		HOLZY(at)aol.com Guest
				 Posted: Thu Jun 01, 2006 9:39 am    Post subject: high oil temps 912 |
				List Members,
 I have been getting some very high oil temps lately on my 912.  POH  says up
 to 285 is within limits, but my gauge only goes to 260.  I have  been doing a
 lot of pattern flying & it spends most of the time  pegged.  It drops off a
 little(10-20 degrees) when I level off at 3000  ft.Pressure is only slightly
 high & cht's are fine so my mechanic thinks it  is a gauge/sender problem.  I
 did, however, get a new gauge & sender at  the beginning of 2005.  There were no
 high readings in 2005.  Engine  is 10 years old but with only 125 hours,  oil
 change is fresh this  spring.  Any ideas or suggestions would be appreciated.
 What are  Ideal oil temps/pressure for the 912 in the summer?
 Thanks in advance for the advice,
 Mike Holzberger
 Milwaukee WI
 N104DG Model IV Speedster 912
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		lcfitt(at)sbcglobal.net Guest
				 Posted: Thu Jun 01, 2006 11:46 am    Post subject: high oil temps 912 |
				Mike are you using an oil cooler?
 Lowell
		mike Guest
				 Posted: Thu Jun 01, 2006 1:37 pm    Post subject: Re: high oil temps 912 |
				This may sound weard, but turn off your charging system, when I do all my temps drop 20degrees.  Still trying to figure why.
		roncarolnikko(at)hotmail. Guest
				 Posted: Thu Jun 01, 2006 2:01 pm    Post subject: high oil temps 912 |
				Mike do you have a ground strap on your engine, frame, panel?  Ron NB Ore
 Dont just search. Find. Check out the new MSN Search!
 http://search.msn.click-url.com/go/onm00200636ave/direct/01/
		mike Guest
				 Posted: Thu Jun 01, 2006 3:14 pm    Post subject: Re: high oil temps 912 |
				good grounds, but the temps on all guages do this. I have a ground that goes to the engine, seperate ground buss for all other grounds.  I come across this because my stereo was making noise and I turned off the alternator and it quit and I noticed the temps dropped when doing it.  I did correct the stereo noise by putting a cap on the power lead to ground for the stereo.  Nice and quit now.  But the temps has me wondering might need to tackle that problem next.  But then again even with this the temps don't go over 220 on head temps, oil or water(still head temp).  That's with 90 f outside temp.
 kitfox4 1200
 912ul
 kitfoxmike
		neflyer48(at)cableone.net Guest
				 Posted: Thu Jun 01, 2006 3:58 pm    Post subject: high oil temps 912 |
				Mine usually shows about 240 to 250 on warm days. The sending unit is in the
 bottom of the block, in the front port. The oil blow back hose is in the
 back port. I believe the high temperature reading is because the sending
 unit is not really submerged in oil because the oil is scavenged out of the
 block. The hot blowby gas in the crankcase is what is really being read by
 the oil pressure gauge. I thought about changing it to a different location.
 Jerry Kohles  912  830hrs.
				 Posted: Thu Jun 01, 2006 9:23 pm    Post subject: high oil temps 912 |
				Mike,
 Try running a temporary ground wire from your gauge
 grounds to the battery (-) terminal.  See if that
 changes it.  You may have a bad battery ground since
 you get the lower reading off the battery.
 Kurt S.
 --- kitfoxmike <kitfoxmike(at)yahoo.com> wrote:
  	  | Quote: | 	 		   This may sound weard, but turn off your charging
  kitfoxmike
  kitfox4 1200 912ul speedster
  http://www.frappr.com/kitfoxmike
		mike Guest
				 Posted: Fri Jun 02, 2006 7:42 am    Post subject: Re: high oil temps 912 |
				Next time I have the cowl off I'll check the ground for the guages.
				 Posted: Fri Jun 02, 2006 10:44 am    Post subject: high oil temps 912 |
				I am really curious about what is going on here.  When I was building, I
 went to the factory fly-in in Caldwell and noticed that most 912 powered
 airplanes had tape over part of their oil cooler fins to reduce air flow and
 thus increase oil temps.  The target, of course, close to the boiling point
 of water to keep the condensation and blow by moisture under control.
 For that reason I used the 5.5 inch (between centers) Earls oil cooler
 rather than the 7 inch sold by Skystar at the time.  I still had to put
 shutters on the oil cooler and can climb with temps in the green and with
 the exception of the hottest days, the shutters are rarely fully open.
 What model KF are you flying?
 Regrding blowby gasses, Rotax has spent a lot of energy with Service
 Bulletins talking about the importance if not having air (gas) in the oil.
 The new dipstick, oil recommendations, direction of prop rotation (hand
 propping) and venting of the oil system after oil change have all been to
 eliminate this issue and they hold that if you have bubbles in your oil, you
 will have much more serious problems than simply with the high oil temps.
 incidentally, I have just gone through my forth oil temp sender - WesTach -
 in two years.  One lasted less than 2 months, this one almost exactly a
 year.  What are others experience with these senders - the short one.
 Lowell
 Can yoiu give a few more details on your installation.
		clint_bazzill(at)hotmail. Guest
				 Posted: Fri Jun 02, 2006 12:20 pm    Post subject: high oil temps 912 |
				I replaced oil temp sensor at 1000 hours, and a CHT at about 800.  Clint
 912ULS
 Subject: Re: high oil temps 912
 Date: Fri, 2 Jun 2006 11:41:02 -0700
 Lowell
		mike Guest
				 Posted: Fri Jun 02, 2006 1:03 pm    Post subject: Re: high oil temps 912 |
				I personally have the big cooler with a thermostate.  The thermostate is way cool, no more waiting for the engine to warm up, by the time I get to the runway I'm ready to go, doesn't matter if it's 30f outside or 90f, best thing, no more tape on the cooler.  I've also had to replace the oil sensor about 200hrs ago, hum... last year.
		kerrjohna(at)comcast.net Guest
				 Posted: Sun Jun 04, 2006 5:27 pm    Post subject: high oil temps 912 |
				where did you get the thermosat and where did you install it?
  John Kerr
  	  | Quote: | 	 		   --> Kitfox-List message posted by: "kitfoxmike"
  hum... last year.
  kitfoxmike
  http://forums.matronics.com/viewtopic.php?p=38171#38171
  <  BR>>  ====== =====================================
		mike Guest
				 Posted: Mon Jun 05, 2006 6:44 am    Post subject: Re: high oil temps 912 |
				lockwood aviation.  on top of the motor, behind the gear box.
