Tim Olson
Posted: Tue Jun 12, 2012 1:02 pm Post subject: Mystery Oil Leak (solved) |
Not sure what I mentioned and what I didn't on the list.
I did have this write-up from the fall:
http://www.myrv10.com/N104CD/maintenance/20110819/index.html
I had a very minor oil leak. You could see oil spots that
were so small, they were just pinprick in size on the windshield.
They ONLY were on the co-pilot side. Back then, I also had some
oil inside my ring gear area, and dripping down hanging from the
starter and under my engine a bit.
After I did some crankshaft seal work, I have had a constant
bit of oil that still gets on my windshield. I did a write-up
now for that too, since I FINALLY, after many many days
and hours and dollars, found the culprit!
http://www.myrv10.com/N104CD/maintenance/20120609/index.html
Hopefully that will help someone else with a leak. I know talking
with Scott, he had identical symptoms within the first 50 hours
of operation.
coop85(at)verizon.net Guest
Posted: Tue Jun 12, 2012 1:39 pm Post subject: Mystery Oil Leak (solved) |
Tim,
Thanks for the write up, I too fell victim to over servicing the first time around. It's easy to do.
Just out of curiosity, what is the shop charging you to replace the seals?
Marcus
of operation.
Tim Olson
Posted: Tue Jun 12, 2012 2:44 pm Post subject: Mystery Oil Leak (solved) |
I don't get the bill for a couple days yet, but, it sounds like
a good ballpark is maybe $500. A couple of the seals are
about $90 each from the sounds of it. So that's not too horrible
considering the trip I'm about to head on...I want things
PERFECT.
Tim Olson - RV-10 N104CD
On 6/12/2012 4:34 PM, Marcus Cooper wrote:
Tim,
Marcus
of operation.
Bob Turner
Posted: Tue Jun 12, 2012 9:29 pm Post subject: Re: Mystery Oil Leak (solved) |
Some years ago our 182 (McCauley prop) started throwing grease, not too long after overhaul. Shop took it apart and put it back together, said they didn't find anything wrong. But the grease went away. Maybe a dirty O ring. McCauley suggested we cycle the prop 4 or 5 times during run ups to help keep O rings seated.
_________________ Bob Turner
RV-10 QB |
Kelly McMullen
Posted: Wed Jun 13, 2012 4:49 am Post subject: Mystery Oil Leak (solved) |
Keep in mind that cycling a prop is NOT good for the prop or the
engine. Its only purpose is to verify that the prop control and
governor are operational, and a 100-200 rpm drop is more than
sufficient for that purpose. The blades will get rotated as part of
normal take-off and climb. I cringe every time I hear pilots deep
cycling props, as though they want to see if full coarse pitch can
stall the engine.
Latest thinking is to only cycle the prop if the plane hasn't flown
for awhile, and then just a small drop to verify the system is
functioning.
Kelly
On Tue, Jun 12, 2012 at 10:29 PM, Bob Turner <bobturner(at)alum.rpi.edu> wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=375481#375481
A&P/IA, EAA Tech Counselor
KCHD |
tomrv4(at)me.com Guest
Posted: Wed Jun 13, 2012 5:13 am Post subject: Mystery Oil Leak (solved) |
Agree with Kelly...
I fly a Cirrus, which has a single power lever controlling both throttle and prop. Therefore the prop never gets cycled on the ground. To the best of my knowledge, the props on Cirrus planes do not leak any more than the standard setup...
Tom
On Jun 13, 2012, at 07:48 AM, Kelly McMullen <apilot2(at)gmail.com> wrote:
| Quote: | --> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
stall the engine.
functioning.
Kelly
On Tue, Jun 12, 2012 at 10:29 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
> --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
> Bob Turner
> RV-10 QB
>ta-mce-href="http://www.matronics.com/Navigator?RV10-List">http://www.ma://forums.matronics.com" data-mce-href="http://forums.matronics.com">httf="http://www.matronics.com/contribution" data-mce-href="http://www.ma==========
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Wed Jun 13, 2012 6:59 am Post subject: Re: Mystery Oil Leak (solved) |
| Kelly McMullen wrote: | Keep in mind that cycling a prop is NOT good for the prop or the
stall the engine.
functioning.
Kelly
On Tue, Jun 12, 2012 at 10:29 PM, Bob Turner <bobturner> wrote:
Bob Turner
RV-10 QB
Kelly's advice is exactly the advice I got from Maxwell Aircraft Service in Minneapolis when they overhauled the prop on my Bonanza a few years ago.
They have been overhauling propellers for 45 years and Mr. Maxwell told me he could hear money coming in to his cash register whenever he heard someone deep cycling the prop two, three, or more times before takeoff.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
hotwheels
Posted: Wed Jun 13, 2012 7:04 am Post subject: Re: Mystery Oil Leak (solved) |
This write up was very helpful... My new Hartzell prop had been in the box waiting to be installed for several years. When I took it out, it was obvious that the factory grease had separated as there was oil inside the spinner. I re-greased the prop per the manual and hung it... Several days later there was a thin sheen of oil coming down the inside of one blade. I don't think I over greased, but it's possible. Sounds like a call to Hartzell is in order.
