A question to the American "Europeans"
sidsel.svein(at)oslo.onli
PostPosted: Sun Sep 16, 2012 11:47 pm    Post subject: A question to the American "Europeans" Reply with quote
NTSB issued in May a very interesting report on accidents with amateur-built airplanes compared to certified airplanes, based on detailed evaluation of the numbers behind the summary statistics:
http://www.ntsb.gov/doclib/reports/2012/SS1201.pdf
One of their findings is that many more accidents caused by loss of control in the air happen with amateur-built than with certified airplanes, and that a high percentage is with second-hand airplanes a short time after being purchased. NTSB points to the fact that FAA do not follow the same practice as many other countries do, in that FAA do not require a pre-approved test flight program, nor approval of a report on the test flying (only a log book entry that test flight has been completed), which in turn may cause the pilot’s operating handbook/flight manual to be lacking important airplane characteristics.
What the NTSB report do not say anything about, however, is mandatory transition training and check out in the specific amateur-built airplane. Under the joint European pilot license regime (JAR-FCL), we must receive such training and have it entered in our log book. This means that before we can fly the Europa we have built (unless approved by our CAA to perform the very first flight) we must receive such airplane-specific rating, and also before we may pilot another Europa than our own, no matter how many hours we have logged in our own plane and irrespective of all the similarities between two individual Europas.
Therefore the following question to the American Europeans on this forum: Before you can legally be the pilot of ANY experimental classed, amateur-built airplane, are you not required by FAA to receive transition training/rating check-out by a pre-approved CFI or other experienced, approved person, even for flying a “sister” airplane of the same type and model that you may already be experienced in?
Svein
LN-SKJ
davidjoyce(at)doctors.org
PostPosted: Mon Sep 17, 2012 1:09 am    Post subject: A question to the American "Europeans" Reply with quote
Svein, This isn't an answer to your question and indeed it
comes from the wrong side of the pond, but after reading
the report and noting that 44% of the US fatal accidents
are realted to loss of control in the air (effectively
stall spin accidents) it occurred to me that our
transatlantic friends might be interested in the article
recently published over here in the LAA mag. If taken
seriously I believe it would savea lot of the 44% from a
nasty end. The pictures have been removed to (hopefully)
allow it to travel, but no doubt you can use your
imagination.
Regards, David Joyce, G-XSDJ
On Mon, 17 Sep 2012 09:46:38 +0200
"Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
<http://www.ntsb.gov/doclib/reports/2012/SS1201.pdf>
by loss of control
airplanes, and that
time after being
follow the same
require a
report on the test
turn may cause the pilot's operating handbook/flight
is mandatory
we must receive
means that before
our CAA to perform
matter how many
of all the
classed,
receive transition
experienced,
approved person, even for flying a "sister" airplane of
the same type and
Svein
LN-SKJ
Stall_spin_a.doc
 Filename:  Stall_spin_a.doc
 Filesize:  2.11 MB
 Downloaded:  335 Time(s)
Remi Guerner
PostPosted: Mon Sep 17, 2012 3:28 am    Post subject: Re: A question to the American Reply with quote
Svein,
Where did you see that the JAA FCL require specific training for flying a home built ? As far as I know, here in France, all we need to legally fly any Europa, including for its first flight, is a valid Class SEP (Single Engine Piston) Private Pilot License, a valid class 2 medical and 3 take offs and 3 landings in an airplane of the same Class during the last 90 days. An airplane of the same class could be any single engine piston. For the monowheel, you need to have a tail-dragger and a retractable gear endorsements on your log book. For the motorglider, you need a Class TMG (touring motorglider) PPL.
Of course being legal does not mean being safe !
Remi Guerner
F-PGKL
wdaniell(at)etb.net.co
PostPosted: Mon Sep 17, 2012 4:53 am    Post subject: A question to the American "Europeans" Reply with quote
Where do I get a Barbara (smartass)?
Will
rlborger(at)mac.com
PostPosted: Mon Sep 17, 2012 5:08 am    Post subject: A question to the American "Europeans" Reply with quote
Svein, et. al.,
Big old Catch 22 over here in FAA land. To do a proper checkout one must have a CFI to do the instruction. The CFI normally will charge for their instruction time. But one is not allowed to earn income through the use of an experimental amateur built aircraft. So try to find a qualified CFI with experience in the transition aircraft who will do it for no charge.
