Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
jrlark
Posted: Tue Jul 10, 2012 8:20 am Post subject: Flap Positioner |
Hi Guys
About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo email account was hijacked, I lost that photo. A search of the archives only turned up a discussion, no photo. Anyone have that photo handy?
Thx, Rick
#40956
Southampton, Ont
bwestfall
Posted: Tue Jul 10, 2012 8:34 am Post subject: Flap Positioner |
Here are some I’ve found searching through my outlook folder…
http://forums.matronics.com/files/img_1417_171.jpg
http://forums.matronics.com/files/flap_and_aoa_switch_151.jpg
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark
Sent: Tuesday, July 10, 2012 9:19 AM
Subject: Flap Positioner
Hi Guys
Thx, Rick
#40956
Southampton, Ont
n223rv(at)wolflakeairport Guest
Posted: Tue Jul 10, 2012 8:39 am Post subject: Flap Positioner |
That may have been mine. Here is a link to the picture.
http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg
-Mike Kraus
RV-10 Flying
On Jul 10, 2012, at 12:19 PM, "Rick Lark" <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
[quote] Hi Guys
Thx, Rick
#40956
Southampton, Ont
Posted: Tue Jul 10, 2012 8:44 am Post subject: Flap Positioner |
I found a pic in the advanced flight systems manual which showed essentially how I did it.
amekler
Posted: Tue Jul 10, 2012 8:55 am Post subject: Flap Positioner |
I also used this but be aware the movement us not linear also don't overextend the POS or it will break.
Alan
On Jul 10, 2012, at 12:38 PM, Michael Kraus <n223rv(at)wolflakeairport.net (n223rv(at)wolflakeairport.net)> wrote:
[quote]That may have been mine. Here is a link to the picture.
-Mike Kraus
RV-10 Flying
| Quote: | Hi Guys
Thx, Rick
#40956
Southampton, Ont
Gordon Anderson
Posted: Tue Jul 10, 2012 12:39 pm Post subject: Flap Positioner |
It's a lovely installation so I copied it too. Just beware that if you squeeze the two rivets holding the sensor to the aluminum plate as much as "normal" you will split the sensor flanges, so go easy. Using screws and nuts is probably more clever.
Gordon
41015 Switzerland
On Jul 10, 2012, at 6:34 PM, Ben Westfall wrote:
jrlark
Posted: Tue Jul 10, 2012 12:47 pm Post subject: flap positioner |
That's the setup. Excellent. Thx guys,
Rick
Bob Turner
Joined: 03 Jan 2009 Posts: 443 Location: Castro Valley, CA
Posted: Tue Jul 10, 2012 2:38 pm Post subject: Re: Flap Positioner |
I used essentially the same setup. Nice part is that you can position the Adel clamp (by choosing how high on the aft spar the hinge is) so that the first 3 degrees of travel translate into as much sensor motion as possible (e.g., sensor arm is perpendicular to the clamp); near full flaps there is less sensor motion per degree of rotation of the torque tube. I had concerns about seeing the difference between reflex (-3) and trail (0) but with this set up it works just fine.
_________________ Bob Turner
RV-10 QB |
larkrv10(at)gmail.com Guest
Posted: Tue Jul 10, 2012 7:12 pm Post subject: Flap Positioner |
Bob, I hadn't thought that far ahead, but I understand what you're saying. Thx for pointing that out. I will be sure to position the hinge accordingly.
Regards, Rick
On Tue, Jul 10, 2012 at 6:38 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote]--> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=377947#377947
le, List Admin.
tsts4
Posted: Wed Jul 11, 2012 4:50 pm Post subject: Re: Flap Positioner |
That's a great solution! Just so I understand the geometry and how the Pos sensor moves with the flap torque tube, in the pics posted in this thread are the flaps up? IOW full retraction of the sensor's arm indicates flaps up while full extension of the arm would indicate flaps fully extended?
_________________ Todd Stovall
aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace
RV-10 N728TT
Empacone, Wings, Fuse, Finishing
www.mykitlog.com/auburntsts |
Posted: Wed Jul 11, 2012 5:41 pm Post subject: Flap Positioner |
Todd, as I see it, the Ray Allen has a strictly linear motion, but because there are 2 pivot points (hinge and attachment to the adele clamp), as the sensor retracts, then yes the flaps are up. Having said that you might be able to position the sensor/clamp else where and get just the opposite indications. I think it will sort itself out with all the componets "in hand". Hopefully someone who has already done this will confirm.
Rick
#40956
On Wed, Jul 11, 2012 at 8:50 PM, tsts4 <tsts4(at)verizon.net (tsts4(at)verizon.net)> wrote:
[quote]--> RV10-List message posted by: "tsts4" <tsts4(at)verizon.net (tsts4(at)verizon.net)>
That's a great solution! Just so I understand the geometry and how the Pos senor moves with the flap torque tube, in the pics posted in this thread are the flaps up? IOW full retraction of the sensor's arm indicates flaps up while full extension of the arm would indicate flaps fully extended.
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings, Fuse
http://forums.matronics.com/viewtopic.php?p=378052#378052
le, List Admin.
Bob Turner
Posted: Wed Jul 11, 2012 6:04 pm Post subject: Re: Flap Positioner |
I'm doing this from memory but I think you've got it backwards. Photos show full flaps, with sensor arm fully retracted. As the flaps retract the arm moves aft as well as down. As flaps approach fully retracted, the sensor arm is moving down and not fore or aft, maximizing its motion relative to the angular rotation of the flap torque tube. Fully extended sensor arm is flaps up.
RV-10 QB |
