Alan Carter
Joined: 02 Jul 2012 Posts: 378 Location: Kent, England.
Posted: Fri Oct 05, 2012 2:13 pm Post subject: Auxiliary Power Supply |
Hi All
I want to install two cigar lighter power supplies in the instrument panel.
Usage will mainly be to charge my iPad and Phone, or maybe other things.
I was planing to run a cable (aircraft cable ??? watts) directly from the Battery + and return to the Battery - with an in-line fuse, Amps ???
The Battery is located in the rear fuselage .
Any Comments or Help.
Alan
[/u]
brian.davies(at)clara.co. Guest
Posted: Sat Oct 06, 2012 12:08 am Post subject: Auxiliary Power Supply |
Hi Alan,
Although your plan would work it is not the best arrangement. On most
Europas there will be a positive supply electrical bus bar somewhere behind
the instrument panel that is controlled by a battery master switch. It would
be better to take a connection from there and use a panel mounted fuse or
circuit breaker to protect the wiring to the cigar lighter sockets. You
should also be able to find a negative bus bar or connection stud behind the
panel. The size of the cable and then the size of the fuse/ circuit breaker
will be determined by what you intend to connect to the sockets. If you are
not going to take more than 5amps you could use 22 gauge wire and a five amp
fuse. As you are planning to have two sockets it is probably best to use 20
gauge and maybe a 7 or 10 amp fuse.
It is important to be able to disconnect all electrical supplies in an
emergency so it is not good practice to connect things directly to the
battery.
Brian Davies
pete(at)lawless.info Guest
Posted: Sat Oct 06, 2012 12:56 am Post subject: Auxiliary Power Supply |
Morning Alan
When you take the panel out you should find a power and negative bus in the
back fed directly from the battery. I suggest you take the power from that
via a CB. Trouble with in line fuses in the back of the panel is that it
makes a big job just to change a fuse unless you have easy access.
Pete
Alan Carter
Posted: Sat Oct 06, 2012 2:26 am Post subject: Re: Auxiliary Power Supply |
Good Morning to you Both.
Yes , that all makes good sense, and that,s what i will do.
I was a bit reluctant about going in behind the panel, but hopefully i will be able to do it.
The making the new little panel plate and fixing i can manage ok.
I will make sure i use a good crimping tool, will post a photo when finished, but allow up to six weeks.
Ps, Would like to find the approx 1/2"x1/2" square black push button CB to match the ones i have, ?? have not seen any yet.
Alan
Posted: Sat Oct 06, 2012 5:26 am Post subject: Auxiliary Power Supply |
Alan,
Europa used to stock them- worth a try. They are also sold by RS (ETA 1100
series).
Brian
danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Sat Oct 06, 2012 5:46 am Post subject: Auxiliary Power Supply |
also try matthew-russell-ltd.co.uk I bought some quite a few years ago. I'm sure he still suplies them.
Rgd Danny G-ceri
On 06/10/2012 14:25, Brian Davies wrote:
[quote] [quote]--> Europa-List message posted by: "Brian Davies" <brian.davies(at)clara.co.uk> (brian.davies(at)clara.co.uk) Alan, Europa used to stock them- worth a try. They are also sold by RS (ETA 1100 series). Regards Brian --
