kearney
Posted: Sun Aug 05, 2012 5:06 pm Post subject: Windscreen Installation |
Hi
Today I had a fun filled time trimming my windscreen in anticipation of installing it tomorrow.
Looking at the plans, it would seem that the inside of the windscreen, at the bottom, would merely reveal the epoxy / fibreglass used to glue it in place (on the outside). I am wondering if it is necessary to cover the interior with something so it looks finished.
Any comments / ideas?
Cheers
Les
#40643 [quote][b]
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Sun Aug 05, 2012 5:15 pm Post subject: Windscreen Installation |
Aircraft Spruce sells black dye specifically to color glass and resin. I used this on mine and it worked great.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Sun Aug 05, 2012 5:28 pm Post subject: Windscreen Installation |
I used carbon fiber for the windscreen lower section. I found the carbon fiber easier to work with then glass, and it looks cool on the inside.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Sunday, August 05, 2012 9:06 PM
Subject: Windscreen Installation
Hi
Cheers
Les
#40643 http://forums.matronics.com[/url] - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] [/quote]
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Sun Aug 05, 2012 5:36 pm Post subject: Re: Windscreen Installation |
You can also pick up the black dye at west marine.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
kearney
Posted: Sun Aug 05, 2012 5:51 pm Post subject: Windscreen Installation |
Hmmmm
The dye sounds like what I want. Do you have a product name / description?
Cheers
Les
On 2012-08-05, at 7:36 PM, "bill.peyton" <peyton.b(at)sbcglobal.net> wrote:
Dick Sipp
Posted: Sun Aug 05, 2012 6:07 pm Post subject: Windscreen Installation |
I painted the inside surface with a flat black to provide a view block like on car windshields
Dick Sipp
From: Carl Froehlich (carl.froehlich(at)verizon.net)
Sent: Sunday, August 05, 2012 9:28 PM
Subject: RE: Windscreen Installation
Carl
Hi
Cheers
Les
#40643 [quote] - List Contribution Web generous nbsp; --> http://www.matronics.com/c=[/b] | Quote: |
Strasnuts
kearney
Posted: Sun Aug 05, 2012 6:18 pm Post subject: Windscreen Installation |
Hi Again
To quote Emily Latella, "Nevermind". I found the dye. Spruce lists it as a
pigment and not as a dye. I think I know where I can get it locally as well.
Thanks Again
Les
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sun Aug 05, 2012 6:25 pm Post subject: Windscreen Installation |
Ah, yes! Emily Latella. You are giving a clue to your vintage, Les! ^_^
David Maib
RV-10 Transition Training
40559
On Aug 5, 2012, at 10:18 PM, Les Kearney wrote:
Hi Again
Thanks Again
Les
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Sun Aug 05, 2012 7:21 pm Post subject: Windscreen Installation |
I painted the inside flat black for the first 1.5" or so.
--Dave
On Aug 5, 2012, at 18:05, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Windscreen Installation
Hi
Cheers
Les
#40643
mauledriver(at)nc.rr.com Guest
Posted: Sun Aug 05, 2012 8:21 pm Post subject: Windscreen Installation |
I used black dye in the resin. Made it look like carbon on the inside.
http://www.aircraftspruce.com/catalog/cmpages/epoxyPigments.php
Sent from my iPad
On Aug 5, 2012, at 9:28 PM, "Carl Froehlich" <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
[quote]Windscreen Installation <![endif]--> <![endif]-->
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Hi
Cheers
Les
#40643 http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c=
courier new,courier">http://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Mon Aug 06, 2012 5:45 am Post subject: Re: Windscreen Installation |
You can also use copier machine toner if you any of that around. It doesn't take much to color the epoxy.
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
rv10flyer
Posted: Tue Aug 07, 2012 5:57 am Post subject: Re: Windscreen Installation |
Flat black paint on the inside works great.
_________________ Wayne G. |
