nuckollsr(at)cox.net Guest
Posted: Fri May 26, 2006 6:15 am Post subject: Chapter 8 Update |
Chapter 8 of the Connection has been updated with the
corrected temperature rise data in the figures. For a
limited time, folks on the List can download and print
a complete replacement for Chapter 8 at:
http://www.aeroelectric.com/CH_8/Ch8_R12.pdf
Print odd pages only in reverse order, turn stack over
in printer and print even pages only to get fronts and
backs.
< with experiment. >
< --Lawrence M. Krauss >
djones(at)northboone.net Guest
Posted: Thu Jun 01, 2006 8:02 pm Post subject: Chapter 8 Update |
Bob
The reply claims the file is damaged and cannot be repaired. Something
special that needs to be done?
Jonesy
Posted: Thu Jun 01, 2006 8:34 pm Post subject: Chapter 8 Update |
Hmm, works ok for me right now. Do you have the latest version of Acrobat?
-- Craig
Bob McC
Posted: Thu Jun 01, 2006 9:25 pm Post subject: Chapter 8 Update |
I received the same "damaged file" error when I first tried to open this,
but now it's working just fine and yes, this is with the Acrobat 7, the
latest version.
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
Thanks for the idea. I have the 7.0.7 version. That appears to be the
current version. It still give me the file is damaged message.
Jonsey
rv8ch
Posted: Thu Jun 01, 2006 10:50 pm Post subject: Chapter 8 Update |
| Quote: | The reply claims the file is damaged and cannot be repaired. Something
Jonesy
Sometimes a file can get corrupted between the server and your
PC for a variety of reasons. The thing to do is to flush your
browser cache. This is different depending on the browser you
use, but since there is an 80% chance you are using Microsoft
Internet Explorer, here's how you do it:
Tools/Internet Options/General/Delete Files
Also, if you are using MSIE, you may want to consider upgrading
to Mozilla's Firefox. http://www.mozilla.com/firefox/
After flushing the cache (or installing Firefox) the transfer
will hopefully work. If not, let me know and I'll be happy to
send it to you.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Fri Jun 02, 2006 6:04 am Post subject: Chapter 8 Update |
At 10:54 PM 6/1/2006 -0500, you wrote:
<djones(at)northboone.net>
Bob
Most of the time, no . . .
However, most operating systems have an embedded list of
file extensions intended to tell the system what application
is used to open which type of file. In this case, the file
is a .pdf extension and is opened with one of Adobe's several
viewing/editing applications for .pdf files.
The problem arises when the combination of applications running
in your system get the cart in front of the horse (a hazard
of systems designed for multitasking). I believe folks are getting
the error message you've noted because Acrobat is being prompted
to open the file while it's still being downloaded . . . hence,
Acrobat sees a truncated file and assumes that it's damaged.
The 100% sure method for downloading large data files of
any type from any site is to right-click the link and tell
your browser where to STORE the file on your hard-drive.
Wait until the download is complete and THEN open the
file with the appropriate application.
Eric M. Jones
Posted: Sun Jun 04, 2006 6:30 pm Post subject: Re: Chapter 8 Update |
Comments on Chapter 8: Wire Selection and Installation.
General comments on materials.
The periodic table does not hide any magic conductors. Copper is the second best by volume, it is 94% as good as the best—Silver. Surprisingly, gold is not particularly good. Its magic lies elsewhere.
I have to disagree with several statements. I think these were not critically examined in the writing:
“Weight will not be greatly improved upon; the copper conductor is already the major proportion of the weight and there is simply no practical way to do with less copper with current technology”---Oh? How about higher voltages, single wire busses, fiberoptics, Copper-Clad Aluminum, etc. I am sure you meant something slightly different here….
“There is no material more economical than copper for any given wiring task.” Simply not so. I am sure you do not quite mean it Bob. Throw a couple more modifiers in there please.
Bob, you just plain ignore Copper Clad Aluminum, so I suggest taking a look at the link:
http://www.periheliondesign.com/fatwires_files/Copper%20cables.pdf (I will still send free samples to interested Aeroelectric list fans) Boeing and Airbus buy kilotons of the stuff. Its advantages may or may not be attractive to you, but ignoring it is not serving your readers.
Flexibility: The discussion of flexibility is not clear on a couple points and draws some suspect conclusions. Certainly, flexibility in an electric drill is handy, but this does not mean that the general use of finely-stranded wire is generally advantageous in DC circuits.
Simply put—there is scant evidence that using stranded wire instead of solid gains you much except in some special cases---e.g.
1) Flexibility, as in an electric drill cord or a welding cable.
2) Attachment to resonant or vibrating structures. That’s why the ground strap to an engine is braided. NOT because fine stranding is more reliable.
3) Convenience in spooling, handling, and installation. A solid wire always has bias, but it mostlydisappears in stranding.
Note also that stranded wire has a huge surface area relative to solid. For the same cross-section, let’s say a one square inch solid conductor would have a surface area of four square inches per inch, while if it were separated into 1/12” X 144 strands would have a surface area of 48 square inches per inch. This is why stranded wire is the cat’s meow for higher frequencies that depend on skin effect for transmission. Complicated subject.
