Using Dynon EMS together with VDO gauge
peterthomson
PostPosted: Tue Oct 09, 2012 1:09 am    Post subject: Using Dynon EMS together with VDO gauge Reply with quote
hi List
I have a Jabiru J170C which has VDO 3 wire (+, - and sensor) gauges and sensors for oil temperature and oil pressure. As sensor resistance increases, gauge values increase.
When I installed a Dynon D180. I ran a wire from the same gauge sensor wire to the Dynon. However, the values on the Dynon are not correct.
Is there a work-around to be able to use both measuring instruments (VDO and Dynon) with same sensor ?
thanks
Peter
peterthomson
PostPosted: Tue Oct 09, 2012 4:19 am    Post subject: Re: Using Dynon EMS together with VDO gauge Reply with quote
ooops .. as sensor resistance decrease on temp sensor, but increase on pressure sensor, gauge value increases....
I've now come across dual station sensors, which will support two gauges by two wires. Is there another way ?
thanks
Peter
paul.r.kuntz(at)gmail.com
PostPosted: Tue Oct 09, 2012 8:34 am    Post subject: Using Dynon EMS together with VDO gauge Reply with quote
Check the Dynon user forum on their web site. If the answer is not already available there, you can post your question and expect an answer within the hour from a Dynon tech
thanks
Peter
http://forums.matronics.com/viewtopic.php?p=384987#384987
PostPosted: Wed Oct 10, 2012 11:41 am    Post subject: Re: Using Dynon EMS together with VDO gauge Reply with quote
Have you selected the sensor type as described in the D-180 Installation Guide page 6-9?
Joe
http://www.dynonavionics.com/downloads/Install_Guides/FlightDEK-D180_Installation_Guide_Rev_H.pdf
Joe Gores
