Twinstar MK II W+ B solved
lmorgan100(at)charter.net
PostPosted: Fri May 25, 2012 1:14 pm    Post subject: Twinstar MK II W+ B solved Reply with quote
I finally figured out why my weight and balance was not coming out correct.
I am ashamed to say that I happened to notice a bulge in the tarp that was
over my engine and that bulge turned out to be about two gallons of water
hanging behind the wing. This was making my calculations show a slightly
tail heavy plane, now without the water, I come in at 35% with one person
and at 25% with two people. I could still use something from a Twinstar
manual that states that this is the correct range in case I am asked where I
got the numbers from for my airworthiness certificate.
thanks,
Lee..
elleryweld(at)aol.com
PostPosted: Sat May 26, 2012 4:16 am    Post subject: Twinstar MK II W+ B solved Reply with quote
i am Just thinking out loud so you plan to fly the airplane with that plastic on it? would it be ok to pile a bunch of items on the airplane some where and leave em there during the W&B process" NOT"
any weight is weight suppose to do a W&B with only what you would normally have on the airplane during flight operations
Ellery Batchelder Jr.
PostPosted: Sun May 27, 2012 4:37 am    Post subject: Twinstar MK II W+ B solved Reply with quote
Ellery,
Your right,
I said I was ashamed, But I am still looking for a copy of the page in the
Twinstar Mk II manual that gives the acceptable CG range.
thanks,
Lee..
_____________________________________
Time: 05:16:57 AM PST US
Subject: Re: Twinstar MK II W+ B solved
cristalclear13
PostPosted: Sun May 27, 2012 8:14 am    Post subject: Re: Twinstar MK II W+ B solved Reply with quote
thanks,
Lee..
Lee, I haven't had time to look up all my original measurements and calculations, but I do recall someone telling me that the CG should be 20-30% of the wing. My datum was 69.75" forward of the main wheels and so I set my CG at 80-89" aft of the datum.
I'm glad you found your issue. Let me know if you need any more info.
Sorry for the delay.
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
PostPosted: Sun May 27, 2012 9:34 am    Post subject: Twinstar MK II W+ B solved Reply with quote
correct.
Lee..
Lee/Kolbers:
In my humble opinion and experience building and flying Kolbs for many
years, problems with getting a Kolb aircraft into a flyable approved cg
range is more paper than airplane.
In the beginning no weight and balance form was used with the 1984
Ultrastar. Build it close to what the plans called for and it would be
within cg and fly like a bird. In fact, Homer Kolb said if you wanted to
check the cg, hang the Ultrastar from a rafter with the rope attached at the
main spar carry through of the fuselage. If it balanced, it was good to go.
I never tried that.
1987 Firestar was built and flown with the same instructions from Homer
Kolb.
1992 MKIII had a weight and balance formula. Needed it to pass the
airworthiness inspection for homebuilt experimental classification. We
worked on that problem for quite a while, then gave up and used an "M-1
pencil" to complete the form to make the MKIII flyable. The numbers kept
saying we had a severe aft cg problem.
One way to demonstrate that I did not have an aft cg problem, I installed
and flew a 12 lb Maule Tundra Tail Wheel on my MKIII. Did I have an aft cg
problem? Nope.
Should everyone who builds and flies Kolbs use the same weight and balance
check that I do? Would not say or recommend one way or the other. I flew
the MKIII with that 12 lb tail wheel, 150 lbs of fuel and 125 lbs of cargo
behind the cg, for about 5 years. That includes 5 or 6 flights to the West
Coast and Lakeland, plus a couple to Oshkosh. I think I am good to go.
Still flying with a 7 lb Maule 6" solid rubber tail wheel. Works great.
Take care,
hauck's holler, alabama
zeprep251(at)aol.com
PostPosted: Sun May 27, 2012 12:32 pm    Post subject: Twinstar MK II W+ B solved Reply with quote
You certainly can fly a Kolb relatively safely with it way aft CG wise.But you cannot say it will fly the same as it would if it were in range.All you have to do is try it both ways,preferably in rough air,and you can make your own decision.
G.Aman Mk3 Jabiru 2200A 700 hrs
flykolb(at)pa.net
PostPosted: Sun May 27, 2012 2:42 pm    Post subject: Twinstar MK II W+ B solved Reply with quote
I found the following in the archives. It may or may not help for what you
are looking for, but it was the determination way back then.
Dennis
To Kolb Builders,
When we installed the 912 we simply added some weight (about (20 lb.) in the
nose and went flying. We then started removing the weight gradually and
wound up eventually removing it all. We thus wound up with a C.G. at 40%
with our flight instructor (who weighs about 170 lb.). To our amazement the
Mark-III still stalls fairly well. This is how we are currently flying our
own Mark-III.
The Mark-III has been certified in England and they tested the C.G. as far
back as 39% and found that it still had adequate stall characteristics.
At 35-37%, all Kolb aircraft have good stall characteristics.
Even though we know the C.G. can be further back than 35%, we will be
officially leaving it at 35%, the margin is to absorb a certain amount of
scale error.
Eventually we will be exploring even more aft C.G. conditions. Our large
chord wing and large tail volume, would seem to help in handling a more aft
C.G. condition.
If anyone has any further questions on C.G. please feel free to ask.
Sincerely,
Dennis L. Souder
President, Kolb Aircraft
