bankshire(at)harboursat.c Guest
Posted: Thu Aug 16, 2012 4:56 pm Post subject: Schumacher 1562a |
Hi all have an off subject question, will the Schumacher 1562a charger maintainer available on Amazon work on the Australian voltage of 240v ac, Schumacher specifications state input voltage 110-140v ac. Thanks for any input on the subject . John
rlborger(at)mac.com Guest
Posted: Thu Aug 16, 2012 6:19 pm Post subject: Schumacher 1562a |
John,
Probably not without a step-down transformer/voltage converter. If you can't find a charger-maintainer for your 240v world, you can find voltage converters on Amazon or E-Bay.
Best regards,
Robert Borger, President
Geowhiziks & Doodlebugging, Inc.
Certified Petroleum Geophysicist AAPG#101
3705 Lynchburg Dr.
Corinth, TX 76208-5331
(H) 940-497-2123
(C) 817-992-1117
On Aug 16, 2012, at 18:55, John & Sue Dehnert <bankshire(at)harboursat.com.au (bankshire(at)harboursat.com.au)> wrote:
Bob McC
Posted: Thu Aug 16, 2012 6:57 pm Post subject: Schumacher 1562a |
John;
The international version is model SC1200A, spec sheet attached. (I hope)
Couldn’t find a quick source or price, but this is a similar charger other than the input is 120-240VAC 50/60Hz
The 1562a is 120VAC 60Hz only.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John & Sue Dehnert
Sent: Thursday, August 16, 2012 8:55 PM
Subject: AeroElectric-List: Schumacher 1562a
Quote: | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Description: |
 Download |
Filename: |
sc1200a.pdf |
Filesize: |
104.7 KB |
Downloaded: |
184 Time(s) |
_________________ Bob McC
Falco #908
(just starting) |
john.maccallum(at)bigpond Guest
Posted: Fri Aug 17, 2012 3:21 pm Post subject: Schumacher 1562a |
From the specs you have given I don’t think it will. If it has a Transformer with multiple taps on the primary winding you may be able to get someone to alter the taps for you. If it hasn’t got multiple taps on the Primary you will need a new transformer.
If it’s switch mode then you are stuck with the 110-140 vac unless you buy a step down transformer. 240 to 110 Vac.
Cheers
John MacCallum
Builder #41016
VH-DUU
Sent: Friday, 17 August 2012 10:55 AM
Subject: Schumacher 1562a
