Remi Guerner
Posted: Sat Aug 11, 2012 12:00 pm Post subject: outrigger legs |
Hi Monowheel drivers,
I broke one outrigger leg two months ago and flew for a while with an emergency repair designed on site just to allow me to go back home: the repair was made using the existing remains of the nylon rod lengthened with scrap aluminum tubing. When I finally received the nylon rods ordered from the Europa factory I could not use them because they were slightly too short and badly machined. So I ordered a length of 1"1/4 Nylon from ACS and installed them immediately. At the first landing, one of the all new legs broke just at mid length. I was very embarassed as this happened on a big airport were I had the honor of a jumbo eight wheeler fire truck! This time I managed to repair quickly as I was carrying the old emergency repaired rod in the aircraft. I am now afraid of flying with the aircraft as it is, as an out rigger leg can break again at the next landing.
My questions:
- How is that possible that a new nylon rod breaks at the very first landing while the original parts have been able to withstand 12 years of aging, 950 flight hours and probably one or two thousand landings, some of them not as smooth as they should be?
- How is that possible that the nylon rod broke right at mid length, which is not where the maximum stress is located? Note that the first leg broke at the upper end which seems logical to me.
- What is the experience on other monowheels regarding the life of those nylon rods?
- has anyone designed and tested a variation of the original outriggers, with rods made of other materials such as glass fiber, steel...?
Remi Guerner
F-PGKL, grounded
Posted: Sat Aug 11, 2012 1:55 pm Post subject: outrigger legs |
Remi
I remember there was some testing of various grades of nylon, they are not all the same.
Was it nylon 6-6 that was chosen? Also worth noting that nylon absorbs up to 7% by weight water. Does that make it less brittle? Nigel or Ivan please?
Graham
Sent: Saturday, 11 August 2012, 21:00
Subject: outrigger legs
--> Europa-List message posted by: "Remi Guerner" <air.guerner(at)orange.fr (air.guerner(at)orange.fr)>
My questions:
Remi Guerner
F-PGKL, grounded
http://forums.matronics.com/viewtopic.php?p=38067m/Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigatsp; - MATRONICS WEB FORUMS -
nbsp; -Matt Dralle,tribution" target="_blank">http://www.matronics.com/contribution
_-===================================
Posted: Sat Aug 11, 2012 2:07 pm Post subject: outrigger legs |
Have you considered making some out of Kevlar, could be lighter and
stronger, and more forgiving than the nylon
As for the nylon, I have seen "casting" faults in some of the larger pieces
I have been given over the years. They
Looked like a light coloured line or hair in the nylon. For general use most
people wouldn't notice and it wouldn't
Have any effect on the performance of the product. Maybe you had one that
went undetected at that failure point, until you landed.
Good luck, no damage I hope
Craig
ward.t(at)xtra.co.nz Guest
Posted: Sat Aug 11, 2012 2:21 pm Post subject: outrigger legs |
Remi,
Maybe a bad batch of legs supplied to the Company. Tell the Company and return them for testing. They should send another pair out hopefully from a different batch.
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 12/08/2012, at 8:00 AM, "Remi Guerner" <air.guerner(at)orange.fr> wrote:
My questions:
Remi Guerner
F-PGKL, grounded
http://forums.matronics.com/viewtopic.php?p=380679#380679
klinefelter.kevin(at)gmai Guest
Posted: Sat Aug 11, 2012 5:51 pm Post subject: outrigger legs |
Hi Remi,
I have had several outrigger legs fail. Some from bad landings. Others for no good reason. It is my belief that the Nylon-66 does not easily show any signs of weakness or eminent failure. So you can't properly inspect preflight.
I know from talking to other mono pilots that plenty of failures have occurred for no apparent reason.
