				 Posted: Sat Jun 30, 2012 1:19 pm    Post subject: IO-540 crankcase breather |
				All,
 I was going to use the same crankcase breather oil separator that I have on the 8A http://www.aircraftspruce.com/catalog/eppages/hboilbreather.php
 but then I noted the IO-540 has a huge crankcase breather fitting for a 1” inside diameter hose.  The above separator uses 5/8” hose.
 This separator works well on the IO-360 in the 8A.  Is anyone using this on a IO-540?  Does the IO-540 really need a 1” breather hose?
 Carl
		flysrv10(at)gmail.com Guest
				 Posted: Sun Jul 01, 2012 5:59 am    Post subject: IO-540 crankcase breather |
				Mine really does not leak without a separator. My overflow tube is right above the exhaust pipe.
 Also, there are debates regarding putting the oil byproducts in the breather back into the engine.
 Do not archive.
 Rob Kermanj
 Sent from my iPad
 On Jun 30, 2012, at 5:18 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
 [quote]  <![endif]-->   <![endif]-->
 All,
 Carl
 ://www.matronics.com/Navigator?RV10-List
 cs.com
 matronics.com/contribution
				 Posted: Sun Jul 01, 2012 6:33 am    Post subject: IO-540 crankcase breather |
				This company’s product came recommended on the Lycoming list and is discussed on VAF:  http://antisplataero.com/
 I have an email into them on price for the IO-540 version.
 One point to clarify; as I did on the 8A the oil from the separator will be collected in a small can (~6oz), not returned to the engine.  On the 8A, I empty the can every oil change and never had more than a couple of ounces in it – but a couple of ounces less on the belly.
 Carl
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
 Sent: Sunday, July 01, 2012 10:06 AM
 Subject: Re: IO-540 crankcase breather
 Do not archive.
 Rob Kermanj
 Sent from my iPad
 All,
 Carl 	  | Quote: | 	 		  |   ===================================://www.matronics.com/Navigator?RV10-List===================================cs.com===================================matronics.com/contribution===================================  |
   | 	  0123456789 	  | Quote: | 	 		  | =================================== | 	  0 	  | Quote: | 	 		  | =================================== | 	  1 	  | Quote: | 	 		  | =================================== | 	  2 	  | Quote: | 	 		  | =================================== | 	  3 	  | Quote: | 	 		  | =================================== | 	  4 	  | Quote: | 	 		  | =================================== | 	  5 	  | Quote: | 	 		  | =================================== | 	  6 	  | Quote: | 	 		  | =================================== | 	  7
		Kelly McMullen
				 Posted: Sun Jul 01, 2012 6:43 am    Post subject: IO-540 crankcase breather |
				Yes, the debates with no data. Everything that comes out the breather started in the engine and will be in just as high concentration there. Folks get confused, thinking the separator somehow concentrates contaminates, or condenses water vapor.
 On Sun, Jul 1, 2012 at 7:06 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
		rv10rob(at)gmail.com Guest
				 Posted: Sun Jul 01, 2012 10:22 am    Post subject: IO-540 crankcase breather |
				I don't get any noceable oil out the breather, either. I run about 8 qts as indicated on the dipstick.
  On Sun, Jul 1, 2012 at 7:43 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
   	  | Quote: | 	 		  Yes, the debates with no data. Everything that comes out the breather started in the engine and will be in just as high concentration there. Folks get confused, thinking the separator somehow concentrates contaminates, or condenses water vapor.
 ttp://forums.matronics.com
  Rob Kochman
 RV-10 Flying since March 2011
  Woodinville, WA
  http://kochman.net/N819K
				 Posted: Sun Jul 01, 2012 3:34 pm    Post subject: IO-540 crankcase breather |
				I did say that there is a debate
 On Sun, Jul 1, 2012 at 2:21 PM, Rob Kochman <rv10rob(at)gmail.com> wrote:
  	  | Quote: | 	 		   I don't get any noceable oil out the breather, either.  I run about 8 qts as
 > _blank">http://www.matronics.com/contribution
  Rob Kochman
  Woodinville, WA
 Rob Kermanj
				 Posted: Sun Jul 01, 2012 6:42 pm    Post subject: IO-540 crankcase breather |
				I just have the standard breather that exits over the exhaust pipe.  I add a quart when it gets to 8.  I clean the belly two or three times a year, which takes about 15 minutes.
 I get a drip on the floor if it doesn't fly for a couple weeks--never any more than that.
   Dave Saylor
 [url=tel:831-750-0284]831-750-0284[/url] CL
  1087 hours
 On Sun, Jul 1, 2012 at 11:21 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
 [quote]   I don't get any noceable oil out the breather, either.  I run about 8 qts as indicated on the dipstick.
  Rob Kochman
  Woodinville, WA
  | 	  [b]
		nukeflyboy
  Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
				 Posted: Tue Jul 03, 2012 1:16 pm    Post subject: Re: IO-540 crankcase breather |
				I was consistently getting 2-3 drops of oil on the hanger floor where it ran down from the breather tube to the exhaust pipe.  I installed Van's breather (slime fighter I think) and it has stopped it completely.
  _________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
