Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Sun Sep 16, 2012 12:25 pm Post subject: Silicone Hoses for the Rotax 912 / 914 |
Hello All
I have seen the advert for replacement Silicone Hoses for the Rotax 912/914.
I can not find any details or photo,s on Google, has any one fitted the new hoses and what is the cost of a full set for the Europa.
Alan
rlborger(at)mac.com Guest
Posted: Sun Sep 16, 2012 4:57 pm Post subject: Silicone Hoses for the Rotax 912 / 914 |
Alan,
I have installed a set of the silicone hoses and they work great. You can see pictures of the hoses and their installation in my build diary:
http://www.europaowners.org/main.php?g2_itemId=66265&g2_page=4
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Sep 16, 2012, at 3:25 PM, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hello All
Alan
Alan Carter
Posted: Mon Sep 17, 2012 5:19 am Post subject: Re: Silicone Hoses for the Rotax 912 / 914 |
Hello rlborger.
1.Thanks for photo,s, the complete set counted from your photo,s seem to be eight hoses in total.
2.I notice that the hoses are thinner than the rubber ones , do you know of the advantages of Silicone do they last longer?,
In your photo,s the rubber ones look more sturdy in appearance .
3. The hose clips, see you use the spring type and not the screw up type.
is there a reason for this.
4. How long in time does a complete hose change take on average.
5.What did the silicone hoses cost approx.
I checked the price of the Rotax 5 year rubber change kit, yesterday and was told £605 $985
Alan
paul.the.aviator(at)gmail Guest
Posted: Mon Sep 17, 2012 6:00 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Hello Alan,
I can answer some of your questions:
There are hoses for each cylinder head and two larger diameter hoses that go to the coolant radiator.
I can't say what the expected life of the hoses are, however if you keep them free of oil or gasoline then I expect that these would last the life of your engine. Mine are not showing any signs of deterioration after 4 years
The CTC clips are highly desirable. They allow for expansion and contraction due to temperature. In my case, my hanger is not heated so the aircraft can get down to -15c or lower.
All but one of the hoses are easy to change. One of the hoses on the underneath is difficult and I don't know an easy way to changing it. Perhaps others on the forum could help.
Paul
On Mon, Sep 17, 2012 at 8:19 AM, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
| Quote: | --> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hello rlborger.
Alan
Posted: Mon Sep 17, 2012 6:21 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Hi Alan,
1. You are welcome. Yes, there were 8 hoses shipped, including the two hoses for the intercooler. Some of these are cut to length for shorter hose. The intercooler hoses must be cut to fit. If you do not have an intercooler, you'll jus have a single hose from the turbo to the airbox.
2. The silicone hose is virtually permanent and should never require replacement. The rubber are not more sturdy. They will degrade over time and MUST be replaced on a regular basis.
3. The coolant hose require spring clips as the coolant fixtures to which the hose attach, expand and contract with the coolant temperature. If you use a screw clamp and tighten it fully when cold when the engine warms up, the fixture expands and forces the hose into the screw clamp. This causes eventual cutting and failure of the hose. If you adjust the screw clamp when the engine is warm, then the fixture shrinks when it cools, it becomes loose and leaks. The spring clamps are constant tension clamps which account for the expansion and contraction of the fittings keeping things properly tight.
4. Depends on what stage in the build. I believe you are working on a completed, flying aircraft. It will take you longer as you will have to do some disassembly to get at the hose fittings and then reassemble things after the hoses have been replaced. I'd bet that the disassembly/reassembly takes longer than the actual hose replacement which is pretty quick, half hour to an hour maybe. Since I'm not familiar with your aircraft and engine installation, I can only make a very wild guess as to how long the disassembly/reassembly might take. Probably you could accomplish the total task in 1 or 2 days if you are very good with tools and have everything you need at hand. Is there another Europaphile anywhere near you who has done this task and could assist you. Probably make things go a lot quicker.
5. That was five years ago. I do not remember. Contact Stepahn Ingemarson, he'll give you a current quote.
For £605 $985, I'd check with Stephan. If you are going to have to replace the hoses anyway, why not do it right and go silicone.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Sep 17, 2012, at 8:19 AM, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hello rlborger.
Alan
kevinmarie(at)blueyonder. Guest
Posted: Mon Sep 17, 2012 6:43 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
I have fitted a whole set they are great about 200€ if I remember correctly.
Kevin Challis
On 16 Sep 2012, at 22:25, "Alan Carter" <alancarteresq(at)onetel.net> wrote:
Hello All
Alan
http://forums.matronics.com/viewtopic.php?p=383251#383251
churchy
Posted: Mon Sep 17, 2012 7:17 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Thanks for sharing all that learning. I am also contemplating the silicon hoses and I have the add on carb heaters which require coolant water round their jackets. Do you have those too and if so do you need extra hose to connect those or is there enough n the kit?
Richard CC
On 17 Sep 2012, at 15:21, Robert Borger <rlborger(at)mac.com> wrote:
Hi Alan,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Hello rlborger.
Alan
Posted: Mon Sep 17, 2012 10:37 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Richard,
I do not have the carb heaters on my engine so I can not help with this question.
