		rv10flyer(at)verizon.net Guest
				 Posted: Thu May 24, 2012 9:20 am    Post subject: Takeoff and Full flap landings |
				I am about to take the family out on a camping trip. I was given feedback  that I should avoid full flaps with the plane loaded (2515lbs- 95lb of that in  baggage area). I had planned to use full flaps, as I am coming into a airport  that is surrounded by hills and hence a steeper approach will be needed on  final. Speaking with a builder this morning I received solid feedback on why I  should use full flaps or a partial (20-25 degrees) flap setting versus the 15/18  degrees.
  I understand the wind requirement for when to and not use the full flaps, I  am interested in feedback about when do others use full flaps and reasons not to  use it.
  On the flip side on takeoff- I may use 0 degrees for shorter/ need to climb  over obstacles at end of runway, but the discussion came up about why not use 15  degrees?
  Thoughts on use of flaps on takeoff? any real benefits?
  Just looking for what others do and why, not a debate on which is right or  wrong.
  Thank you!
  Pascal
		rene(at)felker.com Guest
				 Posted: Thu May 24, 2012 9:52 am    Post subject: Takeoff and Full flap landings |
				I use full flaps, all weights and wind conditions.  Have not had a problem.
 No opinion on the flaps on take off?  Have tested it and half flap takeoffs are interesting and would appear to be an advantage for short/soft fields.  But have not done enough to have a real opinion.
 Rene' Felker
 N423CF
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
 Sent: Thursday, May 24, 2012 11:19 AM
 Subject: Takeoff and Full flap landings
 Thank you!
 Pascal
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234567
		jchang10
				 Posted: Thu May 24, 2012 9:57 am    Post subject: Takeoff and Full flap landings |
				Pascal... sounds like a great trip. my first camping trip in the -10     is high on my todo list!
      i can't think of a good reason to avoid full flaps. it lowers my     stall speed by a good margin in all CG configurations, so not sure     what is the harm.
      my word of warning is for a half-flaps takeoff. i casually decided     to give this a go one day. i normally do 0 degree takeoffs but this     was my first time at half-flaps. the plane wants to rotate so     quickly, that it caught me by surprise. i was still pushing the     throttle in when the mains left the ground before the nose wheel. i     quickly pulled back on the stick, so no harm done. anyway, i was     quite surprised how quickly everything happened.
      next time, i will make sure to add some back elevator trim before     doing a half-flaps takeoff.
      Jae
       	  | Quote: | 	 		  #40533 RV-10
 First flight 10/19/2011
 Phase 1 Done 11/26/2011 |
      On 5/24/2012 10:18 AM, Pascal wrote:     [quote]                                        I am about to take the family out on a camping trip. I               was given feedback that I should avoid full flaps with the               plane loaded (2515lbs- 95lb of that in baggage area). I               had planned to use full flaps, as I am coming into a               airport that is surrounded by hills and hence a steeper               approach will be needed on final. Speaking with a builder               this morning I received solid feedback on why I should use               full flaps or a partial (20-25 degrees) flap setting               versus the 15/18 degrees.
              Thank you!
              Pascal
  _________________ #40533 RV-10
				 Posted: Thu May 24, 2012 11:00 am    Post subject: Takeoff and Full flap landings |
				To clarify what I think Jae was saying - it's not that it wants to
 "rotate" in the classic sense, rather it will want to "wheelbarrow on
 the nosewheel because half flaps requires significant up-trim at full
 power.  And I totally agree, you need to prepare for that if you
 routinely make 0 deg TOs.
  	  | Quote: | 	 		   my word of warning is for a half-flaps takeoff. i casually decided to
 My standard procedure is to takeoff with half flaps and land with full
 flaps.  The half flaps probably has something to do with my home field
 being turf with obstructions but I never vary even on 7,000' of
 concrete.  Full flaps work in most/all wind conditions for me though I'm
 careful to liberal with power if the wind gradient gets you low and slow.
  	  | Quote: | 	 		   Next time, i will make sure to add some back elevator trim before
 Yes, it really help to have a trim position figured out and set before
 takeoff with half flaps.
				 Posted: Thu May 24, 2012 11:43 am    Post subject: Takeoff and Full flap landings |
				Thank you all who responded so quickly. Great information!
  Sticking to the plan!
  Thanks!
