Need a set of leads for Tripplet 310-C
rparigoris
PostPosted: Sat Aug 25, 2012 7:24 am    Post subject: Need a set of leads for Tripplet 310-C Reply with quote
Hi Group
I rescued a Triplett 310-C from certain death about two weeks ago.
It's missing the leads for them, anything I have doesn't fit.
Any ideas about getting how to get hold of a set?
This unit takes two 1.5 volt batteries, not sure what size.
Ron Parigoris
PostPosted: Sat Aug 25, 2012 9:09 am    Post subject: Need a set of leads for Tripplet 310-C Reply with quote
At 10:24 AM 8/25/2012, you wrote:
Hi Group
I've not run across that model before. Here's a link to
the list manuals for Tripplet legacy products:
http://tinyurl.com/8tfzxt6
The battery call-outs are:
[img]cid:.0[/img]
Wow! The 1.5 volt cell is an "N" which are still
very much available . . .
http://tinyurl.com/9ozgmtj
The 15v is too . . .
http://tinyurl.com/8okd49r
But a bit more expensive. Again, replacing the
n-cell only might yield a very serviceable
device.
I think those test lead jacks accept the miniature
banana plugs.
Here's a link to a surplus store in Orlando
that has some $high$ Pomona patch cords for cheap with
what I believe is the right sized plug. A couple
of these modified on one end with alligator
clips would get you some leads. You could cover
one of the clips with a red boot and suitably
mark the other end to encourage insertion to the
(+) jack.
When you get it running, show a kid what it does
for you.
 Filesize:  21.75 KB
 Viewed:  1423 Time(s)
