david2005(at)abrahamson.n Guest
Posted: Fri Jun 02, 2006 3:17 am Post subject: 16AWG fusible link |
I am building an RV7 electrical system according to the Z-12
architecture and want to make the fusible link from the aux
alternator to the starter contactor depicted in the diagram. Bob's
online article about fabricating a fusible link and the B&C kit say
that it only applies to 22 and 24AWG fusible links, whereas the Z-12
diagrams lists a 16AWG fusible link. Can't find a resource that
explains how to do this. Help?
Thanks all
nuckollsr(at)cox.net Guest
Posted: Sat Jun 03, 2006 7:17 am Post subject: 16AWG fusible link |
At 07:11 AM 6/2/2006 -0400, you wrote:
Thanks all
The "resources" are limited to the few postings I've
made on the topic. I've often suggested that while fusible
links are attractive for their simplicity and robustness
leading to a very low cost of ownership. However, they are NOT
a general replacement for fuses/breakers and should
not be considered for any applications beyond those suggested
in the Z-figures without some discussion.
Fusible links have fusing constants on a par with ANL style
current limiters. I.e. they'll carry many times their
"normal" rated current for many seconds and in this case,
the link WILL emit smoke and WILL require some over-sleeve
capable of preventing it's high energy operation from
damaging adjacent wires.
Therefore, fusible links in the z-figures are noteworthy
for their scarcity. Every place they've been shown has
been considered for the failure mode effects that might
cause the link to open along with probability that they'll
EVER be required to operate. The note on the fusible link kit
was not intended to limit their fabrication to the
smaller sizes. The kit is supplied with red-PIDG splices
which won't accept the 12AWG/16AWG combination cited in
figure Z-16 and elsewhere. I think the fiberglas/silicone
sleeving will work over the 16AWG link but you'll need a
yellow-PIDG (10-12AWG) splice. The sleeving will have to
go inside the insulation grip on the splice as opposed to
over the outside. I think the sleeving will stretch to
cover the outside of a blue-PIDG at the other end.
I'll use them wherever it seems to make sense but
suggest caution for expanding their use beyond those
applications cited in the drawings.
< with experiment. >
< --Lawrence M. Krauss >
