		dreel(at)cox.net Guest
				 Posted: Tue May 30, 2006 6:47 am    Post subject: How to add 15kt to cruise speed by adding weight |
				I've been exploring the CG range in flight testing of my RV8A and have found
 an unanticipated cruise speed effect.  At 85.9 inches, I was getting 155kias
 with 2300rpm, 23 in mp, 5,500 ft, and 42 degrees F outside.  At 79.6 inches,
 I got 142kias with 2300rpm, 23 in mp, 4,500 ft, and 64 degrees F outside.
 My whiz wheel gives true airspeeds of roughly 169kt and 154kt.  Quite an
 improvement just by adding some weight in back.  Yes, the fast flight was
 with a little bit higher weight!
 There's lots of discussion of speed improvements in the archives, but
 nothing related to CG location that I could find and certainly nothing so
 easy to get and of this magnitude.  So, my question to everyone is have you
 had similar experience?  Do you know anywhere this has been quantified or
 further detailed?  After all, I'm just comparing two test flights here, but
 theoretically, I'd guess the decrease in drag due to decreased pitch
 stability requirements as the CG moves aft would explain the speed increase.
 Excited!
 Dave Reel - RV8A
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Tue May 30, 2006 7:14 am    Post subject: How to add 15kt to cruise speed by adding weight |
				Have you tried simply altering the CG and not the weight?
 I think I remember reading somewhere that the shifted CG changes stabilized AOA thereby changing drag characteristics.
 Geek - not aerodynamicist...and I stayed at a Marriot this weekend instead of a Holiday Inn!
		alexpeterson(at)earthlink Guest
				 Posted: Tue May 30, 2006 7:25 am    Post subject: How to add 15kt to cruise speed by adding weight |
  and have found an unanticipated cruise speed effect.  At 85.9
  inches, I was getting 155kias with 2300rpm, 23 in mp, 5,500
  ft, and 42 degrees F outside.  At 79.6 inches, I got 142kias
  154kt.  Quite an improvement just by adding some weight in
  back.  Yes, the fast flight was with a little bit higher weight!
  archives, but nothing related to CG location that I could
  find and certainly nothing so easy to get and of this
  magnitude.  So, my question to everyone is have you had
  quantified or further detailed?  After all, I'm just
  comparing two test flights here, but theoretically, I'd guess
  the decrease in drag due to decreased pitch stability
  Excited!
  Dave Reel - RV8A
 Dave,
 What were the fuel burns during those two runs?  One cannot state that the
 power was the same, only that the MAP and RPM were the same.  You can vary
 airspeed greatly with mixture.
 A more aft cg is more efficient, but not that much.  (The tail doesn't have
 to generate as much downward lift.)
 Alex Peterson
 RV6-A N66AP 755 hours
 Maple Grove, MN
		lsbrv7a(at)yahoo.com Guest
				 Posted: Tue May 30, 2006 7:39 am    Post subject: How to add 15kt to cruise speed by adding weight |
				David,
   That is true in my Bonanza as well, although I have never tried to quantify it.  Less drag from less elevator (ruddivator) down force.
   The Bonanza experts warn of CG change with fuel burn moving the CG aft and the possibility of elevator sensitivity during the landing flare resulting in over correction.
   Did you notice increased elevator sensitivity?
 Excited!
 Dave Reel - RV8A
 Sherman Butler
 RV-7a Wings
 Idaho Falls
 Be a chatter box. Enjoy free PC-to-PC calls  with Yahoo! Messenger with Voice.
		LloydDR(at)wernerco.com Guest
				 Posted: Tue May 30, 2006 8:10 am    Post subject: How to add 15kt to cruise speed by adding weight |
				This has been discussed before on the 10 list. The heavy lift planes of
 the military will shift loads in flight to do this same thing. How much
 and to what degree, you would have to talk with a loadmaster, and they
 tell real interesting stories!
 So, yes it is possible, but to do it reliable in a small aircraft,
 without getting your CG stuck in an aft position, is the big risk, and
 not worth it in my book.
 YMMV
 Dan
 RV10 40269
 N289DT
		dan.beadle(at)inclinesoft Guest
				 Posted: Tue May 30, 2006 8:39 am    Post subject: How to add 15kt to cruise speed by adding weight |
				This is basic aerodynamics.  To get stability (AKA, hard to flare), you move
 the CG forward.  Think Lawn Dart.  In this mode, the tail actually pulls
 down, not up.  This results in the wing needing to produce more lift (weight
 + the tails negative lift so that total lift = weight).
