Optimal Temperatures and fuel burn
AirMike
PostPosted: Sun Oct 21, 2012 9:26 pm    Post subject: Optimal Temperatures and fuel burn Reply with quote
Not unusually, I have a hot #6 cylinder. It consistently shows CHT at about 25-40 degrees hot compared to the other cylinders. I always keep it under 400 degrees even though Lycoming says up to 425 is ok. My EGT on #6 also runs hot at 1420 when the other cylinders are 1375. My oil is 168 in fall and 180 in winter. What do you all consider excessively high EGT? I do not want to melt my exhaust valves or pipes!
Do you folks think that I should inhibit the air flow to the oil cooler to get better cooling on #6.
See you OSH '18
Q/B - sold.
flying-nut(at)cfl.rr.com
PostPosted: Sun Oct 21, 2012 9:46 pm    Post subject: Optimal Temperatures and fuel burn Reply with quote
I'd suspect an induction air leak first. Easy to find ....
Hook up a CLEAN shop-vac so it blows instead of sucks. Put the hose in
the intake and stuff some rags around it to seal it. Spray soapy water
all over the intake to #6. Usual culprits are where the intake tube is
swaged into the oil pan and the intake coupling hoses.
Same procedure works on a lot of oil leaks too ..... pressurize the
crankcase breather.
Linn
See you OSH '13
Q/B - flying 3 yrs.
http://forums.matronics.com/viewtopic.php?p=385771#385771
Checked by AVG - www.avg.com
Bob Turner
PostPosted: Sun Oct 21, 2012 9:57 pm    Post subject: Re: Optimal Temperatures and fuel burn Reply with quote
What are the EGTs relative to peak EGT, on each cylinder?
E.g., if #6 is 50 rich of peak and the others are 100 rich of peak;
Or, of #6 is 50 rich of peak and the others are 50 lean of peak,
Either way you would expect #6 CHT to be hotter than the others.
Bob Turner
RV-10 QB
TimRVator(at)comcast.net
PostPosted: Mon Oct 22, 2012 1:57 am    Post subject: Optimal Temperatures and fuel burn Reply with quote
Mike Busch's free webinars (hosted by EAA, link from
https://www.savvymx.com/index.php/webinar) address several points from
the post:
"The EGT Myth" addresses concerns about excessively high EGT:
http://www.eaavideo.org/video.aspx?v=1316946190001 (1420 is not "too hot.")
"Troubleshooting Engine Problems" has a wealth of good info:
http://www.eaavideo.org/video.aspx?v=972961455001
"Flight Test Profiles" from January 2012 Sport Aviation includes mixture
distribution test and an airborne induction leak test (page 61).
I don't think 25-40 degree CHT spread is a problem. Depending on phase
of flight, my CHT temps are spread that high or higher.
Tim Lewis -- HEF (Manassas, VA)
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 350 hrs
AirMike said the following on 10/22/2012 1:26 AM:
See you OSH '13
Q/B - flying 3 yrs.
bill.peyton
PostPosted: Mon Oct 22, 2012 4:24 am    Post subject: Re: Optimal Temperatures and fuel burn Reply with quote
I have the same issue with number 5 CHT. It started out way to hot and slowly came down during break-in. One of the things I did to help cool number 5 was to loosen the outer lower baffle wrap-around and to add a 960-10 washer under the rear baffle attachment screw. This created about a 1/4" gap around the back of the cylinder and dropped my #5 CHT by 10 degrees.
Just for a data point. My #6 is the last to peak and it peaks at the highest temp. It is also one of the coolest CHTs.
How many hours do you have on the engine? Go to Tim Olson's web site where he has a little write-up on what he did to cool the CHTs. Also, check for that leak in the intake tube as previously posted.
Bill
WA0SYV
Aviation Partners, LLC
Kellym
PostPosted: Mon Oct 22, 2012 6:00 am    Post subject: Optimal Temperatures and fuel burn Reply with quote
What is your peak EGT, and which cylinder is 1st to peak? What is the
spread of fuel flow from 1st cyl peak to last cyl peak?
EGT is NOT an absolute value and should not be treated as such. You
need to know where you are operating relative to peak. If running rich
of peak you should be 100 degrees rich of the 1st cyl to peak. If you
run lean of peak(and it doesn't sound like you are) you need to base
your lean of peak range from the LAST cyl to peak. If the spread from
1st to last to peak is more than 0.5 gph, you have either induction
problem or injector problem. If you get the mixtures balanced between
cylinders, and baffles are good, CHT issues will go away.
See you OSH '13
Q/B - flying 3 yrs.
Kelly McMullen
KCHD
rv10flyer(at)live.com
PostPosted: Mon Oct 22, 2012 6:06 am    Post subject: Optimal Temperatures and fuel burn Reply with quote
I have battled a similar issue. I have discovered that if you look at the
Lycoming manuals, "key operations" it will tell you that 400-435F is
"normal" for performance and takeoff, 400F for cruise. It will also tell you
that having a CHT spread of 100F is fine and not a bit issue. Most Lycomings
come pretty close to being able to lean them out of the box. I made one
tweak and mine engine is where GAMI says good enough.
