jdubner
Joined: 17 Jul 2012 Posts: 35 Location: Independence, OR
Posted: Wed Jul 18, 2012 9:49 am Post subject: Source for DP3T ON-ON-MOM Toggle Switch |
[Pardon me if this is a duplicate. I twice attempted to post it via the email interface with no apparent success. Using the web interface now.]
Does anyone have a source for the Apem 644H/2-1R toggle switch (DP3T ON-ON-MOM) in the USA? (It's a non-stock, minimum-25 item at DigiKey.) I'd like to use them to control dual PMags in this manner: http://gikonelectrics.blogspot.com/2008/09/p-mag-wiring.html
Joe
Independence, OR
http://www.mail2600.com/position
mrspudandcompany(at)veriz Guest
kuffel(at)cyberport.net Guest
Posted: Wed Jul 18, 2012 11:04 am Post subject: Source for DP3T ON-ON-MOM Toggle Switch |
Joe,
<< toggle switch (DP3T ON-ON-MOM) >>
Mouser (mouser.com) has 3 in stock of part number 633-M204701-RO for $15.14
each with solder lugs. If you can tolerate PC pins instead of solder lugs
they have 520 in stock of non-catalog part number 633-M2047SD3W03/U switches
at $13.57 each. Search M2047 from the Mouser main page. Mouser has a
long history of being friendly to the small quantity buyer. I recommend
them highly.
Tom Kuffel
harley(at)AgelessWings.co Guest
jdubner
Posted: Wed Jul 18, 2012 11:37 am Post subject: Re: Source for DP3T ON-ON-MOM Toggle Switch |
Eaton makes a fine switch but at $30 each, screw terminals, and not in stock, I'll pass.
| Quote: | Mouser (mouser.com) has 3 in stock of part number 633-M204701-RO for $15.14
at $13.57 each. ...
Tom Kuffel |
I hadn't considered anything other than Faston terminals but may re-think soldered leads if all else fails. Thanks.
Harley, I had been looking at that particular switch but the Mouser description says "ON-ON-ON" instead of "ON-ON-MOM" and the part number is slightly different. That's most likely the switch I want but Mouser hasn't responded to my request for more clarification.
So I'm still looking for an Apem 644H/2-1R.
Joe
Posted: Wed Jul 18, 2012 11:59 am Post subject: Source for DP3T ON-ON-MOM Toggle Switch |
Joe...
Actually, the description says ON-ON-MOM...you just have to look at the data sheet where it defines the part numbers. Check out the data sheet for the link I gave you (click on the "Documents" tab, then "Data Sheet" ...that switch part number that you asked about is definitely an ON-ON-Mom...that's what the IR means. The picture and description on the page is just for the general series of that switch...the data sheet states that it is ON-ON-ON only if the IR suffix is not present...and it is present, so it's On-On-MOM.
That is the exact switch you asked for...and I agree with Tom ...Mouser has never done me wrong...good people to work with.
Harley
On 7/18/2012 3:37 PM, jdubner wrote:
[quote] | Quote: | --> AeroElectric-List message posted by: "jdubner" <jdubner(at)yahoo.com> (jdubner(at)yahoo.com)
at $13.57 each. ...
Tom Kuffel
Joe
| [b]
jdubner
Posted: Wed Jul 18, 2012 2:12 pm Post subject: Re: Source for DP3T ON-ON-MOM Toggle Switch |
| harley(at)AgelessWings.co wrote: | Joe...
That is the exact switch you asked for... |
Thanks, Harley -- I'll order a couple.
Joe
bicyclop(at)pacbell.net Guest
Posted: Wed Jul 18, 2012 2:54 pm Post subject: Source for DP3T ON-ON-MOM Toggle Switch |
Try this one:
http://www.digikey.com/product-detail/en/2NT1-50
Ed Holyoke
On 7/18/2012 10:49 AM, jdubner wrote: [quote] [b]
rv6awingman(at)gmail.com Guest
Posted: Thu Jul 19, 2012 5:06 am Post subject: Source for DP3T On-ON-MOM Toggle Switch |
Joes here's another source if you wish.
BandC carries them, and I've always had great service from these folks.
S700-2-50 ON-ON-(ON) (+ $19.50)
Marty RV-6A
Time: 10:51:54 AM PST US Subject: AeroElectric-List: Source for DP3T ON-ON-MOM Toggle Switch From: "jdubner" <jdubner(at)yahoo.com (jdubner(at)yahoo.com)> [Pardon me if this is a duplicate. I twice attempted to post it via the email interface with no apparent success. Using the web interface now.] Does anyone have a source for the Apem 644H/2-1R toggle switch (DP3T ON-ON-MOM) in the USA? (It's a non-stock, minimum-25 item at DigiKey.) I'd like to use them to control dual PMags in this manner: http://gikonelectrics.blogspot.com/2008/09/p-mag-wiring.html Thanks, Joe Independence, OR http://www.mail2600.com/position Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378654#378654