 If you move the CG back, you have less and less down-lift on the tail,
 letting the wing work less, thus getting less induced drag.  Faster.
 A heavier airplane, with the same CG, should fly slower than the same plane,
 same CG, when it is lighter. The reason is the heavier airplane must have a
 higher angle of attack to produce the needed additional lift.  That means
 more induced drag.
 The CG limits are set to give reasonable handling.  The forward CG is
 limited by the ability to flare.
 The Aft CG is limited by the need for positive stability. If we moved the CG
 back to where the tail was lifting, we would have no stability.  In the
 normal range, as the plane slows from the trimmed AS, the wing and the tail
 both lose some lift.  But the tail is now lifting less in the downward
 direction, letting the nose fall down a bit and resume the trimmed AS.
 If we move too far back, we lose the stability feature making the airplane
 difficult or impossible to fly.
 Rule of thumb:  smooth air, load for aft CG (within limits).  Rough air,
 keep a more forward CG.
 So your data does make sense.  (But the faster/heavier combination is
 probably just due to aft CG.)
 Dan
		Tim(at)MyRV10.com Guest
				 Posted: Tue May 30, 2006 9:15 am    Post subject: How to add 15kt to cruise speed by adding weight |
				I don't see it as an especially big risk, providing it's a fairly
 simple load move.  People don't think twice about putting another
 person in the rear seat, which is basically what we'd be talking
 about here, or putting some baggage in the tail.
 I first noticed this phenomenon in my Sundowner when I brought
 along a CFI buddy and his girlfriend, who was a pretty chunky chick.
 It was weird that we had a noticeably higher cruise speed with
 her, than without.
 So sure, if you're going to fly X/C somewhere, do the load
 calculations and if you're way forward on CG, feel free to
 NOT put that big pile of bags in the rear seats, but
 move them to the baggage area if it fits there and weighs
 out properly.   Just don't go aft of CG.  That's what the
 range is there for.
  YMMV
  Dan
  RV10 40269
  N289DT
		jjessen
				 Posted: Tue May 30, 2006 9:53 am    Post subject: How to add 15kt to cruise speed by adding weight |
				Someone, on some list, suggested a system of water bottles that you empty /
 fill as needed.  I know about the Bonanza gaining aft CG as fuel burns, but
 not sure about the RV's.  I think the -10 might.  One might have full water
 on take off and empty as the CG naturally moves aft with fuel burn.  The
 amount of water dependent on the load calculations.
 John Jessen - Tailcone - RV10
		Ed Anderson
				 Posted: Tue May 30, 2006 10:09 am    Post subject: How to add 15kt to cruise speed by adding weight |
				Hi Dave,
 I discovered the same effect in my RV-6A which is a bit nose heavy.  Best
 top speed was when I had the baggage compartment load to the max with
 camping gear and full wing tanks.  I suspect you are correct in that the aft
 CG results in less down component from the horizonal stabilizer resulting in
 less drag.   The wing incident may also be a bit more optimum (less) also
 resulting in less drag.  As best I could determine my speed increase was
 between 8-10 MPH.
 Ed
 Ed Anderson
 Rv-6A N494BW Rotary Powered
 Matthews, NC
 eanderson(at)carolina.rr.com
  _________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
		smittysrv
				 Posted: Tue May 30, 2006 12:18 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				Funny that this topic came up. Over the weekend, My wife, 10 year old son
 and I went a short one hour flight in our C172. My 10 year old pitched a
 royal hissy, wanting to ride in front with me. Rather than argue, my wife
 reluctantly volunteered to sit in back seat. This was the first time in
 many pounds since we have done this. The take-off felt a little weird but
 manageable. When we leveled off I noticed that the ground seemed to going
 by a lot faster than usual. We were going 15kt faster!
 On the return fight, my wife made the kiddo sit in the back. Man, that was
 a long (and slow) trip back. Hmmm, in the future, how do get the wife in
 the back seat without being obvious? I guess I'll keep my mouth shut and
 fly slow.
 Ya'll have a goodun!
 Smitty
 http://SmittysRV.com
  her, than without.
  range is there for.
