CBarber
Posted: Tue Jul 10, 2012 11:43 am Post subject: Ground jumping on Z-14 |
Sorry if this is too basic but I am wondering about being able to jump start my Velocity. I am looking at adding one of the sockets available with plug the standard cables hook to. it is only two screws, but it is a pain to remove them to gain access to my battery. Now that I have flown (as of June 9, 2012) I have noted on one occasion that I left my EFIS on too long and drained the batteries....actually my secondary battery, and the system really did not like it. The secondary low voltage light screaming....uh, blinking at me was quite bothersome. Once charged up again, it seemed happy.
My question. If I am wiring in one of these sockets do I wire to just one battery or to both to allow charging of both at the same time or would this not be the way it worked. Or, wire it to one battery and turn on the crossover switch to allow charging of both. Currently I will hook my charger to one of the other battery and charge them individually should the need develop. Other than me leaving the EFIS on this has not been an issue as of late since I got past some proof of concept wire and engine experimentation.
This all may be overkill now that it seems my stuff is working pretty well and the screws are not that big a deal, but I am curious.
Chris Barber
Houston
Velocity N17010
Rotary 13b turbo
_________________ Christopher Barber
Velocity SE/Rotary 13B
Houston |
Posted: Tue Jul 10, 2012 11:57 am Post subject: Ground jumping on Z-14 |
Chris,
Is there AC mains power in your hangar? How about a 3 or
4 pin plug that wires TWO maintainers to your ship's batteries
when plugged in. These are low cost, accurate chargers that
would be isolated from each other during charging/maintaining
the batteries.
I would be helpful to know what architecture you are using
for a dual battery setup. What are your plan-b procedures
for continued flight with a failed alternator? You menion
Z-14 . . . do you have dual alternators on the Rotary engine?
How did you happen to run down both batteries having left
one accessory turned on? If the smaller alternator is having
trouble charging the battery while running accessories on
its bus, you can close the cross-feed contactor and use the
main alternator to get both batteries topped off.
Posted: Tue Jul 10, 2012 1:04 pm Post subject: Ground jumping on Z-14 |
I missed this . . . if you want to actually crank the
engine using ground power, you'll need a robust connector
capable of carrying the current. You only need to connect
it to the main battery in Z-14 . . . the aux battery gets
connected too by closing the battery master switches and
cross-feed contactors.
CBarber
Posted: Wed Jul 11, 2012 5:04 am Post subject: Ground jumping on Z-14 |
Thanks Bob,
That is basically what I wanted verified.
All the best,
Chris Barber
Houston
Velocity 17010
"Only 38.9 more hours in Phase One Testing"
________________________________________
From: owner-aeroelectric-list-server(at)matronics.com [owner-aeroelectric-list-server(at)matronics.com] on behalf of Robert L. Nuckolls, III [nuckolls.bob(at)aeroelectric.com]
Sent: Tuesday, July 10, 2012 4:04 PM
Subject: Re: Ground jumping on Z-14
Houston |