I suggest you contact Stepahn Ingemarsson and ask him. Perhaps he can provide additional hose if it is needed.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Sep 17, 2012, at 10:16 AM, RCC Sky Mail <richard.churchill-coleman(at)sky.com> wrote:
Richard CC
frans(at)privatepilots.nl Guest
Posted: Mon Sep 17, 2012 11:04 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
On 09/17/2012 05:16 PM, RCC Sky Mail wrote:
| Quote: | Thanks for sharing all that learning. I am also contemplating the
Just do a search for "silicon hoses" on google (or better yet,
www.startpage.com wich has the same results but doesn't abuse your
search words for marketing purposes) and you will see that you can get
silicone hoses in all sizes, dimensions and configurations you want.
Basically, for a Rotax you need one meter (3 feet) of straight 16mm
hose, and one 90 degree elbow. For the carb heat I guess you need to
have T-pieces, which again you can order in any configuration and colour.
Frans
zwakie
Posted: Mon Sep 17, 2012 11:17 am Post subject: Re: Silicone Hoses for the Rotax 912 / 914 |
Richard,
Stefan I. has informed me that as of a few weeks ago, the silicon hoses are available for the carb heater. He will deliver 6mm reinfored silicon hose in 1 meter lengths for that, I do not have price for that available however.
A normal set (without the carb heat) was quoted to me recently for a little over € 300 (my plane is a classic, if I remember correctly the set for an XS was just under € 300)
_________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
mau11(at)free.fr Guest
Posted: Mon Sep 17, 2012 11:39 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Hello,
I use carb heater on my 912 during 9 years, and now 4 years on my 912S the durit is original supply by Skydrive, without problem.
It is not silicone durit.
Michel AUVRAY
Date: 2012-09-17 20:36
To: europa-list (europa-list(at)matronics.com)
Subject: Re: Re: Silicone Hoses for the Rotax 912 / 914
--> Europa-List message posted by: Robert Borger <rlborger(at)mac.com>
Richard,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
--> Europa-List message posted by: RCC Sky Mail <richard.churchill-coleman(at)sky.com>
Richard CC
sp;The Europa-List Email Forum -
avigator to browse
bsp;List Un/Subscription,
bsp;Browse, Chat, FAQ,
?Europa-List
p; - MATRONICS WEB FORUMS -
;via the Web Forums!
p; - List Contribution Web Site -
;support!
p; -Matt Dralle, List Admin.
ion
kheindl(at)msn.com Guest
Posted: Mon Sep 17, 2012 2:43 pm Post subject: Silicone Hoses for the Rotax 912 / 914 |
Michel,
Did you ever have a need to switch on the carb heat, or is it on permanently ?
I am contemplating removing mine again . It was only installed because of regulations, and yet I notice that factory built aircraft in Canada don't have the heater.
Karl
Date: Mon, 17 Sep 2012 21:38:12 +0200
Subject: Re: Re: Europa-List: Re: Silicone Hoses for the Rotax 912 / 914
Hello,
Michel AUVRAY
Richard,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Richard CC
avigator to browse bsp;List Un/Subscription, bsp;Browse, Chat, FAQ, ?Europa-List ============= p; - MATRONICS WEB FORUMS - ;via the Web Forums! ============= p; - List Contribution Web Site - ;support! p; -Matt Dralle, List Admin. ion =============
target="_blank">http://www.matronics.com/Navigator?Europa-List
Posted: Mon Sep 17, 2012 10:30 pm Post subject: Silicone Hoses for the Rotax 912 / 914 |
The carb heaters need extra hose but I got these on eBay quite cheap.
Kevin Challis
G ODJG
On 17 Sep 2012, at 17:16, RCC Sky Mail <richard.churchill-coleman(at)sky.com> wrote:
Richard CC
> Hi Alan,
> Bob Borger
> 3705 Lynchburg Dr.
> Cel: 817-992-1117
> rlborger(at)mac.com
> Hello rlborger.
> Alan
Alan Carter
Posted: Tue Sep 18, 2012 1:55 pm Post subject: Re: Silicone Hoses for the Rotax 912 / 914 |
Hi. rlborger(at)mac.com and All.
Yes my aircraft is flying, i am planning a complete hose change this winter.
Skydrive quoted me £610 for the rubber type, but i have e-mailed Stefan for a price list of the Silicone hoses, i will get the clips you suggested,
At the moment on Evens none water coolant, so plan to continue using this coolant, its expensive at £68 for 5 litres.
I am in a nice big hanger, but due to cost i am moving to a farm metal framed (^^) shaped hanger, covered, but open at one end, so it will get down to say - 10 on the coldest nights.
Alan
churchy
Posted: Thu Sep 27, 2012 6:38 am Post subject: Silicone Hoses for the Rotax 912 / 914 |
Marcel, Bob, others
Thanks for all your comments. One last request (on this subject) -
can anyone tell me the length of their coolant hose on an XS 912S
installation from the coolant system cap to the plastic coolant
overflow bottle as I need to order sufficient silicon hose from Stefan
in addition to the kit? Or is the bottle location an individual
choice on each firewall forward layout?
Richard