 > YMMV
 > Dan
 > RV10 40269
 > N289DT
 > Do not archive
  _________________ Smittys RV-9A
SmittysRV.com
		Dale Ensing
  Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
				 Posted: Tue May 30, 2006 12:33 pm    Post subject: How to add 15kt to cruise speed by adding weight |
 Smitty, just think back a few years. How did you do it then?
 anonymous RV-6A
  _________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
		rick(at)n608ef.us Guest
				 Posted: Tue May 30, 2006 12:41 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				I like Dan's explanation, but will add a bit more.
 Specifically, we require the CG to be forward of the center of lift (CL) in
 order to have a stable aircraft (and one whose nose drops when the wing is
 stalled).  The closer the CG gets to the CL, the less induced drag, but the
 less stable the plane will be.  If the CG should go aft of the CL, all bets
 are off in terms of controllability.
 Another e-mail commented on Bonanzas and how their CG moves with fuel burn.
 Whether the CG moves aft with fuel burn should depend on the CG of the tank
 and its fuel relative to the CG of the plane.  I fly an A-36 Bonanza, and
 when weight is up (hence, realistically, with a CG farther aft than when
 lightly loaded), I have indeed noticed greater pitch sensitivity after a
 long flight.  When I plan flights at higher weights, I check my loading by
 calculating CG for zero fuel, just to be on the safe side.  For extra
 margin), I try to land with fuller tanks, too.
 Rick
 A-36, RV-7 in process
		jpl(at)showpage.org Guest
				 Posted: Tue May 30, 2006 1:00 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				Hand her a camera and point out she can take photos out both sides on
 the way home
 -J
 On May 30, 2006, at 3:15 PM, Smitty wrote:
  that was
  wife in
  shut and
  fly slow.
  Smitty
		low pass
				 Posted: Tue May 30, 2006 1:35 pm    Post subject: Re: How to add 15kt to cruise speed by adding weight |
				Couple of points on this topic:
 1.  A friend said they used to (probably still do) add steel weights to the tail of AT-6's that race in Reno for speed improvements.  Can't recall, but I believe they have minimum weights and are probably working with that number but just shifting the CG aft.
 2.  A few years back I started trying to quantify this situation with adding weight aft.  I never got a conclusive answer, but wondered if the benefit of adding ballast to move the CG aft offset the penalty of added overall weight.
 Example:  I am flying (racing) with a near empty airplane.  Would the plane be faster with 50-lbs of ballast in the rear baggage compartment than without the 50-lbs?  Or faster with 50-lbs of ballast and if I lost 20-lbs??
 Seriously, it sounds like there may be some conditions where the added overall weight to move the CG aft may help.
 Bryan
		Jerry Grimmonpre'
  Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
				 Posted: Tue May 30, 2006 2:11 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				Passed on for what it's worth ...
 I've seen it demonstrated, in the big iron, when the airlines loaded the a/c
 tail heavy, the elevator would raise the tail and thereby, create an airfoil
 shape.  The hs/elevator would sort of act like an airfoil and create lift.
 The up movement of the tail would reduce the wing incidence and shed some
 induced drag.
 Jerry Grimmonpre'
 RV8A Electrical
  	  | Quote: | 	 		   I discovered the same effect in my RV-6A which is a bit nose heavy.  Best
  aft
  in
  between 8-10 MPH.
  Ed
  Ed Anderson
  Matthews, NC
				 Posted: Tue May 30, 2006 2:27 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				You could do some very careful calculations, then try adding a much
 smaller weight in the far aft tailcone area somewhere.  You wouldn't
 need remotely as much ballast as something in the baggage compartment
 - a few pounds would be pretty significant.
 Not something you would want to do casually.  If remotely in doubt,
 you'd want to reweigh the plane afterwards and reverify the CG
 information.
 As you say, 50 pounds of ballast could easily offset the advantages
 of pushing the CG back.  This would at least require far less than 50
 pounds.
 -Joe
 On May 30, 2006, at 4:35 PM, bdjones1965 wrote:
  the CG aft.
  Bryan
		T.gummo(at)verizon.net Guest
				 Posted: Tue May 30, 2006 3:03 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				Simple, get an RV-4, RV-8 or Harmon Rocket II.  If she isn't a pilot, she
 has to sit in the back.
 Tom Gummo
 Apple Valley, CA
 Harmon Rocket-II
 http://mysite.verizon.net/t.gummo/index.html
		ronlee(at)pcisys.net Guest
				 Posted: Tue May 30, 2006 3:30 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				 	  | Quote: | 	 		  Simple, get an RV-4, RV-8 or Harmon Rocket II.  If she isn't a pilot, she
 Possible problem is that if she has any hint of claustrophobia she
 may never fly with you again (at least in a -4).