Solid wire is easier to use in DC circuits—it terminates better, is smaller and lighter for equivalent AWG size.
To simplify—I think your thinking on stranded versus solid need rethinking a bit.
Bob says—“Copper is a very active metal.” No it isn’t. Copper, like many other useful metals forms a protective coating on its exposed surface. You can drop a copper penny in the dirt and dig it up in a thousand years and still read the date on it. Roman soldiers did the first half of this experiment for us. Stainless steel and copper are remarkably similar in corrosion resistance except that stainless steel forms a transparent coating that is NON-conductive, and looks great. Copper forms a conductive coating but looks like hell. At least if I remember my chemistry correctly.
Your description of voltage drop etc., would be improved by some nice drawings.
Note: Rivnuts were developed by B. F. Goodrich.
More later. Keep up the good work.
No one traveling on a business trip would be missed if he failed to arrive.
- Thorstein Veblen
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Mon Jun 05, 2006 9:41 am Post subject: Chapter 8 Update |
At 07:30 PM 6/4/2006 -0700, you wrote:
| Quote: | single wire busses, fiberoptics,
??? We're wiring landing lights and pitot heaters here . . .
and the topic is DC power generation and distribution,
not data handling.
| Quote: | Copper-Clad Aluminum, etc. I am sure you meant something slightly
different here….
I meant exactly what I wrote . . .
| Quote: | “There is no material more economical than copper for any given wiring
How so? Economics is the study of scarce resources for which
there are alternative uses. In this case, I'm speaking of $time$
which one spends to acquire cash to buy wire when one also needs
to spend $time$ to do many other things on the project. Except for
the specialize case where CuC-Al offers some weight savings,
it's still more expensive in $time$, is not as pleasant to work with
and occupies more volume in a bundle.
Further, opportunities for CuC-Al might be as much as 20' of
wiring out of a total of hundreds of feet where a weight savings
of a few pounds is possible. For all other applications expense,
less than friendly flexibility, and miniscule weight savings are
not, in my personal opinion, a good trade off . . . even if the
wire was available in the smaller gages.
| Quote: | Bob, you just plain ignore Copper Clad Aluminum, so I suggest taking a
look at the link:
Eric, you're getting your shorts in a bunch over nothing. I
DO talk about the copper clad aluminum. I have samples you sent
me and I show them in my seminars along with examples of soldered-
on terminals. The attendees also get to handle a piece of CuC-Al,
22759/16-2,
and 2AWG welding cable. We discuss insulations, flexibility and
a few cautions about bolting fat-wires to the lead posts on
a small RG battery (4AWG welding cable recommended).
Chapter 8 was updated to correct errors in the wire tables, not
update it to the latest-and-greatest technologies. Those things will
will be added to the text in due course. All I need is a 36-hour
day.
| Quote: | Flexibility: The discussion of flexibility is not clear on a couple points
The preference for 19+ stranding has nothing to do with DC circuits.
19 or more strands in small wires has been the process of choice for
resistance to vibration and flexing from other sources for a very long
time.
| Quote: | Simply put—there is scant evidence that using stranded wire instead of
You are free to preach any gospel you wish. Are you suggesting that
it's a rational decision to wire one's airplane with solid conductor
stuff? I'm only repeating what has been practice and policy in
aircraft for many, many years. I've worked with wire in many venues
for a long time and the ONLY place I'd use solid wire is in my house .
| Quote: | 2) Attachment to resonant or vibrating structures. That’s why the ground
??? lost you. Does not resistance to breakage due to persistent
motion translate into increased service life, hence 'reliability'
for that component? And does not the whole airplane have a vibration
signature that is greater than automobiles?
| Quote: | 3) Convenience in spooling, handling, and installation. A solid wire
Why even bring it up? Skin effect was never a consideration for
wire selection in airframes. Adoption of relatively fine stranded
wire in aircraft (and as far as I know, all military products)
was for resistance to failure under vibration due to decreased
stresses under vibration and higher reliability - a nick on a stranded
wire puts a few strands at-risk, a nick on a solid wire puts the
whole conductor at risk.
| Quote: | Solid wire is easier to use in DC circuits—it terminates better, is
You're splitting hairs (or strands) here. The weight differences
between stranded/solid for any given gage is miniscule. Does your
reference to "DC circuits" suggest an alternative philosophy is
appropriate for AC circuits? Are you suggesting that readers of this
List consider making the switch to solid wire?
| Quote: | To simplify—I think your thinking on stranded versus solid need
rethinking a bit.
Forgive my imprecise speech with respect to reactivity. Keep in mind
that we tin-coat copper to reduce effects of corrosion that folks
fine objectionable at any level however small. Yes, copper is less
reactive than say lithium, iron or zinc but a whole lot more reactive
than chrome . . . I guess we need to put some numbers to "less" and
a "whole lot more" . . .
| Quote: | Your description of voltage drop etc., would be improved by some nice
drawings.
Send me some sketches of what you propose. Figure 2-3 has an exemplar
voltage drop analysis and I was assuming that the reader would recall
the discussion when he/she advanced to Chapter 8.
