teamgrumman(at)yahoo.com Guest
				 Posted: Sat Oct 06, 2012 7:15 pm    Post subject: Jaguar Cowling |
				----- Forwarded Message -----
  To: Gary L Vogt <teamgrumman(at)yahoo.com>
  Sent: Saturday, October 6, 2012 12:27 AM
  Subject: Re: Jaguar Cowling
  Gary
 Yes, I guess about 5 knots (which I use to offset fuel).
 The big thing is even temps.  My CHTs have evened out.  #3 used to be hot.  Now it as cooled about 15F and evened out, which is good in the weather we fly in.
 Andrew
 On Sat, Oct 6, 2012 at 4:38 PM, Gary L Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
  [quote]Looks real good Andrew. Thanks for the pics.
 Any flight experiences with it yet?
 Gary
 Sent from my iPad
 On Oct 5, 2012, at 8:53 PM, Andrew Kerans <aksnarek(at)gmail.com (aksnarek(at)gmail.com)> wrote:
  	  | Quote: | 	 		  Hi Gary
 Here are some fitting pics.  I did take post painting pics, but now I can't find them    Sorry it took so long, since LA I have been to Singapore and Da Nang.  Bridget is now in LA!!
 Will keep looking.
 By the way, I glued 'zircoflex' beneath the powerflow at the front, it really keeps the cowl cool now.  I know you think it wasn't needed, but I took some temp probe readings in the cowl in flight and from in front of the cowl and showed the to the materials guys at the Uni where I am adjunct, they said that eventually the fibreglass may break down or distort.  So it went on
 It is quite cheap and easy to do with cowls off.  In Aust it is like your 347, just a logbook entry as it doesn't alter th actual cowl in any way.
 Andrew
   On Sat, Aug 11, 2012 at 6:34 AM, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
  	  | Quote: | 	 		    Thanks Andrew,
 I'll update the web page.  When you get a chance, send a pic.
 Gary
      From: Ak <aksnarek(at)gmail.com (aksnarek(at)gmail.com)>
    To: Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
  Sent: Thursday, August 9, 2012 5:47 PM
  Hi
 Yes i have a lot of fitting and pot painting pics, they are at home, I am on holidays in the North because I have had enough of winter.  We took the Grumman, its a ten hour flight.
 Comments so far:
 I guesstimate a 5 knot TAS improvement.
 CHTs are now all below 420 even on climb.  Previously my #3 would exceed 450 unless climb was faster than 90 kt.
 Fitting went well, I have since had an EDM 830 fitted, the LAME (A & P) found the cowl easy to remove/replace.
 Original fit the LAME allowed breather to drain to cowl.  Yuk!  I have since added air oil separator and the breather goes through gear leg opening.
 In hot air (30C) front of cowl got very hot.  We added teflon heat shield from aircraft spruce and it is now fine.  (zircoflex).
 Suggested improvements?  I would reinforce and add camlock instead of screw for upper cowl.
 Andrew
 Sent from my iPad
 On 08/08/2012, at 13:10, Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
  	  | Quote: | 	 		  Andrew,
 I'm working on a new web page for my web site.  It's going to have pics and comments from the owners and installers.  If you could, please, send me some pics and comments on  your experiences with the cowling.
  I'm looking for things like:
    ʉۢ ease of maintenance
     • quality of fabrication on the cowling
     • CHT spread
    ʉۢ change in fuel consumption
     • change in cruise speed
     • installation instructions, clear or not
     • any problems with the cowling
     • reason for wanting/buying the cowling
  Thanks Andrew.  I appreciate the support.  Looking forward to hearing from you and your experiences with the Jaguar Cowling.
  Gary
   PS, if you have a pic of your plane with the cowling, send it.  I'll put it on the internet.
 <cannon 722.jpg>
 <cannon 725.jpg>
 <cannon 729.jpg>
  |  | - The Matronics TeamGrumman-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?TeamGrumman-List |