 Ron Lee
		khorton01(at)rogers.com Guest
				 Posted: Tue May 30, 2006 4:04 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				--- DAVID REEL <dreel(at)cox.net> wrote:
  <dreel(at)cox.net>
  and 154kt.  Quite an
  the archives, but
  decreased pitch
  Excited!
 A few comments:
 1. If you keep the rpm and MP the same, the power
 produced increases as you increase altitude (due, I
 think, to the lower exhaust back pressure helping
 improve the engine's breathing).  So, the test at
 5,500 ft was with higher power than the test at 4,500
 ft.  The air temperature was also quite a bit lower
 for the 5,500 ft test point.  I don't know what engine
 you have, but if you have an IO-360-A series engine,
 the power at 5,500 ft was about 67.2%, and the power
 at 4,500 ft was about 65.1%.  If you had an O-360-A
 series engine, the power at 5,500 ft was about 75%,
 and at 4,500 ft it was about 72.6%.
 As Alex Peterson mentioned, the mixture setting could
 also play a role, as you can change the power by
 changing the mixture, at the same rpm and MP.
 2. ASIs have instrument error, and the error will be
 different at different indicated airspeeds.  Static
 system position error is also different at different
 Given items 1 and 2, it would be very interesting to
 repeat these tests at the same altitude.  It will also
 be interesting to record the fuel flow, to be sure it
 is the same for each test.
 3. At a given weight, there is less drag as you move
 the CG aft (with the CG in approved limits).  The tail
 has to produce a down force to balance out the nose
 down pitching moment from the wing, and the fact that
 the CG is ahead of the wing's centre of pressure.  The
 total lift that the wing has to produce is equal to
 the aircraft's weight, plus the amount of down force
 that the tail is producing.  If you keep the aircraft
 weight the same, and move the CG aft, the amount of
 down force that the tail needs to produce decreases.
 This reduces the drag from the tail, but more
 importantly, it also reduces the amount of lift that
 the wing has to generate.
 So, if you move some item of weight aft (baggage, a
 body, etc), that will help reduce drag.
 4. If you can't move an item of weight aft, some
 people are interested to know if you can improve
 performance by adding weight aft.  Ideally, the weight
 you add would be in the area of the horizontal stab,
 or further aft.  In this case, the amount of down
 force that the tail needs to produce is decreased.
 This reduces drag, as there is less induced drag from
 the tail.  But, the amount of lift that the wing has
 to generate has not changed, for as far as it is
 concerned, we have simply replaced some down force
 from the tail by down force from gravity on our added
 weight.  So the wing's induced drag does not change.
 5. If you can't put the added weight at the HS, what
 about putting it in the baggage compartment?  In this
 case, some of the additional weight is supported by
 the wing, and some by the tail.  So the amount of tail
 down force decreases a bit, but the amount of lift
 that the wing has to generate increases.  Depending on
 how far aft the baggage compartment is, the total drag
 may be increased or decreased.  My gut feel is that in
 most cases the total drag would be increased.
 6. it is very difficult to obtain repeatable speed vs
 power data.  Any one test point may be in error due to
 poor air quality, not waiting long enough for the
 speed to stabilize, errors in setting the power or
 mixture, or errors in recording the data, etc.  I
 wouldn't draw any conclusions from one set of tests.
 If you can do the same test on three or four different
 days and get the same speed vs power, then you know
 you have something.
 Keep us posted as you do more tests.
 Kevin Horton
 RV-8 (Finishing Kit)
 Ottawa, Canada
 http://www.kilohotel.com/rv8
				 Posted: Tue May 30, 2006 6:12 pm    Post subject: How to add 15kt to cruise speed by adding weight |
				Of course, marrying wisely helps a lot too.  My wife watched me fly an F-4
 for twenty years and never even had one thought other than the Pilot sat up
 front and the other person sat in the back.  She picked the RV-4 as the
 starting point of my building a plane.  The RV-4 changed to a Harmon Rocket
 very early and didn't require reworking.
 Gummi
  	  | Quote: | 	 		  >Simple, get an RV-4, RV-8 or Harmon Rocket II.  If she isn't a pilot, she
  Ron Lee
