william(at)wbliss.co.uk Guest
Posted: Tue Jul 10, 2012 1:00 pm Post subject: Rotax 912ULS and VP prop required |
Dear all
Thanks for useful info about fuel smell and landing distance.
The next question relates to changing the Europa Classic engine from
Rotax 912UL to Rotax 912ULS. It is currently fitted with Warpdrive
ground adjustable 3 blade prop. Can the same prop be used with the
912ULS? Is there a noticable improvement in take-off and landing
performance with this combination. What about the Airmaster prop
conversion to VP using the existing blades?
I have placed a wanted ad on AFORS
William Bliss
rlborger(at)mac.com Guest
Posted: Tue Jul 10, 2012 7:25 pm Post subject: Rotax 912ULS and VP prop required |
William,
I can't comment directly on the 912ULS, but my 914 is a noticeably better performer with the Airmaster C/S prop. I installed a ground adjustable Warp Drive prop for a couple flights. It worked well enough but not like the Airmaster. It was set up for takeoff performance (maybe a bit under-pitched even). Acceleration, takeoff distance and initial climb were comparable to the Airmaster. But cruise speed was only about 115-120 kts. The Airmaster would get me about 140 kts cruise. With the G/A prop you get either good takeoff performance and loose speed and economy or good speed and economy with less takeoff performance. Or you can go compromise. But you can't get the best takeoff AND cruise performance as you can with a C/S prop. But the C/S prop is heavier, more complex and a lot more expensive. So, you pays your money and takes your chances.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jul 10, 2012, at 3:59 PM, William Bliss wrote:
Dear all
The next question relates to changing the Europa Classic engine from Rotax 912UL to Rotax 912ULS. It is currently fitted with Warpdrive ground adjustable 3 blade prop. Can the same prop be used with the 912ULS? Is there a noticable improvement in take-off and landing performance with this combination. What about the Airmaster prop conversion to VP using the existing blades?
William Bliss