I happen to have a friend who is a CFI but is not a professional flight instructor. He has given me and others proper checkouts in various experimental amateur built aircraft for not charge. Guys like that are darn few and far between over here.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com (rlborger(at)mac.com)
On Sep 17, 2012, at 2:46 AM, Sidsel & Svein Johnsen <sidsel.svein(at)oslo.online.no (sidsel.svein(at)oslo.online.no)> wrote:
Svein
LN-SKJ
PostPosted: Mon Sep 17, 2012 5:12 am    Post subject: A question to the American "Europeans" Reply with quote
Will, Look up www.smartavionics.com It is run by Mark
Burton ex Europa builder/pilot who also makes the CS prop
controllers that a lot of Europas use. Regards, David
Joyce
On Mon, 17 Sep 2012 07:52:39 -0500
Will
peterz(at)zutrasoft.com
PostPosted: Mon Sep 17, 2012 5:39 am    Post subject: A question to the American "Europeans" Reply with quote
In Canada it's my understanding that it's just an insurance question for hull coverage - which typically is not taken until their requisite number of hours is obtained.
Pete
A239
Ottawa, Canada
On Mon, Sep 17, 2012 at 9:08 AM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
[quote] Svein, et. al.,
Bob Borger
3705 Lynchburg Dr.
Cel: [url=tel:817-992-1117]817-992-1117[/url]
Svein
LN-SKJ
cjaussi(at)gmail.com
PostPosted: Mon Sep 17, 2012 12:06 pm    Post subject: A question to the American "Europeans" Reply with quote
It is my understanding that you can obtain flight training even for a PPL in your own experimental aircraft and pay the instructor. This would be a good question to ask EAA.
On Sep 17, 2012, at 7:38 AM, Peter Zutrauen <peterz(at)zutrasoft.com (peterz(at)zutrasoft.com)> wrote:
[quote]In Canada it's my understanding that it's just an insurance question for hull coverage - which typically is not taken until their requisite number of hours is obtained.
Pete
A239
Ottawa, Canada
On Mon, Sep 17, 2012 at 9:08 AM, Robert Borger <[url=mailto:rlborger(at)mac.com]rlborger(at)mac.com (rlborger(at)mac.com)[/url]> wrote:
Svein, et. al.,
Bob Borger
3705 Lynchburg Dr.
On Sep 17, 2012, at 2:46 AM, Sidsel & Svein Johnsen <[url=mailto:sidsel.svein(at)oslo.online.no]sidsel.svein(at)oslo.online.no (sidsel.svein(at)oslo.online.no)[/url]> wrote:
Svein
LN-SKJ
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
ums.matronics.com">http://forums.matronics.com
http://www.matronics.com/contribution">http://www.matronics.com/contribution
rehn(at)rockisland.com
PostPosted: Mon Sep 17, 2012 3:46 pm    Post subject: A question to the American "Europeans" Reply with quote
That is correct. In USA, Part 91.319 in FAR provides for compensation for a flight instructor in your experimental aircraft.
On Sep 17, 2012, at 1:05 PM, Curtis <cjaussi(at)gmail.com (cjaussi(at)gmail.com)> wrote:
[quote]It is my understanding that you can obtain flight training even for a PPL in your own experimental aircraft and pay the instructor. This would be a good question to ask EAA.
Pete
A239
Ottawa, Canada
On Mon, Sep 17, 2012 at 9:08 AM, Robert Borger < (rlborger(at)mac.com)rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
Svein, et. al.,
Bob Borger
3705 Lynchburg Dr.
On Sep 17, 2012, at 2:46 AM, Sidsel & Svein Johnsen < (sidsel.svein(at)oslo.online.no)sidsel.svein(at)oslo.online.no (sidsel.svein(at)oslo.online.no)> wrote:
Svein
LN-SKJ
cs.com
rampil
PostPosted: Wed Sep 19, 2012 6:42 am    Post subject: Re: A question to the American Reply with quote
In the US there is no regulatory requirement for specific type training
below 12,500 lbs or turbine.
There is usually an insurance issue however with coverage at a reasonable
price is no or minimal experience is an issue.
BTW the accidents in the NTSB report have been discussed before.
They are mostly in high performance AC like the Lancair family with
high wing loading, and able to shed airspeed at the momentary drop of
attention.
Ira N224XS
AirEupora
PostPosted: Wed Sep 19, 2012 8:52 am    Post subject: Re: A question to the American Reply with quote
I am a professional flight instructor and teach almost every day. It was interesting when I applied for my airplane insurance. The company wanted me to have three hours in make and model. I put the word out on the web asking for somebody to give me the three hours. I'd paid for the gas, but the only response was from Bud. The trip out to Florida would have cost me at lease a thousand dollars. Figure three days, one out and one back then one day for the flight. After not getting any local help I called the Insurance company and explained my problem. They changed the three flight hours to three hours of ground training. I talked to Bud and took off on my first flight with the understanding that I might not have insurance for the first three hours.