Jay
at the airport finally
drfred(at)suddenlinkmail. Guest
Posted: Wed Jun 13, 2012 8:28 am Post subject: Mystery Oil Leak (solved) |
Kelly;
I usually check the prop each time as part of my checklist. I just
listen for the slight drop and then go back to fine pitch. You say it
is not good for the engine or the prop. Why??? I can understand
possibly strain on the bearings maybe, but in less than two minutes,
I'm asking the engine for full power for takeoff. I'm trying to
figure out if this is one of those "opinions" or what are the facts
behind this issue.
Dr Fred.
On 6/13/2012 7:48 AM, Kelly McMullen wrote:
stall the engine.
functioning.
Kelly
On Tue, Jun 12, 2012 at 10:29 PM, Bob Turner<bobturner(at)alum.rpi.edu> wrote:
> Bob Turner
> RV-10 QB
philperry9
Posted: Wed Jun 13, 2012 8:42 am Post subject: Mystery Oil Leak (solved) |
I've always cycled it fairly aggressively just to see if I can get oil on the windscreen or the top of the cowling. I figure that if I'm going to blow a seal or discover a leak, I'd rather discover it before my wheels leave the ground.
I'm not saying I'm trying to bog the engine down and abusing it, but I'm doing more than simply looking for a slight drop.
Phil
On Wed, Jun 13, 2012 at 11:27 AM, Fred Williams, M.D. <drfred(at)suddenlinkmail.com (drfred(at)suddenlinkmail.com)> wrote:
[quote]--> RV10-List message posted by: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com (drfred(at)suddenlinkmail.com)>
Kelly;
I usually check the prop each time as part of my checklist. I just listen for the slight drop and then go back to fine pitch. You say it is not good for the engine or the prop. Why??? I can understand possibly strain on the bearings maybe, but in less than two minutes, I'm asking the engine for full power for takeoff. I'm trying to figure out if this is one of those "opinions" or what are the facts behind this issue.
Dr Fred.
| Quote: | --> RV10-List message posted by: Kelly McMullen<apilot2(at)gmail.com (apilot2(at)gmail.com)>
stall the engine.
functioning.
Kelly
On Tue, Jun 12, 2012 at 10:29 PM, Bob Turner<bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner"<bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
le, List Admin.
taildragon(at)msn.com Guest
Posted: Wed Jun 13, 2012 8:54 am Post subject: Mystery Oil Leak (solved) |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> After checking mags at 1800 rpm, I reduce rpm to 1400 for the prop check. A&Ps I talk to suggested it. Anyone else doing that?
Roger
Gordon Anderson
And I've always cycled 2 or 3 times under the impression it was intended to get warm oil into the propshaft and increase the reaction speed of the governor / prop. This certainly is the case on a cold Rotax - rpm recovery is much better after the 3rd cycle than the first - but I can't speak for other engines.
Gordon
On Jun 13, 2012, at 6:41 PM, Phillip Perry wrote:
[quote]I've always cycled it fairly aggressively just to see if I can get oil on the windscreen or the top of the cowling. I figure that if I'm going to blow a seal or discover a leak, I'd rather discover it before my wheels leave the ground.
Phil
| Quote: | --> RV10-List message posted by: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com (drfred(at)suddenlinkmail.com)>
Kelly;
Dr Fred.
stall the engine.
functioning.
Kelly
Bob Turner
RV-10 QB
le, List Admin.
| [b]
robin(at)PaintTheWeb.com Guest
Posted: Wed Jun 13, 2012 9:10 am Post subject: Mystery Oil Leak (solved) |
I think the key is to cycle the prop gently. I hear pilots in the run up area doing these fast deep cycles and can only wonder how those belts are feeling during the cycle. No need to be so aggressive. A slow cycle or several slow cycles accomplishes the same thing but has to be easier on all the moving parts.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley
Sent: Wednesday, June 13, 2012 9:53 AM
Subject: Re: Re: Mystery Oil Leak (solved)
Roger
flysrv10(at)gmail.com Guest
Posted: Wed Jun 13, 2012 9:29 am Post subject: Mystery Oil Leak (solved) |
I think cycling is done to flush the oil sitting the the prop to reduce sludge but I may be wrong.
Do not archive.
Rob
On Jun 13, 2012, at 8:48 AM, Kelly McMullen wrote:
[quote]--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
stall the engine.
functioning.
Kelly
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
Bob Turner
Posted: Wed Jun 13, 2012 10:41 am Post subject: Re: Mystery Oil Leak (solved) |
To clarify: McCauley suggested the extra prop cycling to try to get the O rings to seat, but they did not suggest deep cycling - just enough to move the O rings a bit.
