Plugs leading up worse than normal
Goto page 1, 2  Next
Doug Doty
PostPosted: Thu Nov 03, 2011 4:00 pm    Post subject: Plugs leading up worse than normal Reply with quote
Seems like in the last 60 to 90 days everyone at our airport is having plugs lead and or at least load up much much worse than ever before. With having recently bought my tiger I have noticed that it also needs leaned aggressively on the ground to run clean and it's best and during ground operation mag checks. Has anyone else noticed anything similar in their area. We generally feel that we are dealing with a bad load of fuel at our airport. My plane has in the last 50 hours had the carb replaced with a reman unit and runs perfectly otherwise.
Part 2.. Having a fuel flow totalizer for the first time makes me wonder if anyone knows from memory what kind of flow #'s they might generally see at say, taxing rpm, runup, idle and climb out. Would be fun to compare readings here. The turbine seems to me to be accurate to within maybe as good a 1-2 tenths of a gallon on 40 gallon fill ups so it would seem to be relative to compare readings with one another. I am guilty of not knowing my own answers to these same questions but will re-post as soon as the weather breaks and I get into the air again.
I am thinking I saw 16 gallons on climb out right after liftoff but will accurize my numbers asap following my next flight. I do not have my POH at home but does anyone know the full power climb out fuel burn expectation for the 0-360
Idle: .9 to 1 gallon
Taxi:
Run up:
Climb out:16 gallon
1977 AA5B N28454, Fuel Totalizer, Lopresti Nose, Red Rudder Cap, 4 cyl. egt, stock otherwise.
andy747(at)charter.net
PostPosted: Thu Nov 03, 2011 5:19 pm    Post subject: Plugs leading up worse than normal Reply with quote
I can only provide a number for cruise but 16 GPH sounds reasonable for
climbout.....
Time after time on four hour flights to and from my home and Chicago at
7/8/9 T, I saw 132 knots TAS and 9.2 GPH....exactly what the charts
predicted.... maybe one knot more or one tenth GPH on some days but 132/9.2
was set in stone and confirmed on many flights !!!
Andy Thomas
david(at)troup.net
PostPosted: Thu Nov 03, 2011 11:46 pm    Post subject: Plugs leading up worse than normal Reply with quote
Probably somebody else has piped in already, but if you didn't already know this, all Tigers require you to lean significantly -- I mean a lot, a couple of inches is not too much -- on the ground, to avoid lead fouling. There's nothing unusual about that. It's impossible to overlean on the ground, so there's basically no reason not to pull the red knob to just short of killing the engine. I lean -- a lot -- after start and immediately after I land, when I'm turning off landing light, retracting the flaps, etc.
A side benefit of leaning aggressively on the ground is that you'll never be able to accidentally take off that way. Your mixture knob should be far enough out that if you advance the throttle to full, the engine will stumble. That prevents you from forgetting and taking off with the mixture too lean.
Can't speak to whether you have a bad batch of fuel or not, but there is nothing at all unusual about needing to lean on the ground. Every Tiger I have flown will get fouled plugs almost immediately if you don't.
David Troup
Tiger N28797 (SQL)
stockercarolm(at)gmail.co
PostPosted: Fri Nov 04, 2011 2:22 am    Post subject: Plugs leading up worse than normal Reply with quote
Thanks for that note...a big help!
Carol
N28742
On Fri, Nov 4, 2011 at 3:43 AM, David Troup <david(at)troup.net (david(at)troup.net)> wrote:
[quote]--> TeamGrumman-List message posted by: David Troup <david(at)troup.net (david(at)troup.net)>
David Troup
Tiger N28797 (SQL)
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
le, List Admin.
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
http://forums.matronics.com
le, List Admin.
bkspero
PostPosted: Thu May 24, 2012 7:25 am    Post subject: Re: Plugs leading up worse than normal Reply with quote
Doug Doty wrote:
..... I have noticed that it also needs leaned aggressively on the ground to run clean and it's best and during ground operation mag checks...
I am just beginning to play with leaning on the ground. I had been simply leaning about an inch with no attention to the effect on idle speed. I now find that if I lean to peak idle, it takes about 1.5 inches and gains about 300 rpm over idle at full rich.
But during the ground runup mag check I go back to full rich. Is that wrong? Should I be leaning for that as well? I ask because the left mag always runs a little rougher than the right during the mag check. The RPM drop for the left mag is fine (about 80-100 rpm), and equal to the drop for the right mag. But the left mag is noticeably rougher.
If I should be leaning for the mag check, what technique should I use (eg. run it up rich and lean until rough then enrichen slightly?)?
teamgrumman(at)yahoo.com
PostPosted: Thu May 24, 2012 9:35 am    Post subject: Plugs leading up worse than normal Reply with quote
I think the old rule was to do the run up at full rich. I've gone to leaning to near peak RPM at 1800 then doing the mag checks. If you forget to go full rich on takeoff, it will remind you when the engine stumbles.
What plug are you running?
What gap?
