		Michel
				 Posted: Tue May 30, 2006 1:31 pm    Post subject: West System Epoxy answer |
				Friends, here is the answer from West System Epoxy:
 Methyl tertiary butyle ether, a gasoline additive and ethanol will
 disolve cured WEST SYSTEM epoxy.  We had great success builting fuel
 tanks with WEST SYSTEM until these were introduced.  We are
 investigating som ethanol-resistant coatings, but the testing is still
 being conducted.
 Its a real problem as not only does the ethanol damage composite tanks
 but on older engines damages hoses, gaskets and can built up a varnish
 that can bind compoents resulting in bent push rods etc.
 So, I guess this closes the discussion but ... makes us even more
 worried, doesn't it?
 Cheers,
 Michel
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dosmythe(at)cox.net Guest
				 Posted: Tue May 30, 2006 2:52 pm    Post subject: West System Epoxy answer |
				Michel,
 I guess you ruined my day.  Ethanol is coming to my area real fast.  I have
 heard that the super premium fuel will not contain Ethanol??  My West coated
 tanks might be toast.  Thank you Government, I'm so upset I might just
 refuse my next retirement check from them suckers.
 Don Smythe
		darinh
				 Posted: Tue May 30, 2006 3:23 pm    Post subject: Re: West System Epoxy answer |
				Anyone looked into the cost to have an aluminum tank fabricated?  I don't know the feasability of this but it done in many other aircraft.
 Darin
		wingsdown(at)comcast.net Guest
				 Posted: Tue May 30, 2006 3:34 pm    Post subject: West System Epoxy answer |
				There has been discussion before. I believe SS stated wing flex as an
 issue. I am sure that could be over come, maybe not cheap, but better
 yet why not a fuel bladder for safety sake?
 Rick
		roncarolnikko(at)hotmail. Guest
				 Posted: Tue May 30, 2006 9:19 pm    Post subject: West System Epoxy answer |
				There was a fellow in Klammath falls Oregon who made Poly tanks for the
 undercambered wings. It was a limited run and may be gone now.  No one was
 interested at the time. Bet they would sell now.   I may still have his
 number.   Ron NB Ore
 [quote]From: "wingsdown" <wingsdown(at)comcast.net>
 Subject: RE: Re: West System Epoxy answer
 Date: Tue, 30 May 2006 16:33:31 -0700
 Rick
		janderson412(at)hotmail.c Guest
				 Posted: Wed May 31, 2006 12:02 am    Post subject: West System Epoxy answer |
				Most aircraft wings flex or (helicopter) vibrate so plastic or  rubber are
 the way to go.~j~
 Rick
				 Posted: Wed May 31, 2006 3:50 am    Post subject: West System Epoxy answer |
				I think finding an alternate material is much better than relying on
 coatings and sloshes. However retrofitting a new tank into a completed
 aircraft is a pretty big job and messy.  Another possible option is to use
 our existing tanks with a rubber (whatever) bladder.  One might be able to
 cut a hole in top of the existing tank (say, 1'X1') to gain access and
 remove all the existing baffles.  Use the same hole to install a bladder.
 Finish up with a new cover screwed on top to hide the hole.  Just a wild
 thought without much thinking?  This might be the best, least expensive,
 easiest, modification.
     Are there any bladder companies that can make custom fit products?
 Don Smythe
		mdps_mc(at)swoca.net Guest
				 Posted: Wed May 31, 2006 6:43 am    Post subject: West System Epoxy answer |
				I was wondering why someone hasn't made a tank out of the same material that
 the red plastic gas cans are made from.  I have a number of these plastic
 cans at home and they seem to last forever.
 I know there isn't a large market for tanks that fit in a Kitfox but a
 generic cylinder shaped tank could fit in just about any wing.
 Mike Chaney
		blackcatmoan(at)hotmail.c Guest
				 Posted: Wed May 31, 2006 7:48 am    Post subject: West System Epoxy answer |
				Mike:
 Smartest thing I've heard all week.
 Sounds like the 'makings' of a small business...
 Cheers,
 Tony.
 that
 Mike Chaney
		darinh
				 Posted: Wed May 31, 2006 8:53 am    Post subject: Re: West System Epoxy answer |
				Ok guys,  I am building my Fox now and have yet to install the tanks.  I would like to solve the problem of ethynol and the stock tanks before I build the wing obviously.  Short of dropping the $10k or more to fabricate a prototype tank from HDLPE or other compatible material, what is the best alternative?  We have not been hit by the ethynol bug yet but I am sure it is coming and would like to be ready when it comes.