I started using fiberglass rod, 5/8" diameter. I use a 6" piece of the nylon-66 with a 5/8" hole bored thru the center to fit the fiberglass rod into the Outrigger socket. I tapered the nylon from the bottom of the socket to the lower end of the 6" nylon. I tested this on the bench and the rod has about the same flex as the original setup, but when it fails, it is progressive and visible, rather than shattering unpredictably.
I made new wheel forks out of steel to fit 4"inline skate wheels to the smaller diameter legs. They seem no different in the way they perform from the original shopping cart wheels, except they are urethane, have sealed bearings, and wear quite well. Narrower, so probably less drag.
This setup has worked well for me and saved about 1.5lbs.
Kevin
On Aug 11, 2012, at 1:00 PM, "Remi Guerner" <air.guerner(at)orange.fr> wrote:
My questions:
Remi Guerner
F-PGKL, grounded
Remi Guerner
Posted: Sun Aug 12, 2012 12:06 am Post subject: Re: outrigger legs |
Hi Kevin,
Your mod seems to be a good solution. However I am concern about the higher stiffness of the 5/8" fiberglass rod at extreme deflection such as in case of a flat tyre. Did you test this condition? How many hours have you flown with this mod? Where did you purchase the fiber glass rod?
Thanks to all who have quickly responded to my post.
Remi
ivanshaw(at)btinternet.co Guest
Posted: Sun Aug 12, 2012 1:45 am Post subject: outrigger legs |
Tim,
I experimented with many different materials for the outrigger legs and it
was not until using 'nylon 66' that the strength, flexibility and longevity
were all OK.
Ivan
Posted: Sun Aug 12, 2012 1:55 am Post subject: outrigger legs |
Ivan
what about the water content, how does that affect stiffness? I wonder if drought conditions is harmful?
Graham
Sent: Sunday, 12 August 2012, 10:44
Subject: RE: Europa-List: outrigger legs
--> Europa-List message posted by: "Ivan Shaw" <ivanshaw(at)btinternet.com (ivanshaw(at)btinternet.com)>
Tim,
were all OK.
Ivan
Posted: Sun Aug 12, 2012 12:00 pm Post subject: outrigger legs |
I purchased the fiberglass rod stock from McMaster-Carr.
I tested it on the bench by fixing it horizontally in the OR fitting with the tapered nylon "adapter bushing". Then applying weights to the wheel end, and measuring the deflection. The 5/8" fiberglass rod has a very similar flex pattern to the original 1 1/4" nylon-66.
I have flown with this outrigger setup now for over a year, 100 hours and lots of landings. I fly primarily from hard surface runways, but recently completed a nice long "flyabout" from Califoria to northern Washington and Idaho, landing on lots of grass strips. I continued on to Oshkosh, then back to CA. I carry a couple spare legs just in case, but so far so good!
Kevin
On Aug 12, 2012, at 1:06 AM, "Remi Guerner" <air.guerner(at)orange.fr> wrote:
Hi Kevin,
Remi
http://forums.matronics.com/viewtopic.php?p=380717#380717
Remi Guerner
Posted: Mon Aug 13, 2012 10:22 am Post subject: Re: outrigger legs |
Thanks Kevin,
I will certainly use your solution in a near future. BTW I had the opportunity to look at several Fournier motorgliders and some of them are using a design which is similar to yours except that the fiberglass rod is slightly tapered.
Remi
mau11(at)free.fr Guest
Posted: Sat Aug 18, 2012 4:32 am Post subject: outrigger legs |
Hi Kevin, do you have pictures of your fiberglass outrigger?