Sent: Thursday, May 24, 2012 8:25 AM
Subject: Re: Plugs leading up worse than normal
--> TeamGrumman-List message posted by: "bkspero" <bkspero(at)gmail.com (bkspero(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=373771#373771
http://www.matronics.com/Navigator?TeamG &nbs===================
flyv35b(at)minetfiber.com
PostPosted: Thu May 24, 2012 12:12 pm    Post subject: Plugs leading up worse than normal Reply with quote
First off you can't check the idle mixture unless the engine is fully
warmed up (after flying). Then you should get about a 25 rpm rise from
full rich when you lean slowly at 800-1000 rpm, say.
I always check carb heat at full rich mixture and see about 100 rpm drop
at 1700rpm. I then lean to max rpm and it rises about 50 rpm or
thereabouts. I let it run there for 10 seconds and then do the mag
check with it leaned. I leave it leaned until ready to takeoff and then
shove the mixture in. You won't forget as the engine will stumble upon
throttle application if you forget. I always taxi with it leaned as far
as the engine with still run smoothly. I always lean in the air, even
at low altitude, when the power is reduced for cruise. Plugs run pretty
clean for 100 hrs.
Cliff
bkspero
PostPosted: Thu May 24, 2012 1:10 pm    Post subject: Re: Plugs leading up worse than normal Reply with quote
What gap?
Hi Gary. This is about 74429. Alan had the plugs replaced last September at about 390 hrs on the engine. He had type REM-38E installed. There is no entry for the gap in the logbook. It was at about 406 hrs when I bought it, and it is at about 450 hrs now.
I will try the lean runup and see if it helps.
Barry
bkspero
PostPosted: Thu May 24, 2012 1:19 pm    Post subject: Re: Plugs leading up worse than normal Reply with quote
clean for 100 hrs.
Cliff
Thanks for the input, Cliff. I now taxi lean to peak rpm. And do lean in the air even at low altitude as long as the power is low.
Plane gives the 200+ idle rpm increase whether the engine is cold or its been flying for hours.
Makes sense to do the carb heat check while rich. Will try the lean mag runup. Hoping that's the key.
Thanks again.
Barry
PostPosted: Thu May 24, 2012 1:29 pm    Post subject: Plugs leading up worse than normal Reply with quote
> clean for 100 hrs.
> Cliff
Thanks again.
Barry
http://forums.matronics.com/viewtopic.php?p=373807#373807
Well, your idle mixture adjustment is way to rich if you are getting
200+ rpm rise when you lean, if your checking it with a warm engine.
You might see that much with a cold engine right after start up.
Turn your idle mixture screw in 1/2 turn and recheck it.
Cliff
PostPosted: Thu May 24, 2012 9:24 pm    Post subject: Plugs leading up worse than normal Reply with quote
If I set the plugs, I set them to .018.
Gary
> What gap?
> [b]
Barry
http://forums.matronics.com/viewtopic.php?p=373803#373803
PostPosted: Thu May 24, 2012 9:33 pm    Post subject: Plugs leading up worse than normal Reply with quote
Most people check the rpm incorrectly.
At idle, full rich, engine warm, it should idle about 600-650 rpm. Lower is better since it makes landing easier. My plane idles at 450 rpm.
At idle, very slowly pull the mixture out. Very slowly. The engine rpm should go up roughly 50 rpm at sea level. At 1500 feet, figure about 25-30 rpm.
ANY throttle setting other than throttle closed at idle and the carb will NOT be operating on the idle circuit. Any checking of rpm rise without the throttle closed will give an artificially rich indication since the carb is operating on the transition circuit.
Gary
> clean for 100 hrs.
> Cliff
Thanks again.
Barry
PostPosted: Thu May 24, 2012 9:35 pm    Post subject: Plugs leading up worse than normal Reply with quote
There is a fine dance between the throttle plate setting and the mixture setting.
Look at my web site, front page, technical, and look for setting the engine idle.
Gary
>> clean for 100 hrs.
>> Cliff
> Thanks again.
> Barry
Well, your idle mixture adjustment is way to rich if you are getting 200+ rpm rise when you lean, if your checking it with a warm engine. You might see that much with a cold engine right after start up.
Cliff
bhauskne(at)gmail.com
PostPosted: Thu May 24, 2012 9:43 pm    Post subject: Plugs leading up worse than normal Reply with quote
And yet the standard procedure we are all taught is 1800 Mag check. Sounds like you are giving unsubstantiated advice that is contrary to aircraft and engine operating instructions.
Probably better to stick to the aircraft operating manual. On May 24, 2012 10:36 PM, "Gary L Vogt" <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:[quote] --> TeamGrumman-List message posted by: Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
Gary
On May 24, 2012, at 2:19 PM, "bkspero" <bkspero(at)gmail.com (bkspero(at)gmail.com)> wrote:
>> clean for 100 hrs.
>> Cliff
> Thanks again.
> Barry
le, List Admin.
PostPosted: Thu May 24, 2012 10:04 pm    Post subject: Plugs leading up worse than normal Reply with quote
Brian H,
Maybe you have trouble understanding the written English. We are not talking about mag checks. I was not giving unsubstantiated advice.
I am describing setting the engine idle and idle mixture.