  Pascal
  Sent: Thursday, May 24, 2012 10:18 AM
  Thank you!
  Pascal
		Bob Turner
				 Posted: Thu May 24, 2012 12:58 pm    Post subject: Re: Takeoff and Full flap landings |
				I'd kindly suggest you exercise caution in whose advice you seek. There is absolutely no reason not to use full flaps for landing.
 Some people do avoid full flaps because their aircraft's CG is too far forward and they run out of elevator authority in the flare. Better to carry some ballast. This shouldn't be an issue for you with that much weight in the back.
 The -10 has a powerful rudder, and is a good cross wind plane. I would go to partial flaps only if the winds were so strong that I thought a go-around was likely, in which case I'd like to have the flaps already at 15-20.
 Takeoffs with 15-20 flaps will shorten the ground roll, but also reduce the rate of climb after lift off.
 I presume you've done a weight and balance. With a lot of weight in the baggage area but not so much elsewhere you may be pretty far aft. Did you check the C.G. at the landing weight? As you burn gas it will move aft if it was aft to start with.
  _________________ Bob Turner
RV-10 QB |
		Tim Olson
				 Posted: Thu May 24, 2012 1:15 pm    Post subject: Takeoff and Full flap landings |
				I use full flaps on landing *all* the time.
 I use 1 notch of flaps for takeoff when I'm on grass or short
 fields.
 On 5/24/2012 12:18 PM, Pascal wrote:
  	  | Quote: | 	 		   I am about to take the family out on a camping trip. I was given
  or wrong.
  Thank you!
  Pascal
				 Posted: Thu May 24, 2012 1:27 pm    Post subject: Takeoff and Full flap landings |
				Sometimes people give advice without one asking. It is a certainty at my
 airport. Regardless if the advice comes from a friend of a friend whose
 brother was an A/P or a experienced pilot, I consider every piece of
 "advice" given.
 This forum serves as a great jury on what may or may not be a problem. Since
 most have flown their planes far more than I have, especially with folks and
 cargo aboard, the advice is far more credible for my final decision on how
 to fly into a mountainous valley airport.
 I use Greg Hale's W&B that he offered up to the group. I have two kids in
 the back that along with 95lbs in baggage (three women will do this!)
 Differnce in CG is minimal for the 45 minute flight.
 Appreciate your feedback!
 Pascal
		arplnplt(at)gmail.com Guest
				 Posted: Thu May 24, 2012 4:58 pm    Post subject: Takeoff and Full flap landings |
				Try doing a touch and go after landing with full flaps.  The ten lifts off like a Harrier!
 Dave Leikam
 On May 24, 2012, at 12:55 PM, Jae Chang wrote:
 [quote]                    Pascal... sounds like a great trip. my first camping trip in the -10     is high on my todo list!
      Jae
      On 5/24/2012 10:18 AM, Pascal wrote:      	  | Quote: | 	 		                                          I am about to take the family out on a camping trip. I               was given feedback that I should avoid full flaps with the               plane loaded (2515lbs- 95lb of that in baggage area). I               had planned to use full flaps, as I am coming into a               airport that is surrounded by hills and hence a steeper               approach will be needed on final. Speaking with a builder               this morning I received solid feedback on why I should use               full flaps or a partial (20-25 degrees) flap setting               versus the 15/18 degrees.
              Thank you!
              Pascal
		toaster73(at)embarqmail.c Guest
				 Posted: Thu May 24, 2012 5:16 pm    Post subject: Takeoff and Full flap landings |
				Yep! that is real fun, I did a couple of "wave offs" like that while exploring the envelope.
 -Chris
   N919AR
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Leikam
 Sent: Thursday, May 24, 2012 8:58 PM
 Subject: Re: Takeoff and Full flap landings
 Dave Leikam
 Jae
  	  | Quote: | 	 		  | #40533 RV-10First flight 10/19/2011Phase 1 Done 11/26/2011 |
 Thank you!
 Pascal
  	  | Quote: | 	 		  |   First flight 10/19/2011 | 	  0 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  1 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  2 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  3 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  4 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  5 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  6 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  7 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  8 	  | Quote: | 	 		  | First flight 10/19/2011 | 	  9 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  0 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  1 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  2 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  3 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  4 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  5 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  6 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  7 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  8 	  | Quote: | 	 		  | Phase 1 Done 11/26/2011 | 	  9