Michel AUVRAY
Builder 145
From: klinefelter.kevin (klinefelter.kevin(at)gmail.com)
Date: 2012-08-12 21:59
Subject: Re: Re: outrigger legs
--> Europa-List message posted by: klinefelter.kevin(at)gmail.com
Kevin
> --> Europa-List message posted by: "Remi Guerner" <air.guerner(at)orange.fr>
> Hi Kevin,
> Remi
sp;The Europa-List Email Forum -
avigator to browse
bsp;List Un/Subscription,
bsp;Browse, Chat, FAQ,
?Europa-List
;via the Web Forums!
p; - List Contribution Web Site -
;support!
p; -Matt Dralle, List Admin.
ion
JonathanMilbank
Joined: 14 Apr 2012 Posts: 397 Location: Aberdeen area
Posted: Sun Sep 23, 2012 9:31 am Post subject: Re: outrigger legs |
Remi,
PM me if you still need help. Perhaps I might be of assistance.
Jonathan
Remi Guerner
Posted: Sun Sep 23, 2012 11:53 pm Post subject: outrigger legs |
Jonathan,
I have finally installed the new nylon rods supplied by the factory and have flown a few hours since without trouble. But because the supplied rods were badly machined, I had to cut them, then install extensions. So I still consider this fix as temporary and I am considering alternative solutions using composite or metal tapered rods.
Other suggestions?
Remi
<<<<<<PM me if you still need help. Perhaps I might be of assistance.
Jonathan>>>>>>
JonathanMilbank
Posted: Mon Sep 24, 2012 7:03 am Post subject: Re: outrigger legs |
In November my classic mono/tail wheel will be with Neville Eyre in Yorkshire getting tri-gear fitted, after I have flown it for 15 years with the "heroic" undercarriage. The time has arrived for me to have fewer challenges while approaching retirement and approaching runways.
So I should soon have a pair of outrigger legs to give to a deserving cause around mid November. The main problem for most Europa mono owners is that the legs are almost certainly too short, because I still have the original direct drive tail wheel under the fin. Subsequent legs were lengthened for aircraft with the extended tail wheel.
I think it will be almost impossible to remove my wheel forks or the sockets from the legs, but if someone out there thinks that these legs could be useful after surviving intact for such a long time, by all means I'd be glad to see them go to a good home.
raimo.toivio(at)rwm.fi Guest
Posted: Mon Sep 24, 2012 12:24 pm Post subject: outrigger legs |
The tri-gear "trainer" wheels will get me used to the idea that some day I may need to accept being in a wheelchair, which will be okay as long as there's a pretty nurse to push me.
| Do not worry Jonathan - pilots get always the prettiest nurse as long as they are able to talk good pilot stories like mono landings. After, she will sit on you (on the wheel chair) and you start to push hard.
Cheers
- Raimo OH-XRT Finland
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
Terveisin,
Raimo Toivio
RWM-SYSTEMS
"älykästä informaatiotekniikkaa vuodesta 1980"
37500 Lempäälä
FINLAND
p. 03 - 3753 777
f. 03 - 3753 100
www.rwm.fi
info(at)rwm.fi (info(at)rwm.fi)
JonathanMilbank
Posted: Tue Sep 25, 2012 10:30 am Post subject: Re: outrigger legs |
Raimo. Thanks for that thought, but I doubt that I will have strength left in my arms at that age to push the wheels of a wheelchair with two sitting on it together.
However we are not talking about my old arms, but the lovely legs of my other girlfriend Europa G-EIKY. If they are long enough for Remi, then he is welcome to have them; to enjoy their supple strength.
Posted: Thu Sep 27, 2012 1:32 am Post subject: outrigger legs |
2012/9/25 jonathanmilbank <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
| Quote: | --> Europa-List message posted by: "jonathanmilbank" <jdmilbank(at)yahoo.co.uk (jdmilbank(at)yahoo.co.uk)>
Jonathan; have an electric wheelchair if you wanna travel same time and use your old but still strong hands for better purposes in that case.
Maybe you should also save at least one lovely and long enough spare leg for her.
Raimo
http://forums.matronics.com/viewtopic.php?p=383979#383979
le, List Admin.
Terveisin,
Raimo Toivio
RWM-SYSTEMS
37500 Lempäälä
FINLAND
p. 03 - 3753 777
f. 03 - 3753 100
www.rwm.fi