As an Instructor I have to have five hours of flight time in any aircraft that I give instruction in. Getting those five hours have been difficult. My hangar mate has a Cozy IV and he has asked me to fly it for the first flight, but I don't have the time in the plane plus the insurance company is requiring 25 hours of time.
In the U.S. the insurance requirements are the main issue. Some of the better Experiential airplane company have a team of pilots that give the would be owner the training. I went up to VAN's and got an hour in an RV-8. Love it. The pilot that I flew with had over a thousand hours in the RV-8 and the like products.
I have offered my services to Bud, but I don't have the mono wheel training in the Europa. Mine is a tri- gear. Then there is the conventional gear Europa.
I have over 13 thousand hours in helicopters and airplanes. I have been to a number of accident sites of homebuild's and went through the FAA school on home build aircraft. It was fun as the instructors did not like the home build aircraft and made it know during class. The biggest problem is with the builder pilot. They have been building the aircraft for 3 to 10 years. They want to get it flying. They have not followed the AC's. They are not current. The aircraft as not been inspected by enough people. I believe I had over ten people look at my plane and I'm and A&P/AI. Each one found something that need attention. A lot of the pilots flight skills are not up to the level that they should be. They have not taken advantage of the EAA Tech Councilor program or the Flight Advisor program.
We had one EAA member sell his RV-6 and he offered to give the guy some flight training in the plane before he took it home. He refused the training. He crashed the plane on landing at his home base.
I give a class every year at the EAA West Coast flight in on "First Flight" I only get about ten people each year. It was great this year, as that morning, I had taken my first flight in the Europa. It only lasted six minutes, but I had flown it.
jimpuglise(at)comcast.net
PostPosted: Wed Sep 19, 2012 11:35 am    Post subject: A question to the American "Europeans" Reply with quote
Rick-
When I explained to my insurance company that I could not get Europa time, they let me fly a Liberty for 2 hours, instead of the Europa. Going from the Liberty to the Europa is like moving from a Mac truck to a Porsche. I understand perfectly what you are saying. I now have about 10 hours in my Europa but have not flown it for four months and will try to get some more dual before I fly it again. I did something highly illegal and went around the patch a few times with an experienced Europa CFI in my plane before I flew it. The current structure of the law is just not safe. I'd sure like to see EAA lobby for some better regulations for the transition.
Jim Puglise
N283JL
Sent: Wednesday, September 19, 2012 12:52:15 PM
Subject: Re: A question to the American "Europeans"
--> Europa-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net>
http://forums.matronics.com; -Matt Dralle, List Admin.========
rlborger(at)mac.com
PostPosted: Wed Sep 19, 2012 11:57 am    Post subject: A question to the American "Europeans" Reply with quote
Jim,
I did the same thing in my Monowheel. I read the FARs and interpreted them as this was OK. You can only have those crew on board who are necessary for the safe completion of the flight. I saw a CFI as being necessary for the safe completion of the flight.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
On Sep 19, 2012, at 2:34 PM, jimpuglise(at)comcast.net (jimpuglise(at)comcast.net) wrote:
Rick-
Jim Puglise
N283JL
craigb(at)onthenet.com.au
PostPosted: Wed Sep 19, 2012 12:33 pm    Post subject: A question to the American "Europeans" Reply with quote
As you said very informative post, and something to think about for those of
us
Getting close to getting in the air. In Australia our babies have a placard
fitted
Stating the aircraft is "Experimental" and not required to meet normal
airworthiness standards.
Regards and good building
craig
PostPosted: Wed Sep 19, 2012 1:11 pm    Post subject: A question to the American "Europeans" Reply with quote
Bob-
That is what we figured we would tell the FAA if we were checked. Better to ask forgiveness than permission.
Jim
Sent: Wednesday, September 19, 2012 3:55:47 PM
Subject: Re: Re: A question to the American "Europeans"
Jim,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
Rick-
Jim Puglise
N283JL
rlborger(at)mac.com
PostPosted: Wed Sep 19, 2012 1:31 pm    Post subject: A question to the American "Europeans" Reply with quote
Jim,
We actually had a visit from someone from the local FSDO. Explained to him what we were doing in those terms and the fellow kinda shrugged and said it made sense to him.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
On Sep 19, 2012, at 4:11 PM, jimpuglise(at)comcast.net (jimpuglise(at)comcast.net) wrote:
Bob-
Jim
From: "Robert Borger" <rlborger(at)mac.com (rlborger(at)mac.com)>
Jim,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
Rick-
Jim Puglise
N283JL
href="3D"http://www.matronics.com/Navigator?Europa-List"">http://www.matronics.com/Navigator?Europa-List
href="3D"http://forums.matronics.com"">http://forums.matronics.com
href="3D"http://www.matronics.com/contribution"">http://www.matronics.com/contribution
