		tombaisley
				 Posted: Thu Jun 21, 2012 3:26 am    Post subject: rotax 447 propeller recomendation high temps |
				I have a FS1 w/ 447 2.58 box,  spinning a 66" two blade IVO. I am have trouble with high EGT and CHT.
    With the propeller pitched to give me 6200rpm at climb out ,I'm seeing EGT in the 1100-1150 at 5700rpm which seems to cause the CHT to start climbing thru 400F.  If I increase the prop pitch to 6000 rpm at climb out my EGT are stable at 1050 or so, but I'm still seeing CHT of 390-410F.
     I also have high EGT ( 1150 - 1230 ) in the 3900-4600rpm range, I suspect that may just be the nature of the beast.
     I spoke with IVO prop and his recommendation was "more pitch", But that seems to aggravate the CHT.
     I'm starting to wonder if I'm over propped and should maybe cut down the diameter or go to a three blade prop?
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Richard Pike
				 Posted: Thu Jun 21, 2012 5:05 am    Post subject: Re: rotax 447 propeller recomendation high temps |
				You are running stock jets and have pressure/vacuum tested your engine I assume? Do you have an intake silencer? Because it will cause you to lose a hair of power, and IMO you can't afford to lose any power, because you already have too much prop.
 Back in the day when I had a 532 on the MKIII,  IVO started me out with a 3 blade 64" - that was way too much prop for that engine, took one blade off and it was a sweetheart. Then I put a 2 blade 66" on it and that was good too. If I remember correctly (HAH) my buddies ran 3 blade 62" Warp Drives on their 503's. I am running a 68" 2 blade IVO on my 582, and you are trying to run almost as much prop on a much smaller engine, so I would say you are way overloaded on prop.
 This might be comparing apples to oranges, but at the Powerfin prop selection page http://www.powerfin.com/eng_Rotax.htm  they show either a 2 blade 61" or a 2 blade 64" prop for your engine.
 If I were you - before I spent any money on another prop, I would start by shortening your current blades a bit at a time and see what happens. I suspect that when you get down around 62"  - 64" you will find things to be OK assuming that all else with your engine is as it should be.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
				 Posted: Thu Jun 21, 2012 5:27 am    Post subject: rotax 447 propeller recomendation high temps |
				---- tombaisley <tombaisley(at)yahoo.com> wrote:
  	  | Quote: | 	 		       I'm starting to wonder if I'm over propped and should maybe cut down the diameter or go to a three blade prop?
 Tom B/Folks:
 I prop a Kolb by flying straight and level, wide open throttle.  A correctly propped engine should turn the max continuous red line.  This will give best cruise and climb performance with a fixed or ground adjustable prop.
 I flew a 60X30 Culver two blade fixed pitch prop on my original Firestar and 447.  This gave me 6500 rpm straight and level, WOT.
 Burns Junction, OR
  _________________ John Hauck
Titus, Alabama |
		beauford
				 Posted: Thu Jun 21, 2012 5:50 am    Post subject: rotax 447 propeller recomendation high temps |
 Brother Baisley:
 I run exactly the same 447/gearbox/prop combination as you, sir...
 My prop is loaded to yield exactly the same rpm on climb out as yours...
 My EGT/CHT temps mirror yours exactly....
 I have, after much carburetor twiddling, fan fumbling, prop pitch changes, a
 thermocouple replacement festival,
 and several sessions of peering and poking at rings through exhaust ports,
 finally come to the
 conclusion that the little Nazi S.O.B. just likes to run hot.   I don't
 know, but strongly suspect, that
 performing a carbon-fiber circumcision on your IVO won't solve the problem;
 that is just
 another way to reduce prop loading and the effects of that upon the EGT/CHT
 balance is already
 known and understood.  Am pretty sure there is no free thermal lunch hiding
 in there anywhere.
 I place the issue of chronic 447 overheating in the same category of
 intractable problems as matrimony,
 stagflation and oversize prostates.  They are built into the bedrock of the
 universe and we might as
 well get used to 'em...
 Accordingly, I have perfected and adopted the Beaufordian school of 447
 operational philosophy... i.e.
 run the chrome-plated hell out of the damn thing and don't worry about it.
 It works fer me...   may not
 work fer you...   I think of it as rather like Dr. Stangelove's approach...
 Quit worrying about the Bomb and
 learn to love it.
 Worth what ye paid fer it...
 Overheated beauford
 FF-076
 Brandon, FL
 p.s.  Brother B:  Should you come across the 447 holy grail and figure out
 how to make it run cooler,
 please write home and share it without delay...
 b.
		tombaisley
				 Posted: Thu Jun 21, 2012 5:52 am    Post subject: Re: rotax 447 propeller recomendation high temps |
				I'm running stock jets, needle, and clip position. No intake silencer, stock exhaust. I replaced the head, base, intake, and exhaust gaskets. I had found that the spark plugs were cross threaded and not sealing. I have not pressure tested, but this engine is very fresh <100hours.