If you are having trouble following the conversation, I suggest you reread the text. If you are still having trouble following the conversation, go have another beer and reread it in the morning.
Gary
On May 24, 2012, at 10:41 PM, Brian Hausknecht <bhauskne(at)gmail.com> wrote:
[quote] And yet the standard procedure we are all taught is 1800 Mag check. Sounds like you are giving unsubstantiated advice that is contrary to aircraft and engine operating instructions.
PostPosted: Thu May 24, 2012 10:20 pm    Post subject: Plugs leading up worse than normal Reply with quote
Nope, didn't misunderstand English.  Reread the discussion and you will see that it includes the mag check process, which is the process we typically do to check the mags which also includes leaning for the rpm increase. I see now that you were talking about a different test that is not normally done, a mixture check at idle.  Not in any of my checklists but I see now that this could be another useful check of idle mixture. Probably something my AI does at annual.
Sorry for suggesting you were looking at a process different than our manuals, you were adding another check. On May 24, 2012 11:06 PM, "Gary L Vogt" <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:[quote] Brian H,
Gary
On May 24, 2012, at 10:41 PM, Brian Hausknecht <bhauskne(at)gmail.com (bhauskne(at)gmail.com)> wrote:
Gary
>> clean for 100 hrs.
>> Cliff
> Thanks again.
> Barry
le, List Admin.
href="http://www.matronics.com/Navigator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
As for rpm drop during carb heat teat, I check at 1800 rpm leaned. It's in my checklist right after mag check.
I have records of over 2000 post annual checks for engine runup. On the average, carb heat decreases rpm anywhere from 50 to 100 rpm. It makes a difference what the OAT is, it makes a difference what the altimeter setting is. The same plane will show various rpm drops as the annual cycles months over the years.
During the carb heat rise testing for the Jaguar cowling, I tested two different Tiger air boxes. The early ones (pre-77) give less rpm drop. The air isn't as hot. Lots of leaks.
Gary
On May 24, 2012, at 11:03 PM, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote]Brian H,
Gary
Gary
>> clean for 100 hrs.
>> Cliff
> Thanks again.
> Barry
le, List Admin.
PostPosted: Fri May 25, 2012 4:52 am    Post subject: Plugs leading up worse than normal Reply with quote
Gary
Where is that documented? I think the idle circuit goes much higher
than 650 rpm as I found out in the middle of Australia when flying a
Tiger which had the idle circuit completely blocked with debris!
Cliff
bkspero
PostPosted: Fri May 25, 2012 7:34 am    Post subject: Re: Plugs leading up worse than normal Reply with quote
Gary
On May 24, 2012, at 2:10 PM, "bkspero" <bkspero> wrote:
No, these were installed by the other A&P that Alan tried.
I will check the mixture as you described. Most of my hot adjustments of the mixture were during taxi where the throttle was set a little higher than idle. Sounds like that could explain why I am seeing >50 rpm increase on leaning even hot.
Won't get to any of this stuff unless the weather here gets better though. Maybe tomorrow.
Thanks again, all.
Barry S(2)
PostPosted: Fri May 25, 2012 11:59 am    Post subject: Plugs leading up worse than normal Reply with quote
If the idle circuit is completely blocked with debris, as you say, then the engine is operating on the transition or main circuits. You can completely close the mixture down and still make the engine run. That tells you nothing.  You can even MAKE the engine idle with no flow from the idle circuit.  It will run on the rest of the carb.
There are three fuel delivery circuits in a carb. IDLE, Transition, and Main.
IDLE: No fuel flow through the main venturi. No flow through the main jet(s). All of the fuel flow comes from the idle circuit in the carb. There is no jet which changes the amount of fuel delivered. Fuel flow is adjusted by the IDLE mixture screw. The IDLE fuel delivery comes from a metered slot in the carb.
Transition: This is nothing more than an additional slot (or, sometimes, additional fuel to the IDLE slot) as the throttle plate opens. As the throttle plate opens further, manifold vacuum causes fuel to flow from the transition slot. This is to cover up a lean condition as the throttle plate is opened and the IDLE circuit cannot supply enough fuel.
Main: At some throttle plate position beyond transition, where the main venturi begins to flow fuel, the air-fuel mixture ratio is set by the main jet and the main venturi deliver system.
I have a customer, who shall remain anonymous, who insists his mixture is too rich because he gets a 200 rpm rise when leaning at 1800 rpm from full rich. He'll go home and fuck with the idle mixture crew after every annual. And, every annual I have to reset the IDLE.
Sent: Friday, May 25, 2012 5:52 AM
Subject: Re: TeamGrumman-List: Re: Plugs leading up worse than normal
--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
--> TeamGrumman-List message posted by: Gary L Vogt<teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
Gary
Where is that documented? I think the idle circuit goes much higher than 650 rpm as I found out in the middle of Australia when flying a Tiger which had the idle circuit completely blocked with or?TeamGrumman-List" target="_blank">http://www.matronics.com/Navigator?T - MATRONICS WEB FORUMS -
Goto page 1, 2  Next
Page 1 of 2
