wnorth(at)sdccd.edu Guest
Posted: Mon May 29, 2006 10:41 am Post subject: stiff brakes |
Most likely is the pedal rocker pivots are too stiff and the small
compensating valve spring in the master cyl can't open, thereby pushing the
pedal back that last bit. (These are NOT the pedal swing pivots which allow
for rudder movement) After a bit they either bleed down, or the system cools
and reduces fluid pressure.
Check by getting the brakes to the stiff condition then pull back on the
tops of the pedals to force them fully back and see if that loosens the
brakes. (This also assumes the pedal rocker action has enough swing
clearence to let the master cyls fully extend.)
If this is the case the best fix is to loosen those pivots some as another
spring is something that could break/jam/whatever at the wrong time.
Air in the line would not cause this as the compensating port allows for air
or fluid to return immediately. Is also not likely to be gunk in the caliper
as that would probably not get better after a few minutes. The same would
also be true for the too tight pins that retain the floating calipers.
The one other option is the matco style parking brake valve could be not
fully opening both poppets thereby acting like one way check valves, if one
is installed. If the above test doesn't make it better remove the pants and
get them stiff, then open the bleeder for a tad and see if they loosen. This
will tell you if the P brake is holding the pressure on. (you could also try
working the P-brake valve when they are stiff and see if that suddenly
loosens them.)
W
lifeofreiley2003(at)yahoo Guest
Posted: Tue May 30, 2006 6:42 am Post subject: stiff brakes |
Did you read this Charles?
According to Wheeler North we must be smoking crack. We never even fixed the brakes on the airplanes we worked on, as bleeding the brakes or even straightening up a caliper and brake line that was forcing a sideways bind could never have caused the brakes to have an issue! I guess is was a miracle...
Darrell
"do not archive"
loosens them.)
W
Be a chatter box. Enjoy free PC-to-PC calls with Yahoo! Messenger with Voice.
charlieray(at)optonline.n Guest
Posted: Tue May 30, 2006 3:14 pm Post subject: stiff brakes |
The wonders never cease to amaze me. Airplanes that fix themselves!
Avionics fixed by UPS!!!
Do not archive.
Charles
Posted: Tue May 30, 2006 4:17 pm Post subject: stiff brakes |
Yes, on the UPS fix...has happened a multiple times. In my 14 years of being around aircraft, flying, building, owning a flight school and performing maintenance on my aircraft there's no way I can know anything. But, who really cares...
Darrell
"DO NOT ARCHIVE"
Do not archive.
Charles
dbris200(at)sbcglobal.net Guest
Posted: Tue May 30, 2006 4:38 pm Post subject: stiff brakes |
Darrell,
I saw nothing in Wheeler's post that should cause this kind of nasty
reply. It was very good information about another possible cause for
this problem and did not attack anybody or their ideas. We've run enough
good people off this list with this kind of comment and I for one, would
like to see it stop. Say something constructive or keep it to yourself.
Dave B
Darrell Reiley wrote:
Darrell
"do not archive"
loosens them.)
W
Posted: Tue May 30, 2006 7:12 pm Post subject: stiff brakes |
Maybe you need to read his reply again...!
<snip>
for air
caliper
would
<snip>
This reply is not accurate as it solved our probelm! This is a problem I've dealt with more than once even with hand lever handicap modified levers in RV's...
I'm done...
warmest regards,
Darrell
"do not archive"
"D.Bristol" <dbris200(at)sbcglobal.net> wrote:
Darrell,
Dave B
Darrell
"do not archive"
loosens them.)
W
"Do Not Archive"
Darrell Reiley
RV7A "Reiley Rocket"
N622DR Reserved
Yahoo! Messenger with Voice. PC-to-Phone calls for ridiculously low rates.
jabowenjr(at)hotmail.com Guest
Posted: Sat Jun 03, 2006 8:11 am Post subject: stiff brakes |
Does not play well with others?
Jim Bowen
| Quote: | From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
Reply-To: rv-list(at)matronics.com
Subject: Re: stiff brakes
Date: Tue, 30 May 2006 20:09:40 -0700 (PDT)
<snip>
for air
caliper
would
<snip>
levers in RV's...
I'm done...
warmest regards,
Darrell
"do not archive"
Darrell,
Dave B
miracle...
> Darrell
> "do not archive"
the
allow
cools
another
air
caliper
one
and
This
try
>loosens them.)
>W
Voice.
"Do Not Archive"
Darrell Reiley
N622DR Reserved
