Making a LED landing light flash
jerrytex
PostPosted: Mon Oct 15, 2012 11:53 am    Post subject: Making a LED landing light flash Reply with quote
I recently fitted an LED driving light into my wingtip. I am now interested in making it flash so I am more visible in the pattern. What is the best/cheapest way of doing this? I have seen the Wig Wag schematic but I only have one light and from what I read, it requires two lights to work.
PostPosted: Mon Oct 15, 2012 1:27 pm    Post subject: Making a LED landing light flash Reply with quote
Put a 50 ohm resistor in place of the second light.
http://tinyurl.com/9xbhdt6
Eric M. Jones
PostPosted: Mon Oct 15, 2012 4:02 pm    Post subject: Re: Making a LED landing light flash Reply with quote
I have experimented with this and it look like doubling the rate is the best way to go if you have only one lamp. Just leaving out the other lamp leaves a whole lot of empty time to not-be-seen. Try it. You'll like it.
I've made one-lamp flashers for some customers using this method.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Mon Oct 15, 2012 7:06 pm    Post subject: Making a LED landing light flash Reply with quote
You'll like it.
Agreed. I don't recall the authoritative source but
waaaayyyy back when, we were advised that cockpit
warning lights should be flashed at about 3 to
3.5 flashes per second with 50% duty cycle for
maximum attention getting effects.
I was told that's the number that works best for
intensity modulation (on-off) as opposed to 1 to
1.5 per second for position modulation (wig-wag).
Back when I worked with attorneys wrestling with
grade crossing accidents and various visibility
issues, we learned that visual acuity for 20/20
observer was about 1 arc-minute or 1/60th degree.
To perceive that a wig-wag grade crossing signal
(8 or 12" roundels on 30" centers) was not a steady
red light, the 20/20 observer who was paying attention
under good visibility conditions had to be less
than 8000' away. For the wig-wag to get some attention,
required about 3 arc seconds or a sight distance
of about 2800 feet. Of course, there are a dozen
other variables that drive the situation down-hill
from there.
If your wig-wags are on wing tips of an RV or
25 feet apart (10x the center distance on a
grade crossing wig-wag) then you can expect
pretty good attention grabbing presentation
in clear visibility to other pilots at about
28000 feet or 5+ miles and the 1 to 1.5
transitions/second values apply.
For intensity modulated warning systems (strobes,
rotating beacons, etc) the numbers are better
especially at the faster rate more likely to
grab attention. Unlike the wig-wag that simply
morphs into a steady light beyond a certain
distance, the strobe's on-off behaviors can
be detected from much greater distances.
mrspudandcompany(at)veriz
PostPosted: Tue Oct 16, 2012 4:13 am    Post subject: Making a LED landing light flash Reply with quote
Are you aware of any wig-wag studies on incondescent vs. LED
lighting of the same intensity? I would think that perhaps the LED with
it's crisp instant on would be an attention getter from a farther distance,
as opposed to the ramp up of light output from the other source.
What is your take on this?
Roger
PostPosted: Tue Oct 16, 2012 5:41 am    Post subject: Making a LED landing light flash Reply with quote
Are you aware of any wig-wag studies on incandescent vs. LED lighting
of the same intensity? I would think that perhaps the LED with it's
distance, as opposed to the ramp up of light output from the other source.
Not that I'm aware of. My middle son's mother-in-law
was a professor at KU who spent much of her academic
career studying the physiology of sight. Were she
still with us, I'm pretty sure she'd have a lot to
share . . . and direction to other sources.
Your mention for rate-of-rise in intensity is
perceptive. While I was at Cessna, about 1967, a company
called AeroFlash came out with a replacement for
the motorized rotating beacons that were the anti-
collision warning devices of choice in 1965.
These were single, halogen bulbs under a domed lens
that delivered the requisite intensity in all directions
at the same time. But instead of being a 30 watt bulb
at the center of a mechanical focusing/directing system,
these were 150 watt devices that were flashed electrically.