   Travis (at) Kolb recomends 60" three blade IVO, My friend at the field has a FSII w/503 spinning at 62" IVO, runs like a top. I would like to stay with a two blade, I think I will start trimming 1" at a time to see what happens.
		Richard Pike
				 Posted: Fri Jun 22, 2012 6:47 am    Post subject: Re: rotax 447 propeller recomendation high temps |
				Called a friend of mine yesterday who has a Flightstar with a 447 on it, and he said the only way he got it to behave and run cool was to install a Dial-A-Jet on it, and run a cable to the cockpit.
Kingsport, TN 3TN0
		beauford
				 Posted: Fri Jun 22, 2012 7:48 am    Post subject: rotax 447 propeller recomendation high temps |
 Brother Pike:
 That is interesting...  Thought those things were just for snowmobiles.
 Do you have any information about how many hours he has run
 it and whether he has had any carbon build-up problems with it?
 The way I understand the DAJ set-up is that the engine is baseline jetted to
 run on the
 lean side and the DAJ then dumps extra fuel into the carb as required to
 compensate for the lean condition, temperature, altitude, etc.
 I know that enriching the mixture will make it run cooler, but I also have
 vivid recollections of the carbon problems which stuck the rings on my
 toy once before.  Am a little bit carbon-shy, but very interested in what
 your friend has done and how long he has been using the gizmo...
 Thankee for the reply, sir...
 Wary eye on the Gulf  beauford
 FF-076
 Brandon, FL
				 Posted: Fri Jun 22, 2012 8:00 am    Post subject: rotax 447 propeller recomendation high temps |
  Richard Pike
 Kolbers:
 I realize this is ancient history, but it is all the personal info I have with the 447, which I put 755.0 hours on two of them from 1987 to 1990 in my original Firestar.
 Through experience I learned to leave the engine exactly like it came from the factory.  What worked for me was to adjust the prop pitch so the engine would barely touch the red line for max continuous rpm, which I think was 6,500 rpm.  When I did this the EGT/CHT operated in the Green.
 I found it very easy to chase one's tail trying to "tune" a 447.  I believe the 447 was set up at the factory to operate in a 70F day from 0 to 1,500 feet ASL.
 With the engine remaining at factory tune, I was able to climb to 10,000 feet ASL.
 Rock House, Burns Junction, OR
Titus, Alabama |
				 Posted: Fri Jun 22, 2012 8:14 am    Post subject: rotax 447 propeller recomendation high temps |
				 	  | Quote: | 	 		   I know that enriching the mixture will make it run cooler, but I also have
  toy once before.
 Kolbers:
 I had good luck with the old point ignition, single carb 447, other than the normal operating problems of failed wrist pin bearings (which were later improved), loose coils, and difficulty keeping the points in adjustment caused by normal wear (which were upgraded to CDI ing).
 Have always been an advocate of not babying two stroke engines and operating at recommended cruise rpm which is 5,800 rpm, if I remember correctly.  I didn't say abuse two stroke engines, but make them work to keep crank cases clear of excess oil and reduce carbon buildup in the upper end.
 I found there are a lot of "little things" that can affect the operation and reliability of a two stroke, many not logical or readily understandable.
 Having the opportunity to fly with a 4 stroke since 1994, I have a much better reliablity record.  No engine failures in more than 3,000.0 hours.
 Burns Junction, OR
Titus, Alabama |
		rickofudall
				 Posted: Fri Jun 22, 2012 9:14 am    Post subject: rotax 447 propeller recomendation high temps |
				Roger Lee, Rotax guru on their Matronics list has maintained that the biggest problem with Rotax engines is their owners. I've set up a few new 447's now and they run great right out of the box WHEN you set up the prop per Rotax instructions, which as John H said is to just get the prop to touch max RPM in level flight. For the 447 this is 6800 rpm and setting it for about 6400 to 6500 static will get you right there. The only, and I honestly think only two adjustments that need to made to a new 447 are fan belt tension, and, depending on your field elevation, the clip on the needle. Once the break in is accomplished, the fan belt is adjusted and the clip is reset, if needed, they run perfectly. The last one I did was on a Northwing trike. I finished the break in just after sun down and didn't get started to test fly until about 2:00 pm the next day. The temps were already in the high 100's headed for 112 that day, iirc, and the little Maverick trike broke ground in about 200 and I had pattern altitude long before I was abreast of my back yard (2300 feet from the departure end of 17). You have a little leeway in the prop adjustment to find the sweet spot for CHT and EGT. If you CHT's are on the hot side decrease the prop pitch and it should drop a bit. It it's the EGT's that are troublesome, add pitch.
