		Larry Bowen
				 Posted: Tue May 30, 2006 6:54 pm    Post subject: Burnt out MAC indicator? |
				One of the rectangluar LED's on my MAC pitch trim indicator seems to be
 burnt out.  Am I the first to have this happen?  Guess the only fix is to
 replace the whole thing? ($86!)
 Larry Bowen
 Larry(at)BowenAero.com
 http://BowenAero.com
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
		rv8ch
				 Posted: Tue May 30, 2006 11:00 pm    Post subject: Burnt out MAC indicator? |
				 	  | Quote: | 	 		   One of the rectangluar LED's on my MAC pitch trim indicator seems to be
 Hi Larry,
 You might want to check on the GRT yahoo group to see if anyone
 wants to sell theirs - most of the GRT EFIS systems show the
 trim on the EFIS.
 Just as an aside, do you actually use the trim indicators very
 much while flying, or is it just to set the trim at takeoff?
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
  _________________ Mickey Coggins
http://www.rv8.ch/ |
				 Posted: Wed May 31, 2006 3:50 am    Post subject: Burnt out MAC indicator? |
				I had this happen to me too.  I sent an e-mail to RayAllenCo and they took care of it!
 YMMV - but they were good to me!
		seiders(at)bellsouth.net Guest
				 Posted: Wed May 31, 2006 4:47 am    Post subject: Burnt out MAC indicator? |
				Larry you are right about that. I recently replaced mine after losing
 several leds over a span of about 1 year. Call Ray Allen. He may cut you a
 little slack on the replacement.
 Dick
 At 10:52 PM 5/30/2006, you wrote:
 Larry Bowen
		mstewart(at)iss.net Guest
				 Posted: Wed May 31, 2006 5:23 am    Post subject: Burnt out MAC indicator? |
				Larry I think I may have a couple of these in my hanger.
 Will check this weekend and if I have it Ill send it to you.
 Do not archive.
		Larry Bowen
				 Posted: Wed May 31, 2006 5:56 am    Post subject: Burnt out MAC indicator? |
				Many thanks.
 Larry Bowen
 Stewart, Michael (ISS Atlanta) wrote:
  <mstewart(at)iss.net>
  Do not archive.
RV-8 SOLD,
		Larry Bowen
				Thanks for all the input.  I'll give Ray a call and if that doesn't pan
 out I'll get the parts book and soldering iron or check for someone
 selling one.
 Mickey - I reference it almost anytime I'm adjusting it.  I know what the
 normal positions are for my plane during different phases of flight, so I
 can confirm everything is normal in regards to trim.
 Larry Bowen
 Richard Seiders wrote:
  Dick
 >Larry Bowen
RV-8 SOLD,
		low pass
				 Posted: Wed May 31, 2006 6:04 am    Post subject: Re: Burnt out MAC indicator? |
				I lost a couple of elements in several of mine after my voltage regulator failed and they saw high voltage.  Just something you might want to check.
 Bryan
		lifeofreiley2003(at)yahoo Guest
				 Posted: Wed May 31, 2006 6:32 am    Post subject: Burnt out MAC indicator? |
				That's a great idea Mickey. With everyone updating to the glass there should be a stack of used indicators out there. I really don't know and want to clarify, are these LED indicators very accurate?
   Darrell
 Hi Larry,
 trim on the EFIS.
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
 Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls.  Great rates starting at 1¢/min.
				 Posted: Wed May 31, 2006 6:58 am    Post subject: Burnt out MAC indicator? |
				I felt they were accurate enough for our use in RV's
 Do not archive.
 Had one led burn out once. Of course it was my tak-off position one:)
 Never replaced it.
		Ted French
  Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
				 Posted: Wed May 31, 2006 7:00 am    Post subject: Burnt out MAC indicator? |
				I lost the indicator bars in mine as well. I had it wired so it came on with
 the master and when starting, I suspect that the voltage surges zapped it.
 Rewired it to run off an avionics master and no more problems.
 Ted French
 RV-10  finish
  _________________ Ted French
RV-10 fuselage |
				 Posted: Wed May 31, 2006 7:54 am    Post subject: Burnt out MAC indicator? |
				I'm thinking about leaving the LED out all together. There should be a way to install just a light for a generic takeoff position, maybe with some sort of rheostat or potentiometer setup? Any ideas?
   Darrell
 Do not archive.
 Never replaced it.
		tcervin(at)valkyrie.net Guest
				 Posted: Wed May 31, 2006 2:58 pm    Post subject: Burnt out MAC indicator? |
				Add me to the list! I had 26 hours on my 6-A when parts of my trim indicator
 wouldn't light. Called Ray
 Allen and they said to send it in for a look see but that will have to wait
 for the annual in October as I am having to much fun right now.
                                                              Tom in Ohio
		greg(at)itmack.com Guest
				 Posted: Wed May 31, 2006 4:38 pm    Post subject: Burnt out MAC indicator? |
				Mickey, I've ordered the GRT EFIS and have been reading the manuals but see
 no reference to trim inputs.  Where are they mentioned?  BTW I'm not using
 the EIS if that is where it goes.
 Greg
  Hi Larry,
  trim on the EFIS.
  Mickey Coggins
  http://www.rv8.ch/
  #82007 finishing
		rv8ch
				 Posted: Thu Jun 01, 2006 12:42 am    Post subject: Burnt out MAC indicator? |
				Greg(at)itmack wrote:
 The GRT guys seem to be a bit behind on their website updates,
 and documentation updates.  I learned about this on the
 GRT_EFIS yahoo group.  Here's a picture of the trim indicators
 on the screen from Mike Schipper's website:
   http://www.my9a.com/finish15.asp  (it's about two screens down)
 Mike drew a nice wiring diagram, but I couldn't find it
 on his site.  I uploaded it here:
 http://img93.imageshack.us/img93/9839/grtefistrimwiring1zj.jpg
 The Yahoo group is good - check it out!
   http://groups.yahoo.com/group/GRT_EFIS/
 Mickey Coggins
 http://www.rv8.ch/
 #82007 finishing