The filaments were so massive that the lamps were visibly
slower in both rise and fall of intensity than the legacy
rotating beacon. I remember seeing multiple aircraft at
night were one was fitted with the AF device while others
were sporting rotating beacons. The difference in visual
'force' for getting attention was obvious. But the regs
for qualifying such devices waxed eloquently about color,
intensity, flash rates and spherical coverage without the
slightest attention to rate of rise/fall for the emitted
energy.
I went to the bench last night an cobbled up a panel
mounted, incandescent annunciator light to renew my
recollected perceptions for flash rate and duty cycle.
The rise/fall characteristics of the incandescent lamp
was perceptible and my anecdotal musings with the knobs
on the function generator renewed and old bit of knowledge
that a 33% on 66% off was a bit more 'forceful' when
observed in peripheral vision. An LED substitute didn't
seem to have much difference at 33/66 vs 50/50.
My gut feeling is that lights which are flashed will
probably rattle the grey matter of distant pilots sooner
than lights which are simply wig-wagged. LED's are no doubt
better yet. Perhaps the ideal system would not only
alternate the lamps from side to side . . . but
generate a trio of pulses for each illumination. Say
3 flashes in 1 second per side. I think I recall a
system being offered at OSH over 10 years ago for
producing a series of short flashes for each illumination
interval. Again, the rise/fall rates for LED's would
probably enhance performance.
That's something we could do with the LED wig-wag
project. The software could be modified to offer the
trio of short bursts for each lamp in addition to the
positional offset of side-to-side cycling.
That project is not on a back burner. I've got boards
laid out and thanks to the able skills of byte-herder
McHugh, we have source code that could easily be amended
to produce the proposed behavior. All I need is a 36-hour
day . . . but it's going to happen along with several other
new products.
raymondj(at)frontiernet.n
PostPosted: Tue Oct 16, 2012 6:37 am    Post subject: Making a LED landing light flash Reply with quote
Just a random thought. How would what I'll call "asynchronous wig wag"
affect visual impact? The flash pattern I'm thinking of would have
wingtips flashing at different rates. As an example, the left flashing
at 1/sec and the right at 1/1.25 sec. Or each one flashing at random
intervals between 1/.5 sec and 1/1.5sec.
Any thoughts, experience, or data.
Raymond Julian
Kettle River, MN.
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 10/16/2012 08:40 AM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
energy.
new products.
FisherPaulA(at)johndeere.
PostPosted: Tue Oct 16, 2012 9:25 am    Post subject: Making a LED landing light flash Reply with quote
I'm glad to hear the wig-wag project isn't on the back burner. I tried, unsuccessfully, to get involved back in May/June but apparently higher priority projects moved in. I'd still be interested once you get that 36 hour day thing figured out! Wink
I have no pressing need - it just sounds like an interesting learning opportunity...
Paul A. Fisher
RV-7A N18PF
Q200 N17PF
PostPosted: Tue Oct 16, 2012 10:28 am    Post subject: Making a LED landing light flash Reply with quote
At 12:24 PM 10/16/2012, you wrote:
<FisherPaulA(at)johndeere.com>
Oh yeah, you asked for a board. I can send
you one along with a copy of Greg's present
handiwork. Shoot me an address again.
How's your stock of 1206 SMD parts? I can
probably put sort of a 'kit' together.
Have you downloaded the latest data package?
http://tinyurl.com/6w9vndk
PostPosted: Tue Oct 16, 2012 12:01 pm    Post subject: Making a LED landing light flash Reply with quote
SCRATCH THE ABOVE. I'd promised you a STUFFED
board. Also found your address. The board is about
half done. Won't make today's pickup but it will go
out tomorrow. I'll find Greg's last pass on the
code and get it posted to the website.
PostPosted: Wed Oct 17, 2012 5:57 am    Post subject: Making a LED landing light flash Reply with quote
Thanks Bob. I'll take a look and see if I can incorporate a 3-flash on cycle for the transition of the wig-wag into Greg's software and get it back to the group. Should be an interesting project!
- Paul
PostPosted: Wed Oct 17, 2012 6:42 am    Post subject: Making a LED landing light flash Reply with quote
I think so.
