girard
On Thu, May 24, 2012 at 4:33 PM, kinne russ <russk50(at)gmail.com (russk50(at)gmail.com)> wrote:
| Quote: | You should be talking to the model makers -- they'll likely have answers.
| Quote: | Well I have a semi off topic post. Can't think of anywhere where I am more likely to get an intelligent answer than here so hang on...
Jeremy Casey
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Dana
Posted: Thu May 24, 2012 4:04 pm Post subject: Cheap covering job |
Just dope it on with butyrate dope from the local R/C hobby shop. Use dope for the finish, too... better finish than latex and much cheaper than poly stuff.
-Dana
"Alcohol, Tobacco and Firearms" should be a convenience store, not a government agency.
WhiskeyVictor36(at)aol.co Guest
Posted: Fri May 25, 2012 6:46 pm Post subject: Cheap covering job |
Jeremy,
I know a fella that uses regular hardware store 'Contact Cement' to glue the fabric on his homebuilt. Works well for him. I used Poly Tak on my Kolb.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 5/24/2012 5:14:34 P.M. Eastern Daylight Time, 1planeguy(at)kilocharlie.us writes:
| Quote: | What would work good for a glue to attach this to wood?