  Pretty much what is in the Installation manual, and it seems to work just fine.
 Rick Girard
 On Fri, Jun 22, 2012 at 11:13 AM,  <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
   	  | Quote: | 	 		  --> Kolb-List message posted by: <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
  > toy once before.
  	  | Quote: | 	 		   Wary eye on the Gulf  beauford
 Kolbers:
  Burns Junction, OR
  http://forums.matronics.com
  le, List Admin.
 Zulu Delta
 Mk IIIC
 Thanks, Homer GBYM
    - Groucho Marx
		herbgh(at)nctc.com Guest
				 Posted: Fri Jun 22, 2012 11:49 am    Post subject: rotax 447 propeller recomendation high temps |
				and don't forget to re torque the heads ....after 1 hour...Herb
  At 12:13 PM 6/22/2012, you wrote:
  [quote]Roger Lee, Rotax guru on their Matronics list has maintained that the biggest problem with Rotax engines is their owners. I've set up a few new 447's now and they run great right out of the box WHEN you set up the prop per Rotax instructions, which as John H said is to just get the prop to touch max RPM in level flight. For the 447 this is 6800 rpm and setting it for about 6400 to 6500 static will get you right there. The only, and I honestly think only two adjustments that need to made to a new 447 are fan belt tension, and, depending on your field elevation, the clip on the needle. Once the break in is accomplished, the fan belt is adjusted and the clip is reset, if needed, they run perfectly. The last one I did was on a Northwing trike. I finished the break in just after sun down and didn't get started to test fly until about 2:00 pm the next day. The temps were already in the high 100's headed for 112 that day, iirc, and the little Maverick trike broke ground in about 200 and I had pattern altitude long before I was abreast of my back yard (2300 feet from the departure end of 17).
  Rick Girard
   > toy once before.
   Kolbers:
   Burns Junction, OR
   le, List Admin.
  Zulu Delta
  Mk IIIC
  Thanks, Homer GBYM
    - Groucho Marx
		beauford
				 Posted: Fri Jun 22, 2012 12:56 pm    Post subject: rotax 447 propeller recomendation high temps |
				Rick and John:
 Many thanks for your inputs, Gents…   My 447 has the original factory jetting and needle is currently in second notch…  The IVO turns 6050 static, 6250 in climb and 6550 WOT level…   If I leave it at WOT in climb for more than a minute, the CHT will go to and through redlines.
 At 5800 cruise I am seeing 390 to 400 CHT and EGTs of 1080 and 1140 for the two cylinders.  The plugs have a nice tan color, so I think
 the jetting is OK.  The crankshaft seals are new, as are the intake and exhaust gaskets…. I do not suspect leaks.
 Based on Rick’s input, on the first dry day I will unload the prop to get 6400 static and pull the needle up to see if the EGT’s will stay under control.
 If you never hear from me again, you may assume this did not pan out…   monitor the FL obits…
 Soggy beauford
 FF-076
 Brandon, FL
 P.S.  I agree with guru Roger Lee…   (see below).
 From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Richard Girard
 Subject: Re: Re: rotax 447 propeller recomendation high temps
 Rick Girard
		Richard Pike
				 Posted: Fri Jun 22, 2012 4:30 pm    Post subject: Re: rotax 447 propeller recomendation high temps |
				My personal experience is that if I set the prop to just bump redline in straight and level, then the EGT  tends to be a bit uncooperative, but that could be the difference between the IVO and the Warp. Probably the Warp and the IVO respond differently. So I set the IVO to fall about 150-200 rpm shy of redline in level flight, and then my EGT stays constant at all rpm's.
 Your results may vary, that is why they are called Experimental aircraft...
Kingsport, TN 3TN0
				 Posted: Fri Jun 22, 2012 5:35 pm    Post subject: rotax 447 propeller recomendation high temps |
				 	  | Quote: | 	 		   My personal experience is that if I set the prop to just bump redline in straight and level, then the EGT  tends to be a bit uncooperative, but that could be the difference between the IVO and the Warp. Probably the Warp and the IVO respond differently.
  Richard Pike
 Richard P/Folks:
 Works for me with Culver two blade wooden prop.
 Never flew the 447 with any other.
 I still prop all my engines the same way, two or four stroke, for best performance for me.
 john
Titus, Alabama |
		tombaisley
				 Posted: Fri Jun 22, 2012 6:09 pm    Post subject: Re: rotax 447 propeller recomendation high temps |
				I have had much success after trimming my prop from 66" to 62". My CHT are under 400f and my EGT are 1060f (at) 5700rpm. For the must part my egt are <1100 with only a hot spot around 4100-4500rpm which I avoid during decent
  I'm so pleased with the way the engine is running, I'm done fiddling and just flying. All that is left to do is check the plugs in a couple of hours.
