Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Fri Sep 14, 2012 2:21 pm Post subject: Re: Rotax 914 Oil Change |
Hi All.
The Magnetic plug, mine is the old stile Allen Key type, the new ones have an Hexagonal head so you can use a socket,
The cost is $63 in the UK and $52 in the States.
So if i want a new one it going to cost me £40, plus P/P
Do the magnets get weak over time, and is there a way of re magnetizing them.??
Alan
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rlborger(at)mac.com Guest
Posted: Fri Sep 14, 2012 2:32 pm Post subject: Rotax 914 Oil Change |
Alan,
You'll never have to replace it because of loss of magnetism.
Take care when tightening and you'll never have to replace it again.
Best regards,
Robert Borger, President
Geowhiziks & Doodlebugging, Inc.
Certified Petroleum Geophysicist AAPG#101
3705 Lynchburg Dr.
Corinth, TX 76208-5331
(H) 940-497-2123
(C) 817-992-1117
Sent from my iPad
On Sep 14, 2012, at 17:21, Alan Carter <alancarteresq(at)onetel.net> wrote:
Hi All.
Alan
http://forums.matronics.com/viewtopic.php?p=383120#383120
Roger Lee
Posted: Fri Sep 14, 2012 4:13 pm Post subject: Re: Rotax 914 Oil Change |
Hi Alan,
It probably isn't an Allen wrench for the mag plug on your old one. It is a #40 Torx. If you use an Allen you'll strip it out.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Alan Carter
Posted: Sat Sep 15, 2012 12:39 am Post subject: Re: Rotax 914 Oil Change |
Hi Chaps.
Before doing the job i carefully looked a it, the sides of the hole they were flat and the best fit seemed to be Allen Key , as the side of the hole had no inward curves, it hard to tell it may have been worn, but looked more Allen key, i used an Allen key on a 1/4" socket extension which did the job,
I have a question,
Why can,t i put some Araldite on the little "Allen Key adaptor Bit" and knock it tightly into the hole and let it set.
So next time i can put my hard metal socket on the hard metal key inset in the plug.?
Alan
BARRY CHECK 6
Posted: Sat Sep 15, 2012 3:03 am Post subject: Rotax 914 Oil Change |
Alen:
The EPOXY will more than likely be softer than the material of the plug. But, if the edges of the plug are deformed, yes, give it a try. As they say : "It can't houit".
Question(s):
What is the plug made of?
What is the threaded hole made of?
Is there a Heli-Coil in the threaded hole?
I think the solution is very simple for all these problems.
Barry
On Sat, Sep 15, 2012 at 4:39 AM, Alan Carter <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)> wrote:
[quote]--> RotaxEngines-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net (alancarteresq(at)onetel.net)>
Hi Chaps.
I have a question,
Alan
http://forums.matronics.com/viewtopic.php?p=383149#383149
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
le, List Admin.
Roger Lee
Posted: Sat Sep 15, 2012 6:36 am Post subject: Re: Rotax 914 Oil Change |
Hi Alan,
I think it would be better to just do it the right way. It will save you time, effort and money in the long run. The 16mm hex head mag plug would be the better way to go.
Tucson, Az.
Cell 520-349-7056 |
bob(at)fly-ul.com Guest
Posted: Sat Sep 15, 2012 8:51 am Post subject: Rotax 914 Oil Change |
Quote: | Why can,t i put some Araldite on the little "Allen Key adaptor Bit" and knock it tightly into the hole and let it set.
I agree with Roger. Why complicate things? Do it the right way, and forget all this adapter/epoxy nonsense.
Alan Carter
Posted: Tue Sep 18, 2012 2:21 pm Post subject: Re: Rotax 914 Oil Change |
Hi All.
Today i cut open the oil filter, this is the first oil filter i have cut open,
but my gut feeling tells me this was the first time anybody has bothered to do it on this aircraft, and from what i feel many others the same.
However, i do not know what is acceptable in the filter.
I could not see any large particles of 1 mm or 1/2 mm, I could see brown carbon deposits, I then looked at the paper in the sunlight and could not see any metal on the oil covered paper.
However after throwing it away i noticed my fingers felt a bit gritty to small to see, but i could see a few very small pin head of silver in the sunlight, very small,and it was not apparent when inspecting the paper .
As a green horn i would say all was OK , what do you think.
Alan
Roger Lee
Posted: Tue Sep 18, 2012 8:01 pm Post subject: Re: Rotax 914 Oil Change |
Hi Alan,
Sounds like all was okay.
If you really want to see what's in an oil filter. Cut the paper element out. Put it in a small jar with about 1" of fuel and shake it up fairly well. The remove the filter and look at it. It will most likely be very clean as the fuel washed it off. Now pour the fuel and oil residue through a white paper towel. What ever was on that filter element will now stand out like a sore thumb against the white paper towel surface. Usually I only see a few carbon flecks and once in a while a chrome colored fleck.
Tucson, Az.
Cell 520-349-7056 |
Alan Carter
Posted: Wed Sep 19, 2012 1:59 pm Post subject: Re: Rotax 914 Oil Change |
Thanks Roger.
That,s a very good way to check it, I will remember that for next time i cut the filter open,
Alan
artglaser(at)sbcglobal.ne Guest
Posted: Wed Sep 19, 2012 3:22 pm Post subject: Rotax 914 Oil Change |
How about a coffee filter? Might be a better filter than a paper towel.
Sent: Tue, September 18, 2012 11:07:30 PM
Subject: Re: Rotax 914 Oil Change
--> RotaxEngines-List message posted by: "Roger Lee" <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)>
Hi Alan,
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p href="http://www.matronics.com/Navigator?RotaxEngines-List" target=_blforums.matronics.com/" target=_blank>http://forums.matronics.com
_ -Matt Drallntribution" =======
Roger Lee
Posted: Wed Sep 19, 2012 6:41 pm Post subject: Re: Rotax 914 Oil Change |
A coffee filter is fine.
Tucson, Az.
Cell 520-349-7056 |
