graeme bird
Posted: Sat Jul 14, 2012 12:04 pm Post subject: NPT fittings on fuel flow sensor |
I have just been fitting flow and return EI FP5 fuel sensors using brass NPT hose fittings but they leak, should I use PFTE tape (which is not recommended in case threads of PTFE affect the sensor or block the flow, or maybe compound)
_________________ Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk |
rampil
Posted: Sat Jul 14, 2012 12:31 pm Post subject: Re: NPT fittings on fuel flow sensor |
Never use teflon plumbing tape on fuel fitting!
Tape shreds, sheds and blocks carb orifaces
PTFE compound is the way to go if need be.
europa-list(at)matronics. Guest
Posted: Sat Jul 14, 2012 2:12 pm Post subject: NPT fittings on fuel flow sensor |
Best use a special fuel resistant grease, forget name of it. Small amount on threads cured mine. Dave G-ldvo
On 14 Jul 2012, at 21:09, "graeme bird" <graeme(at)gdbmk.co.uk> wrote:
Graeme Bird
G-UMPY
Mono Classic/XS FWFD 912ULS/Warp drive FP
Newby: 35 hours
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=378291#378291
rlborger(at)mac.com Guest
Posted: Sat Jul 14, 2012 5:08 pm Post subject: NPT fittings on fuel flow sensor |
Greame,
No PTFE tape. There are several brands of PTFE pipe seal compound (SAF-T-LOK, Permatex, Swagelok, LocTite, etc.) that would do the job. They will seal the joint and prevent seizing.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Graeme Bird
G-UMPY
Newby: 35 hours
g(at)gdbmk.co.uk
mau11(at)free.fr Guest
Posted: Sat Jul 14, 2012 10:23 pm Post subject: NPT fittings on fuel flow sensor |
Another solution is Loctite 577. (fuel resistant)
Michel AUVRAY
Date: 2012-07-15 03:07
To: europa-list (europa-list(at)matronics.com)
Subject: Re: NPT fittings on fuel flow sensor
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com>
Greame,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
--> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk>
Graeme Bird
G-UMPY
Newby: 35 hours
g(at)gdbmk.co.uk
sp;The Europa-List Email Forum -
avigator to browse
bsp;List Un/Subscription,
bsp;Browse, Chat, FAQ,
?Europa-List
p; - MATRONICS WEB FORUMS -
;via the Web Forums!
;support!
p; -Matt Dralle, List Admin.
ion
Posted: Sun Jul 15, 2012 12:09 am Post subject: NPT fittings on fuel flow sensor |
Use Loctite Teflon pipe seal, (sparingly) it's supposed to go to dust when unscrewed. Never use the tape.
Graham
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Saturday, 14 July 2012, 23:11
--> Europa-List message posted by: david park <europa-list(at)matronics.com (europa-list(at)matronics.com)>
On 14 Jul 2012, at 21:09, "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)> wrote:
| Quote: | --> Europa-List message posted by: "graeme bird" <graeme(at)gdbmk.co.uk (graeme(at)gdbmk.co.uk)>
Graeme Bird
G-UMPY
Newby: 35 hours
g(at)gdbmk.co.uk
http://forums.matronics  tronics.com/contribution" target="_blank">http://www.matronics.com/contri================