One of the things I miss most about being 'retired' is
that it's more like being 'isolated'. Most of the jobs
I've held came with a certain population of curious minds
who were also great 'connectors of dots' . . . they
could sit around a table and play 'pass the idea' . . .
each trip around the loop would produce clearer insight
and/or interesting alternatives to the task before us.
While working in the Targets division at HBC, I sat in
a bull-pen of cubicles occupied by such individuals. We
overheard each other's conversations including phone calls.
A GOOD thing especially when some eavesdropper had some
interesting thought or fact to stir into the mix.
You folks are my surrogate think tank. I'm enthusiastic
about exploring these 'open source' projects. In terms
of quality of outcome, it cannot be bad . . . and certainly
much better than projects that grow up within narrow silos
of talent and responsibility.
When I've explained these experiments with some of my
past colleagues, they often voice some skepticism about
the 'business model'. Over the years, I've come to understand
that product development is greatly separated from production
and marketing of an idea. Further, just because an idea is
fully disclosed doesn't mean that there is an increased risk
to individuals who decide to produce and market those ideas.
Most of the folks on the List have no interest in producing
and marketing anything. They're interested in acquiring
certain capabilities, of good value, off the shelf with track
record and warranty. If competing production and marketing efforts
arise from an idea, it's a good thing. Carrying these activities forward in
the open source, open forum environment goes a long way toward
informing potential customers and demonstrating track records.
But for some, it's not about production/marketing. It's all
about an intellectual 'buzz' that rises from a successful
recipe of of simple ideas. During my brief stint in television
broadcast, I was tasked with producing and marketing a video
time base corrector. The thing was designed by a very clever
fellow who was deprived of the 'think tank' refinement tools
that I've learned to value. I was forced into learning video
in a big hurry so that I could sift out the little bugs and
production snags in the design. Support from the original
designer was disappointing. He'd seen it work once and was
off on other ideas. He ultimately went to work for Heathkit,
the IDEAL environment for his talent and motivations. He was
immersed in an organization of very capable production and
marketing folks who could maximize the exploitation of his
unique talents.
I'd like to believe that the List membership includes the
whole spectrum of talents, personalities and life-goals
willing to contribute to the life cycle of interesting and
useful products.
We shall see. Thanks for participating . . . any many thanks
to those who have participated thus far.
Eric M. Jones
PostPosted: Thu Oct 18, 2012 3:09 pm    Post subject: Re: Making a LED landing light flash Reply with quote
Some notes on wig wags and flashers: This field has been studied since the 1800's since people were quite interested in making lighthouses visible to ships. Studies on what is most visible and how it is measured is an extremely difficult subject: Viz, a light visible at a flash pulse-width of 40 mS can appear to be LESS BRIGHT at 50 mS. WTF? (I hear you ask), well, the visual system is working as hard as it can to detect a shorter flash and sends a signal to the brain. Nothing happens beyond that while the visual neurons need time to recover. OR SOMETHING...Weird. (Broca & Sulzer 1902). I'm not sure anyone really knows, but it is an easy experiment to reproduce.
Blondel-Rey equations are used to determine Effective Intensity Ie. In the last few years the methodology has been called into question because the Blondel-Rey equations don't work well except with purely square-wave pulses over a limited range. The B-R equations don't do so well with strange wave shapes, multiple flashes, complex flash chains, and many other complications. Nevertheless the FAA still uses B-R.
The Cessna beacon was approved years ago and still complies with the old standard. The new FAA standard (which YOU must use) is much brighter.
The best reason to use LEDs for brake lights is that the distance you have available to stop when the guy in front of you stops is markedly increased due to not having the delay needed to heat up a tungsten lamp, so you see it sooner. This is much safer but probably has nothing to do with the wave shape and wouldn't help much in aviation.
An LED engineer suggested to me that I use the newest board-mounted red LEDs because they can produce much higher-energy flashes (or even Ie) than white (or anything else). I intend to do so.
Attached is my paper on LED beacons. The last couple paragraphs show their age. These beacons are easier and cheaper than they were 8 years ago.
Comments appreciated.
aircraft_beacons_using_leds.pdf
 Filename:  aircraft_beacons_using_leds.pdf
 Filesize:  57.57 KB
 Downloaded:  788 Time(s)
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
