HS done! Elevators next
LIKE2LOOP(at)aol.com
PostPosted: Sun Jun 04, 2006 7:28 am    Post subject: HS done! Elevators next Reply with quote
Here is my HS, "flying" from the garage ceiling.
   I closed the rudder with the new version of the Proseal, in the self mix caulk tube. Very easy to work with, lots of extra mixed material wasted..... clean up is easy if you dont touch the stuff.  I was able to dispense directly to the inside surface of the right skin, then place the trailing edge piece a few clecos from underneath, and add a layer of proseal and then the left skin, without touching the stuff.
Steve
Stephen Blank             RV-10 Builder #40499        Cessna 170B flyer
766 SE River Lane                      Trimming elevator ribs........
Port St. Lucie, FL 34983
772-475-5556 cell - evenings and weekends
 Filesize:  28.49 KB
 Viewed:  383 Time(s)
jjessen
PostPosted: Sun Jun 04, 2006 7:44 am    Post subject: HS done! Elevators next Reply with quote
Looks like it's flying pretty good.  Nice job.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LIKE2LOOP(at)aol.com
Sent: Sunday, June 04, 2006 8:28 AM
Subject: HS done! Elevators next
[img]cid:426494315(at)04062006-188E[/img]
Steve
 Filesize:  28.49 KB
 Viewed:  383 Time(s)
bldgrv10450(at)comcast.ne
PostPosted: Sun Jun 04, 2006 11:05 am    Post subject: HS done! Elevators next Reply with quote
If you still need to complete your elevator trims, I have wood clamp blocks for you.
Paul Grimstad,
RV10-40450, assembling tailcone
 Filesize:  28.49 KB
 Viewed:  376 Time(s)
Mike Whisky
PostPosted: Tue Jun 06, 2006 5:30 am    Post subject: Re: HS done! Elevators next Reply with quote
Good job, any heads up for me regarding the HS, because I just started it now.
Best Regards
Michael
www.wellenzohn.net
RV-10 builder (flying)
#511