Forget EGT's they mean nothing except for Leaning and engine
troubleshooting.
My #3 cylinder is 40F cooler than any other cyclinder. Was told by Eci that
is just fine.
My oil, more like 189-203 for me most of the time, but within the green arc
and below 220F, so once again told it's fine and normal.
Don't fret it, believe me, I have ! BTW if you listen or read a Mike Busch
article or webinar- IGNORE his if its at 400F do something now.. that is
just an unneccessary stress inducer, may be an issue for his Continental,
but both Lycoming and Eci told me it was NOT an issue at all.
Everything is within "normal" tolerances that you are seeing.
Pascal
Kellym
PostPosted: Mon Oct 22, 2012 6:20 am    Post subject: Optimal Temperatures and fuel burn Reply with quote
Lycoming is not known for good advice regarding engine management. These
are the same folks that say pilots are too inattentive/stupid to run
lean of peak.
Lycoming and TCM cylinders are made from the exact same alloy. The main
difference is that Lycoming uses sodium filled exhaust valve stems, and
TCM uses solid valve stems. Lycoming specifies approx 5 ft/lbs higher
spark plug torque, for no know reason.
So, the same thinking regarding CHT applies to both brand engines. The
hotter you let the cylinders get the weaker the metal gets and the more
it fatigues. Also, hotter cylinders are more prone to valve sticking and
excess valve guide wear. Prime example...Mooney TLS in first couple
model years had cylinders losing compression and other valve problems at
200-300 hours. Problem was that Mooney designed the cowling to provide
the pressure differential and CHT Lycoming said were OK. This engine
was the same as the RV-10 engine, with lower compression and a
turbo-charger added, for 270 hp rating, same parallel valve cylinders.
The fix was to incorporate positive oil flow to the outside of the valve
guides to cool them. Engines now do fine, but are very pricey to overhaul.
So, to make long story short, pay attention to what Advanced Pilot
Seminars, GAMI and Mike Busch have to say. They have test data to back
them. Lycoming recommendations are likely to lead to shorter engine life.
the Lycoming manuals, "key operations" it will tell you that 400-435F
is "normal" for performance and takeoff, 400F for cruise. It will also
tell you that having a CHT spread of 100F is fine and not a bit issue.
Most Lycomings come pretty close to being able to lean them out of the
box. I made one tweak and mine engine is where GAMI says good enough.
troubleshooting.
that is just fine.
green arc and below 220F, so once again told it's fine and normal.
Busch article or webinar- IGNORE his if its at 400F do something now..
that is just an unneccessary stress inducer, may be an issue for his
Continental, but both Lycoming and Eci told me it was NOT an issue at
all.
Pascal
Kelly McMullen
KCHD
partner14
PostPosted: Mon Oct 22, 2012 10:09 am    Post subject: Optimal Temperatures and fuel burn Reply with quote
Only thing I can add to my good frieeeeend Pascal's comments... and noone else seemed to answer your question.... Your oil temps are plenty low... so yes, you could block off some of the flow to the oil cooler. Best way is a butterfly fly valve. That emables you to be right on top of the entire temp issue all year long. Especially since 168 is low and not good on the engine. If it came down to a choice of running a cht at 400, and oil temp at 168 to 180... vs. cht at 385 and oil temps at 180 to 200.... I'd take the latter any day.
My 5 cents worth
Don McDonald
Sent: Monday, October 22, 2012 9:05 AM
Subject: Re: Optimal Temperatures and fuel burn
--> RV10-List message posted by: "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)>
I have battled a similar issue. I have discovered that if you look at the Lycoming manuals, "key operations" it will tell you that 400-435F is "normal" for performance and takeoff, 400F for cruise. It will also tell you that having a CHT spread of 100F is fine and not a bit issue. Most Lycomings come pretty close to being able to lean them out of the box. I made one tweak and mine engine is where GAMI says good enough.
Forget EGT's they mean nothing except for Leaning and engine troubleshooting.
My #3 cylinder is 40F cooler than any other cyclinder. Was told by Eci that is just fine.
My oil, more like 189-203 for me most of the time, but within the green arc and below 220F, so once again told it's fine and normal.
Don't fret it, believe me, I have ! BTW if you listen or read a Mike Busch article or webinar- IGNORE his if its at 400F do something now.. that is just an unneccessary stress inducer, may be an issue for his Continental, but both Lycoming and Eci told me it was NOT an issue at all.
Pascal
Don A. McDonald
40636
AirMike
PostPosted: Sun Oct 28, 2012 8:10 pm    Post subject: Optimal Temperatures and fuel burn Reply with quote
Thanks all of you for the comments especially Don. I think that I will try a flow restrictor on the oil cooler air intake.
See you OSH '18
Q/B - sold.