 On the other hand, as one lister wrote...this may be a good opportunity for a small business, especially if one were to work a deal with John McBean and provide OEM tanks for the new Kitfox...sounds interesting.
		bmwebb(at)cox.net Guest
				 Posted: Wed May 31, 2006 1:40 pm    Post subject: West System Epoxy answer |
				Amen. Except don't limit us to the wings. I've considered a single fuselage
 tank for a while now. Plenty of room behind the seat, and in the "baggage"
 area. The feed problems of the wing tanks would disappear.
 The only bad side is that I'm fundamentally opposed to fuel in the cabin. I
 discounted the Mustang II long ago for this reason. But since in the Kitfox
 you hit things at 30, as opposed to 70mph, it may be mitigated.
 Wing folding and transportation becomes a non-issue, as well.
 Put me in for one M2 fuselage tank, 15-20 gallon, please.
 Bradley
				 Posted: Wed May 31, 2006 1:57 pm    Post subject: West System Epoxy answer |
				Bradley Walmart has some nice boat tanks for that.  Ron NB Ore
 [quote]From: "Bradley M Webb" <bmwebb(at)cox.net>
 Date: Wed, 31 May 2006 17:39:01 -0400
 Bradley
				 Posted: Wed May 31, 2006 2:29 pm    Post subject: West System Epoxy answer |
				Oh No! I won't have anything so...so...GOUCH in my airplane!
		AMuller589(at)aol.com Guest
				 Posted: Wed May 31, 2006 2:34 pm    Post subject: West System Epoxy answer |
				Also Remember fuel in the cabin increases the wing loads more than fuel in
 the wings. The design gross weight moments were derived based on wing tanks  to
 reduce the wing bending loads. Not terribly significant unless you are flying
  at high gross weights in air gusts greater than CAA (way back
 when).standards.
				 Posted: Wed May 31, 2006 2:49 pm    Post subject: West System Epoxy answer |
				Ya also weights and balance would be a pain to behind the seat.
 Date: Wed, 31 May 2006 18:28:08 -0400
				 Posted: Wed May 31, 2006 3:19 pm    Post subject: West System Epoxy answer |
				Fues tank  Well, if you are going to do that, take a
 look at the tanks in JEGS or other racing catalogs.
 They are foam filled for crash protection and come in
 various sizes to fit your needs.  Dealing with how to
 hook up the filler might slow you down a bit, but
 otherwise a safer tank than any we have now.
 Kurt S.  S-5
 --- Bradley M Webb <bmwebb(at)cox.net> wrote:
  	  | Quote: | 	 		   Amen. Except don't limit us to the wings. I've
  considered a single fuselage tank for a while now.
		bnn(at)nethere.com Guest
				 Posted: Fri Jun 02, 2006 7:23 pm    Post subject: West System Epoxy answer |
				At 09:53 AM 5/31/2006, you wrote:
  	  | Quote: | 	 		  Short of dropping the $10k or more to fabricate a prototype tank from
 I vote:
 1) properly designed and fabricated aluminum tanks.
 2) Properly designed and fabricated vinyl-ester tanks.
 Guy Buchanan
 K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
				 Posted: Sat Jun 03, 2006 4:42 am    Post subject: West System Epoxy answer |
				Guy,
 I just finished replacing the 2" tapes on my wing tops.  It wasn't fun and
 never turns our as good as the first cover job.  Replacing a tank could only
 be worse.  I would like to see a bladder replacement come on the market.  We
 have an old bladder in the hanger that came out of the Rich man's twin
 Comanche that's 35 years old (finally leaked).  New replacement was around
 $700.  Maybe we could have some made for way less than Piper's cost.  This
 might be a good project for Kitfox LLC to take on in their spare time.
 Ha....
 Don Smythe
  	  | Quote: | 	 		   I vote:
  Guy Buchanan
		Jim Shumaker
				 Posted: Sat Jun 03, 2006 6:18 am    Post subject: West System Epoxy answer |
				Don,
   I was at an EAA fly-in where a tank bladder dealer was showing.  The cost was about as for the Comanche or less and I may need to use that approach for my Aluminum tank that needs repair.
   Will keep you posted.
   Jim Shumaker
 Don Smythe <dosmythe(at)cox.net> wrote:
 Guy,
 Ha....
 Don Smythe
  	  | Quote: | 	 		   I vote:
  Guy Buchanan
  _________________ Jim Shumaker |
				 Posted: Sat Jun 03, 2006 11:18 am    Post subject: West System Epoxy answer |
				At 05:41 AM 6/3/2006, you wrote:
  	  | Quote: | 	 		  I would like to see a bladder replacement come on the market.
 I don't know how you could do it with the baffles in the fiberglass tank. I
 suppose you could rip out the baffles, but my arms just aren't long or
 skinny enough to get in an sand out the rough edges.
 Guy Buchanan
