Family numbers
gus.fraser(at)gs.com
PostPosted: Fri Jan 13, 2006 2:39 pm    Post subject: Family numbers Reply with quote
Craig,
I got bored again so I ran my own numbers. I upload the registration database to my server so I ran this query
SELECT faa_ar.modelname, count(*) as Total
FROM faa_ar, faa_master
WHERE ((faa_ar.mmscode = faa_master.mmscode))
AND((faa_ar.modelname like "YAK%") or
(faa_ar.modelname like "CJ6%") or
(faa_ar.modelname like "CJ-6%") or
(faa_ar.modelname like "SU-%") or
(faa_ar.modelname in� ("E-3","I-3")) or
Group by faa_ar.modelname
Order by faa_ar.modelname
It yielded the following. These figures are valid as of today. I tell you what I will put this query into a web page with a drill down for each group how about that. TJ would you be interested in growth of the stock over time ?
�CJ-6�� 53
�CJ-6A�� 129
�CJ6A (YAK 18A) 4
�E-3�� 5
�I-3�� 2
�SU-1�� 1
�SU-26�� 11
�SU-26M�� 8
�SU-26MX�� 7
�SU-29�� 30
�SU-31�� 10
�SU-31M�� 1
�YAK�� 1
�YAK 11�� 1
�YAK 18�� 6
�YAK 18PS�� 1
�YAK 18T�� 12
�YAK 3 UPW�� 1
�YAK 3UPW�� 1
�YAK 3UR 2000�� 1
�YAK 3UR-2000�� 1
�YAK 50�� 3
�YAK 52�� 175
�YAK C-11�� 1
�YAK-11�� 9
�YAK-11-R2000�� 1
�YAK-12M�� 1
�YAK-18A�� 20
�YAK-3�� 1
�YAK-3M�� 6
�YAK-3U/R-200�� 1
�YAK-3UA�� 2
�YAK-40�� 1
�YAK-50�� 33
�YAK-52�� 53
�YAK-52TW�� 29
�YAK-52W�� 14
�YAK-53�� 1
�YAK-54�� 4
�YAK-55�� 5
�YAK-55M�� 69
�YAK-9U-M�� 7
�YAKOLEV YAK 11�� 1
�YAKOVLEV�� 1
�YAKOVLEV 52 S�� 2
Gus
"Craig Payne" <cpayne(at)joimail.com> Subject:� Re: Family Numbers Date:� Dec 19, 2005
Correction! I did some more searching on Yaks. You sneaky guys use different A/C
codes for the Yak-52 as well as variations on "Aerostar".
Add:
SC Aerostar Yak-52TW���� 1 (Oh..that Dalton guy)
Aerostar Yak-52��������������� 38 (+10 that I listed from another Aerostar code)
Aerostar Yak-52TW�������� 28
Total Yak-52's of various flavors 175 + 67 = 242
Total Yak's of the M-14 variety��������������������� = 378
Craig Payne
End Msg:� #34�
PostPosted: Fri Jan 13, 2006 3:37 pm    Post subject: Family numbers Reply with quote
Gus
I followed up with a world-wide survey for CJ's and Yaks of the 620 cu in. variety. I combined those into tables and wrote an article for the RPA Newsletter. Just submitted a few days ago. Your search includes lots of A/C that I didn't include but� neglects other aircraft codes that the same kind of airplane may have been certified as. Some folks added their own names to the type so it may not show up unless you used a UNIX expression/script to cover lots of variations.
Craig Payne
