		jimhefner
				 Posted: Thu Jun 01, 2006 8:04 am    Post subject: Adriel Sighting |
				A few minutes ago while I was out in my back yard,  I heard an ultralight out to the East and spotted it heading toward my house in Oro Valley from the Pusch Ridge Mountain direction.  As it got closer I looked at it with my binoculars and to my surprise I saw that it was Adriel Heisey circling around and then he headed NW.  It appeared he was following Tangerine Rd out toward Marana.  Maybe he launched his flight from there.
 I have not heard about or from Adriel in what seems to be a couple years and found out from his website late last year that he had moved from Tucson some time ago, so I assume he trailered his plane here and was doing a photo shoot.
 His highly modified Firestar fuselage is a dead give away, as well as the all cream colored plane with no markings.  The 912S sounded sweet, obviously throttled back a lot for cruising.  He told me he burns around 4 gph cruising... he said he can stay up more than 4 hrs with his fuel capacity.  He's an amazing photographer!!  Highly publicized in National Geographic, AZ Highways, etc and has published 2, maybe 3 books by now.
 It was good to see him in the air around Tucson again!!
 Has anyone else heard from Adriel in the recent past??  Wish he would join us at MV sometime!  He's pretty busy with his flying photography business so I'm not holding my breathe on that one... similar to Homer joining us.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Jim Hefner
Tucson, AZ
Do Not Archive |
		Ed in JXN
				 Posted: Thu Jun 01, 2006 8:46 am    Post subject: Adriel Sighting |
				Hi Jim,
         Wasn't he using a modified MkII IIRC?
 Ed in Jxn
 MkII/503
 Do not archive.
		jimh474(at)earthlink.net Guest
				 Posted: Thu Jun 01, 2006 9:00 am    Post subject: Adriel Sighting |
				Adriel, is flying a modified TwinStar.
 Jim Hauck
 On 6/1/2006 12:44:56 PM, Ed Chmielewski (edchmiel(at)mindspring.com) wrote:
 <edchmiel(at)mindspring.
 [quote] com>
 =20
  Hi Jim,
 =20
 =20
  Ed in Jxn
  MkII/503
 =20
  Do not archive.
 =20
 =20
		jimhefner
				 Posted: Thu Jun 01, 2006 2:17 pm    Post subject: Re: Adriel Sighting |
				Thanks for correcting me Jim.  You would know since you might have helped Dennis custom built it for Adriel.   I'm not familiar with the old Kolb line but knew it was a 2 seater, modified quite a bit for his photography equipment.  I've never seen a stock Twinstar, but judging by Adriel's plane, it appears to have had some similarities to the Mark III.
Tucson, AZ
Do Not Archive |
				 Posted: Thu Jun 01, 2006 3:16 pm    Post subject: Adriel Sighting |
				Jim and All;
 No I didn't custom modify Adriel's Twin Star and I don't believe Dennis =
 had anything to do with it either. I repaired the plane after Adriel =
 broke it several years ago.
 Jim Hauck
 On 6/1/2006 6:17:17 PM, jimhefner (hefner_jim(at)msn.com) wrote:
 =20
  Thanks for correcting me Jim.  You would know since you might have =
 helped
  	  | Quote: | 	 		   Dennis custom built it for Adriel.
  I'm not familiar with the old Kolb line but knew it was a 2 seater, =
  	  | Quote: | 	 		   never seen a stock Twinstar, but judging by Adriel's plane, it appears =
  	  | Quote: | 	 		  =20
  Jim Hefner
  Tucson, AZ
  Firefly #022  447, 2 blade IVO, BRS-750
 =20
 =20
 =20
 =20
 =20
  http://forums.matronics.com/viewtopic.php?p=3D37944#37944
 =20
 =20
 =20
 =20
 =20
 =20
 =20
 =20
 =20
 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
  	  | Quote: | 	 		   =
		jimhefner
				 Posted: Thu Jun 01, 2006 4:52 pm    Post subject: Re: Adriel Sighting |
				Jim, I recall from talking to Adriel a few years ago that he had worked with Dennis on the changes, unless my brain cells are starting to retire with me...      Dennis could easily set us all straight if he is monitoring the list now.  I'm pretty sure Adriel didn't just go off and make those mods without consulting old Kolb, particularly Dennis Souder.  Adriel's a darn good photographer and flier, but he doesn't strike me as being an aircraft designer/engineer type.  Been wrong many times before though so you might be right.
Tucson, AZ
Do Not Archive |
		jimhefner
		flykolb(at)pa.net Guest
				 Posted: Thu Jun 01, 2006 9:20 pm    Post subject: Adriel Sighting |
				Adriel's aircraft is an original TwinStar (not Mark-2 or 3). He
 painstakingly built it all by himself with many modifications and additions
 for his photographic purposes.  Some years later he had an accident and a
 fair amount of damage and Jim H. helped with the cage repair.
 	Later, when Adriel wanted a more dependable engine, because he was
 flying over such inhospitable terrain, I did my best to dissuade him from
 installing the 912 in the TS, and then I was even more adamant when he
 wanted to do the 912S instead of the 912.  But seeing he was determined and
 not about to be deterred from his task - I offered what input I could so as
 to hopefully increase the probability of success.  Adriel is an
 exceptionally gifted photographer, and designer, and builder and pilot.  Not
 too many of those around.
 	I was opposed to the 912 installation because the TwinStar has only
 5" x 050 spars; not the 6" x 058 that the Mark-III uses.  Even though Adriel
 assured me that he would use the power very sparingly, I was and still am
 concerned that others see his installation and think this is something they
 too can do.  Possibly they could, but maybe they would not be quite as
 diligent in the building details as Adriel was, and maybe not quite as
 meticulous in maintenance as Adriel is and possibly not as conservative in
 flying as Adriel is ... and maybe they won't experience his success.  And
 maybe Adriel's 912S powered TS may yet have, for instance, have some fatigue
 related problems surface - I certainly hope not.  But one thing is for
 certain, he is certainly probing closer to the edge than anyone has
 previously done with the TS design.  Adriel you are awesome - but keep
 inspecting that frame!
 Dennis
		jimhefner
				 Posted: Fri Jun 02, 2006 5:41 pm    Post subject: Re: Adriel Sighting |
				Thanks for your post Dennis.  I agree wholeheartedly with what you said about Adriel's many talents.  He's also one hell of a nice guy!!  He's responsible for getting me into Kolb flying.  After I met him and saw his plane, saw his photos and heard about his flying scenario, I had to have a trailerable Kolb, with no enclosed cockpit, so I could take great photos like Adriel, although my equipment (plane and camera) and my photographic talent all pale in comparison to Adriel's!  He's "the man" in my book!  He figured out how to combine his many talents and his love for flying and make a comfortable living doing it, although it took quite a while for the success and recognition to come when he first got started.
 Since he was looking for reliability, not lots of power, I'm sure the 912S is loafing along most of the time.  It is interesting that he went all the way to the 912S... seems the 80hp would have been a lot more than was needed and would have gotten the reliability he was looking for.  I'm sure he had a good reason in mind.
 Thanks again to you and Jim H for sharing your experiences with Adriel.
Tucson, AZ
Do Not Archive |
				 Posted: Fri Jun 02, 2006 7:46 pm    Post subject: Adriel Sighting |
				The reason he wanted the 912s was for his "next" airplane.  He really didn't
 want the -s for the TS, but figured it would be useful in the future.
 Dennis
