Robert_Harris(at)intuit.c Guest
Posted: Tue May 30, 2006 9:36 am Post subject: Flaps or no flaps on crosswind lanings in a heavy V |
Hey Kurt and others,
In crosswind conditions do you find it easier to land with no flaps or
one notch flaps? I have not landed in a significant crosswind yet but I
prefer one notch three point landings for regular landings as I feel I
have more control of the plane and it lands at a much slower speed.
Robert
Model V 0200
San Diego, CA
smokey_bear_40220(at)yaho Guest
Posted: Tue May 30, 2006 10:26 am Post subject: Flaps or no flaps on crosswind lanings in a heavy V |
Where I am now in Florida there are almost constant
crosswinds. My first landing there was 90 degrees 12
gusting to 20. That was the worst I have dealt with
so far. Only 70 hrs in type.
I like the 50% flaps, 3 point stall, dumping them on
touchdown technique. The plane sits right down.
Almost wish I had a twist grip throttle on the flap
handle. Full control of thrust and lift between that
and the stick... Old helo pilot here....
On my second such landing on pavement and second using
that technique during testing, I got confused. I
grabbed and "pulled" full flaps. There I was back 10
feet high, no speed and my hand off the throttle.
Ever hear people laugh on the radio???
Haven't found a need for full flaps, unless I really
had to make a short landing in a headwind. So far not
required. I have gottin it down to 30 knots full
flaps and power on in flight, but that is hanging.
Not yet up to doing that for landings.
I added 2 intermediate flap settings on my plane. I
might block out the highest setting for control
purposes. The rest work fine and I can use 1/4 flaps
for takeoff if needed.
Kurt S. S-5
--- "Harris, Robert" <Robert_Harris(at)intuit.com> wrote:
| Quote: | Hey Kurt and others,
crosswind yet but I
much slower speed.
Robert
Model V 0200
San Diego, CA
dave(at)cfisher.com Guest
Posted: Tue May 30, 2006 10:57 am Post subject: Flaps or no flaps on crosswind lanings in a heavy V |
Kurt - Good point on crosswinds and flaps. And dumping flaps once gear
touches kills the extra lift and give better braking power.
I will tell you that I only use full flaps for quicker take off and I have a
Model IV that has about 30 degrees down travel. I have read of some that
never use flaps but I almost always do. It will take extra load from gear to
wings quicker on TO and visa cresa on landing. Besides we do want the
shortest adn slowest take off and landings ideally.
Dave
Thanks Kurt,
I'll practice dumping the flaps.
Robert
algate(at)attglobal.net Guest
Posted: Tue May 30, 2006 11:09 am Post subject: Flaps or no flaps on crosswind lanings in a heavy V |
I agree totally with Dave,
I almost always use flaps to some degree but in a cross wind I lift the
flaps immediately I have touched down. I find that this gives quick
authority to the rudder and puts the weight on the gear. I do the same on a
soft field landing as lifting the flaps reduces any tendency to nose over.
Gary Algate