So far on the 10 I have not had grease issues, and on runup I put the prop back in as soon as I hear any RPM drop. But I just did my first prop maintenance. Hopefully I didn't put in too much grease. I pumped until I saw it exiting out the open hole. It took about what was suggested, as I recall, in terms of the number of pumps on the grease gun.
RV-10 QB |
Kelly McMullen
Posted: Wed Jun 13, 2012 2:04 pm Post subject: Mystery Oil Leak (solved) |
The issue is the forces the pitch change mechanism puts on the prop
and the engine bearings when the engine is not a full power and has no
air moving through it. Similar to a full power run up with twisting
forces added to the prop blades. On a Lycoming flat 4 or 6 cylinder,
cycling the prop only serves one purpose..to show that the pitch
change mechanism is working. Doing that as gently as possible reduces
the forces involved. Checking the mechanism multiple times a day
accomplishes nothing. Checking it first flight of the morning might
add a little confidence, but really isn't necessary. Nothing bad is
going to happen if the prop stays in fine pitch, that you can't
correct once at a safe altitude to return to the field.
On Wed, Jun 13, 2012 at 9:27 AM, Fred Williams, M.D.
<drfred(at)suddenlinkmail.com> wrote:
Kelly;
Dr Fred.
> stall the engine.
> functioning.
> Kelly
>> Bob Turner
>> RV-10 QB
KCHD |
Tim Olson
Posted: Sat Jun 16, 2012 12:06 pm Post subject: Mystery Oil Leak (solved) |
Update: I got the prop back and learned a few things while I talked to
them. First, they do NOT recommend 100 hour greasings. At most you'd
want to do it annually, but then make SURE to stick to the 1oz
recommendation and also use safety wire on the opposite zerk to dig out
any pasted grease so it comes out easily. In fact, there is a saying
that "if it ain't leaking, don't grease it" which makes some sense now
that I've seen a cutaway view. Inside there, you don't have lots of
fast rolling bearings...just bearings that let you rotate the prop. The
grease just lubes that area and keeps it from rusting. So, it's
unlikely to wear out the grease very fast, and if it isn't leaking it's
probably going to last many many years. They feel that although they
wouldn't recommend it, you could run to TBO on the grease that's in
there IF it doesn't leak out. So, don't overgrease for sure...it's not
like wheel bearings that need to be done real often. Also, apparently
the original seals from Hartzell were "quad" (square) seals, and those
leaked a lot. The prop shop actually had some better seals made up at
one time that were round and made of something else. Hartzell also
changed seals and had even worse leak issues. Not all that long ago,
Hartzell finally updated their seals once again to some nice silicone
material that lasts longer and seals better. So if you get new seals
it will likely be better than original if you have the older seals of
other types.
With all of this done, I got the prop on and did a test flight and my
leak problem is definitely gone!
On 6/13/2012 5:03 PM, Kelly McMullen wrote:
> Kelly;
> Thanks
> Dr Fred.
>> stall the engine.
>> functioning.
>> Kelly
>>> Bob Turner
>>> RV-10 QB
>>> Read this topic online here:
dmaib@me.com
Posted: Sat Jun 16, 2012 1:11 pm Post subject: Re: Mystery Oil Leak (solved) |
Tim, that is pretty much exactly what Maxwell Propeller in Minneapolis told me when they overhauled the propeller on my old Bonanza. In fact, that was a Beechcraft propeller (no longer produced) and Maxwell actually took the grease zirks off and plugged them while performing the overhaul, saying there was no need to ever grease the Beechcraft propellers for the reasons you mention. Those old Beechcraft props were excellent. IIRC, there were zero AD's on a propeller that had been in service for several decades. They don't make em like that any more!
RV-10 #40559
Tim Olson
Posted: Sat Jun 16, 2012 1:28 pm Post subject: Mystery Oil Leak (solved) |
Yeah, it was Maxwell that I went to too. They have so many props in the shop that I know I can trust their advice. Good folks. Due to my time pressure, which caused the wrong person to have to calculate my bill, I almost paid double....but I noticed something wrong and they checked it out. Ended up paying $800 but they repainted it too so it looks good and they alodined the wear pits and cleaned them up. I shouldn't have pushed the timeline which would have allowed the normal billing person to do it. I'm just glad it's good to go.
On Jun 16, 2012, at 4:11 PM, "dmaib(at)me.com" <dmaib(at)me.com> wrote:
David Maib
RV-10 #40559
Transition Trainer
http://forums.matronics.com/viewtopic.php?p=375816#375816
Bob Turner
Posted: Sat Jun 16, 2012 3:32 pm Post subject: Re: Mystery Oil Leak (solved) |
Tim, David,
Thanks for posting this useful information. My previous prop was a McCauley on a 182 and it didn't have any zerk fittings, so the Hartzel maintenance instructions seemed like a bit of overkill.
No grease next year unless it's leaking!
Bob
RV-10 QB |
