Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Mon Jul 02, 2012 9:47 am Post subject: Logging Engine Hours |
Hello ALL.
I am a new member to the Forum, My name is Alan and i live in England in the County of Kent, my nearest Airfield is Headcorn which has a grass runway.
I am not a builder but a retired pilot now 66 so decided to spend every penny on a new car and an aeroplane before the Tax man takes it to pay for my Old Folks Home, so i have my first aircraft G-PEGY Mono to Tri Conversion.
My Question , G-PEGY has a FLYdat which start timing after the first impulse .
This has been recorded in the log book, the aircraft has 330 Airframe and 408 hours on the engine,
All the flying i have done in the past i have reduced the Tacko reading by 10 mins which has been standard practice,
Rotax are logging all engine run time. Is this right ?
Many thanks
Alan
trevpond(at)aol.com Guest
Posted: Mon Jul 02, 2012 10:17 am Post subject: Logging Engine Hours |
Yes Alan, you are quite correct, Flydat records all engine running time.
Trev
GLINN
Sent from my iPad
On 2 Jul 2012, at 18:47, "Alan Carter" <alancarteresq(at)onetel.net> wrote:
Hello ALL.
Many thanks
Alan
http://forums.matronics.com/viewtopic.php?p=377094#377094
Alan Carter
Posted: Mon Jul 02, 2012 1:38 pm Post subject: Re: Logging Engine Hours |
Hi Trev and All.
OK Flydat records ALL, At the beginning of the log book they have taken off 10 min per flight, then there is a jump from say 45 hrs to 65 hrs this is when the FLYdat was installed and a correction made so the FLYdat has taken into account the earlier flights adding back the 10 mins so now has the correct number in total.
So on a Europa just what times should be recorded in the log books,?
Airframe, Flight time only ?
Engine, Start till Stop?
Propeller, ??????
Alan
