Bi-ennial transponder/encoder/static certifications
recapen(at)earthlink.net
PostPosted: Fri Jun 08, 2012 6:46 am    Post subject: Bi-ennial transponder/encoder/static certifications Reply with quote
Thanks - I figured there would be some weasel-wording in there.
Since I have already done most of the tests, I have a high confidence level in taking it to a 'certified' shop.
Good scoop!
Eric M. Jones
PostPosted: Sat Jun 09, 2012 7:23 am    Post subject: Re: Bi-ennial transponder/encoder/static certifications Reply with quote
I have a high confidence level in taking it to a 'certified' shop...Bi-ennial transponder/encoder/static certifications (Ralph E. Capen)
Definitions for Airmen:
Certified: Endorsed by authorities as having met specific requirements or possessing certain qualities; e.g. " Certified Public Accountant", i.e., a person skilled at altering or destroying documents, ignoring or failing to investigate shell companies created by insiders who grotesquely enriched themselves while hiding mounting corporate debt in "off-balance-sheet companies"; Ignoring knowledgeable whistleblowers and accounting "red flags" that indicate massive fraud is taking place; misleading investors who continued pouring their money into failing companies. See “Enron”.
Certifiable: Determined to be insane or non compos mentis; e.g. “I know who I am. No one else knows who I am. If I was a giraffe, and someone said I was a snake, I'd think, no, actually I'm a giraffe.” - Richard Gere
Certificated: Something or someone judged to meet certain standards, e.g. “airworthiness” or as in “certificated flight instructor”. The term signifies that a printed official-looking paper (a “ticket”, slang for certificate) is somewhere to be found.
Discussion--The FAA is quite careful to use the word “certify” only in the sense of “swear to the truthfulness of” or “affirm”. For example:
“…you only have to certify that you have no medical defect…”
“You must certify the application form by reading, answering, signing, and dating….”
“…to certify the record is true and complete.”
In good humor, Eric M. Jones
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
