		ppeerenbo(at)charter.net Guest
				 Posted: Thu Jun 01, 2006 3:27 am    Post subject: Cracked Eng Mount |
				I have a Model IV with a 912UL 360TT. I found a eng mount crack on the short
 tube that connects the top mounts, left side. The crack looked like a stain
 on the powered coated mount that wiped off. I cleaned the paint off and the
 tube is cracked half way around. Can any one give me information on the
 mount? Wall thickness, any weld repair advice is welcome.
 Paul N102DG
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Jim Shumaker
				 Posted: Thu Jun 01, 2006 5:11 am    Post subject: Cracked Eng Mount |
				Paul
   I just found a crack on my model III 912ul.  It was on the top of the ring tube of the dynafocal mount.  When I pulled the engine, one of the short tubes was also cracked.  I have not even done a complete inspection yet.  Will keep you informed as to what I find.
   Even with two cracked tubes on the mounts the engine felt tight and secure on the frame.
   Jim Shumaker
 Paul N102DG
  _________________ Jim Shumaker |
		jimmieblackwell(at)sbcglo Guest
				 Posted: Thu Jun 01, 2006 7:24 am    Post subject: Cracked Eng Mount |
				This the third engine mount problem, (including mine), with the 912 UL in the last two weeks.  I wanted to ask Jim and Paul to post a picture of their cracked mounts on Sportflight and let's try to determine if there is are some common denominators such as torque or total hours on the mount when it fails.  Looks like Paul and I had about the same amount of hours when the failure occurred.
    My rubber engine mount pads had been changed within 15 hours of when my engine mount broke.  When changing the rubber pads I torgued all the hardware according to the latest Model IV building manual.  I can't help but wonder if the torque settings may be wrong or if there was a batch of bad engine mounts produced at some point.  Hopefully, some of you with more experience and knowledge can help us figure out what is causing the engine mount failures before someone hurts their Kitfox or worse, themselves.
   Jimmie
 James Shumaker <jimshumaker(at)sbcglobal.net> wrote:
 Paul
 Jim Shumaker
 Paul
 Paul N102DG
				 Posted: Thu Jun 01, 2006 7:58 am    Post subject: Cracked Eng Mount |
				Jimmie and all,
 I do not have the 912, but wonder after reading other
 posts on this list if it isn`t a problem with start
 and shutdown shaking from the high compression.
 Unless you have inflight vibration that occurs at rpms
 you should stay away from, it would seem the biggest
 vibration is durning starting and stopping.  Different
 props would likely mean different running vibrations,
 so unless your props are the same, that should not be
 the problem.
 Do you have clutches installed?
 How much does the plane shake when you start?
 Do you notice inflight vibs?
 Have you had exhaust cracks that would indicate
 running vibs?
 Carbs falling off?
 These questions have been raised before on the list
 and there may be a connection.
 Kurt S.  S-5/NSI turbo
 --- Jimmie Blackwell <jimmieblackwell(at)sbcglobal.net>
 wrote:
  	  | Quote: | 	 		   This the third engine mount problem, (including
				 Posted: Thu Jun 01, 2006 3:01 pm    Post subject: Cracked Eng Mount |
				I will take a picture this weekend. I have had a carb come off 200  plus hrs
 ago, balancing carbs, new carb sockets, and spring kit seams to have taken
 care of that. 100 plus hrs ago I did the mod to stiffen the eng mounts
 (shorten the bushings). Its more than likely that this has been cracked for
 a wile. Its appears to emanate from the weld and I would say it went aft
 first and could go unnoticed easily. I am an airline mechanic for 27 years,
 including time as a level II NDT, PT, UT, ET & PM. If I had just wiped the
 stain and not go further with power coat removal, it would go till the next
 annual inspection, this is a very fine tight crack. I do not have a slipper
 clutch, and the 912 does shake if you don't get a clean start. The start
 procedure that was on this list of using choke with the ignition off and let
 sit, then set the throttle seams to work better than the primer system. ( I
 took that off) I have never had exhaust or any real fretting problems, when
 running the 912 is awsom powerplant.
 Paul N102DG
		mike Guest
				 Posted: Thu Jun 01, 2006 4:43 pm    Post subject: Re: Cracked Eng Mount |
				another thing to be concerned about is shut down.  What I do is run the rpm's up to about 3000 and then turn off the mags and pull back on the throttle as far as it will go at the same time.
		Jim Shumaker
				 Posted: Thu Jun 01, 2006 9:51 pm    Post subject: Cracked Eng Mount |
				I'll try to get pictures up this weekend also.
   My guess is that it is the shaking of the engine.  There is not any distortion associated with the cracks on my engine and they are not cracked all the way around.
   Jim Shumaker
 Paul N102DG
		gjglh(at)cebridge.net Guest
				 Posted: Fri Jun 02, 2006 5:38 pm    Post subject: Cracked Eng Mount |
				I had to pull my engine because of a cracked motor mount. Facing the engine the top
 left verticle downward tube broke of 3/4" above rubber mounts and the right side of
 the cross tube for the upper mounts had a crack 1/2" in. I put an outer tube layer
 on each tube to give added strength.
 Gary
 M-IV Speedster
 On Fri Jun  2  1:48 , James Shumaker <jimshumaker(at)sbcglobal.net> sent:
 around.
   Jim Shumaker
 Paul N102DG
		Jim Shumaker
				 Posted: Sat Jun 03, 2006 6:16 am    Post subject: Cracked Eng Mount |
				The cracks on my mounts seem to be in the same places.
   Jim Shumaker
 Gary
 M-IV Speedster
 On Fri Jun 2 1:48 , James Shumaker sent:
 around.
  Jim Shumaker
 Paul N102DG
		pwmac(at)sisna.com Guest
				 Posted: Tue Jun 06, 2006 3:10 pm    Post subject: Cracked Eng Mount |
				There are many examples of cracked mounts before Skystar came up with
 the heavy wall mount $$. Most of the cracks were in the tubing - not
 even close to the welds. Guys with powder coated mounts found the
 cracks were hidden by the coating because the coating is so flexible.
 I would strongly recommend removing the coating on all the upper
 tubes from weld to weld and making a close examination. When the
 repair is complete don't powder coat use and enamel paint which is
 brittle and will reveal a crack as soon as it happens. White is the
 best color for showing cracks.`
 BTW, there are several reports of the Skystar repairs failing again,
 but fix I used is much better than the temporary fix that Skystar was
 using and did not work.
 If you want the details on how to do a DIY beefup/repair let me know
 and I will PM you with pics and specs which Frank Miller gave me.
 This info is applicable for the M4 mount which was a Skystar design.
 If the newer models use the Rotax style with the circular /ring mount
 then I would be of no help.
 I hesitate to post the long winded message on the list so If someone
 else wants the info I will send it to them as well.
 Avoid cracks by using a protocol for start and shutdown that
 eliminates engine shake, but, that is another thread.
 Regards, Paul W
 Paul N102DG
