Cork Gaskets For Comant CI122 VHF Antennas
Site Admin
PostPosted: Mon Aug 06, 2012 7:18 pm    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
Does anyone have a good source for the cork gaskets used with the Comant CI 122 VHF Com antennas? When I removed them from the old RV-8 fuselage, I must have put them in a very "safe" place and now I can't find them anywhere. Guess they're pretty safe. Anyway, I need to order a couple more but I checked the Chief, Pacific Coast Avionics, and ACS web pages and found the antennas but no references to just ordering the cork gaskets.
<http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf>http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf
Thanks for any tips...
Status: 80+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
Kelly McMullen
PostPosted: Mon Aug 06, 2012 7:33 pm    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
Probably easiest to visit your friendly National Air Parts Store or
AirplaneZone for a roll of cork gasket material and cut yourself ones
to fit. Nothing special about those gaskets.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Mauledriver(at)nc.rr.com
PostPosted: Tue Aug 07, 2012 7:11 am    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
Seems like I recall someone recommending discarding the gasket and going
for direct metal to metal.
Anyone doing that? Why?
Bill Watson
(do not archive)
Checked by AVG - www.avg.com
rv10pro(at)gmail.com
PostPosted: Tue Aug 07, 2012 10:54 am    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
At the airlines, we do Direct Metal to Metal to effect an improved groundplane.  We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity.  The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture.  The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
On Tue, Aug 7, 2012 at 8:10 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Seems like I recall someone recommending discarding the gasket and going for direct metal to metal.
Bill Watson
(do not archive)
--> RV10-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
http://forums.matronics.com
le, List Admin.
dmaib@me.com
PostPosted: Tue Aug 07, 2012 11:05 am    Post subject: Re: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
rv10pro(at)gmail.com wrote:
At the airlines, we do Direct Metal to Metal to effect an improved groundplane. �We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity. �The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture. �The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
I did mine exactly the way John describes. Somebody (can't remember who, but probably Stein) recommended this approach. I have had no problems in nearly four years.
David Maib
RV-10 #40559
New Smyrna Beach, FL
carl.froehlich(at)verizon
PostPosted: Tue Aug 07, 2012 11:11 am    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
Recommend using the gasket.
Recall that the antenna needs an RF ground, not necessarily a DC ground. Using the gasket mitigates the corrosion aspects while still providing the needed RF ground.
Carl
On Aug 7, 2012, at 2:51 PM, John Cox <rv10pro(at)gmail.com (rv10pro(at)gmail.com)> wrote:
[quote]At the airlines, we do Direct Metal to Metal to effect an improved groundplane. We also treat the skin agains corrosion (Alodine), then Fillet seal the antenna flange to the skin for water-tight integrity. The biggest failure is returning the aircraft to service too soon, pressurizing the cabin for passengers and getting blow-outs in the fillet which allows moisture. The corrosion is certain in the presence of millivolts, moisture and dissemilar materials.
Bill Watson
(do not archive)
le, List Admin.
Kellym
PostPosted: Tue Aug 07, 2012 12:22 pm    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
The antenna has a gasket for a reason. The base of the antenna is more
than adequately grounded by the 3-4 screws that fasten it to the doubler.
<mailto:Mauledriver(at)nc.rr.com>> wrote:
<Mauledriver(at)nc.rr.com <mailto:Mauledriver(at)nc.rr.com>>
Bill Watson
(do not archive)
<dralle(at)matronics.com <mailto:dralle(at)matronics.com>>
cork gaskets.
Mishap...
Full Flyer Mode
Checked by AVG - www.avg.com <http://www.avg.com>
le, List Admin.
Kelly McMullen
KCHD
hotwheels
PostPosted: Wed Aug 08, 2012 9:38 am    Post subject: Re: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
My brand new Comant antenna came without any gasket. Here's the blurb from ACS:
"Comant Antennas no longer come with a gasket or template. Must order PN 09-00532 separately."
What arrived ended up looking a lot like proseal. I could have done that myself. Sad
Jay
[quote="Matt Dralle"]Does anyone have a good source for the cork gaskets used with the Comant CI 122 VHF Com antennas? When I removed them from the old RV-8 fuselage, I must have put them in a very "safe" place and now I can't find them anywhere. Guess they're pretty safe. Anyway, I need to order a couple more but I checked the Chief, Pacific Coast Avionics, and ACS web pages and found the antennas but no references to just ordering the cork gaskets.
<http>http://www.cobham.com/media/9104/ci%20122%20data%20sheet.pdf
PostPosted: Wed Aug 08, 2012 12:01 pm    Post subject: Cork Gaskets For Comant CI122 VHF Antennas Reply with quote
I just installed a RA Miller AV-17 (bent belly mount VHF). It's a few
$$ cheaper than the equivalent Comant and still comes with a gasket. I
now have two on my belly.
What is the criteria people are using for the Comant over the RAM
equivalent?
Bill "just curious" Watson
Jay
do not archve
