Dennis Thate
Posted: Wed Oct 24, 2012 2:37 pm Post subject: 'Tis the Season' Reminder |
The temperature-dew point spread tells a pilot how close the air is to being 100% saturated, Fortunately old wise men 503 Rotax pilots rarely fly in such conditions.
There seems to be a general consensus that two strokes gas /oil mixtures are invincible to icing, if you have the BING 54 carbs on your two stroke 503 as most Kolb Firestar pilots have they are not as prone to carb icing, because it works with a piston and not a valve as most other carbs do so most ice that will be formed will by design be sucked into the engine, and heated up to melt down preventing the carb piston itself from freezing in a fixed position.
The highest probability for carb icing is during a long decent. It's good General Aviation airmanship to add carb heat and clear the throttle at intervals during a glide approach, keep the power up, and remain with gliding distance of good fields until you get home and don't reduce power until you are sure you can make the field.
Fly Safe, stay revved up !
http://www.800-airwolf.com/pdffiles/ARTICLES/part44.pdf
_________________ Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute. ~Gil Stern
phactor9
Posted: Wed Oct 24, 2012 3:28 pm Post subject: 'Tis the Season' Reminder |
I wonder what risks a diaphragm carb suffers with carb ice? ( I.e. a Tillotson ) At least there's no slide to stick. Perhaps just reduced air intake, resulting in higher oil-to-fuel ratio?
Assuming the whole throat doesn't fill up with ice, does that mean fouled plugs are the biggest problem?
Phil H
FF11-4-76
--- On Wed, 10/24/12, Dennis Thate <retroman(at)frontier.com> wrote:
Subject: 'Tis the Season' Reminder
Date: Wednesday, October 24, 2012, 6:37 PM
--> Kolb-List message posted by: "Dennis Thate" <[url=/mc/compose?to=retroman(at)frontier.com]retroman(at)frontier.com[/url]>
http://forums.matronics.com/viewtopic.php?p=385941#385941
ht="http://forums.matronics.com" target="_blank">http://forums.matronics.; - List Contribution Web Site -
p; &nref="http://www.matronics.com/contribution" =======
| [quote][b]
Dana
Posted: Wed Oct 24, 2012 3:44 pm Post subject: 'Tis the Season' Reminder |
At 06:37 PM 10/24/2012, Dennis Thate wrote:
| Quote: | --> Kolb-List message posted by: "Dennis Thate" <retroman(at)frontier.com>
There seems to be a general consensus that two strokes gas /oil mixtures are invincible to icing, if you have the BING 54 carbs on your two stroke 503 as most Kolb Firestar pilots have they are not as prone to carb icing... |
.. but it still can happen. I have had two engine failures that I can only attribute to icing... no other apparent cause, very close temperature and dewpoint. In my case it's a Mikuni, but that's very similar to a Bing. I was lucky, in both cases I was able to restart, but I was sure picking landing fields!
-Dana
The most exciting phrase to hear in science, the one that
heralds new discoveries, is not Eureka! (I found it!) but rather,
'hmm.... that's funny...'
--Isaac Asimov
Dana
At 07:28 PM 10/24/2012, Phil wrote:
| Quote: | | I wonder what risks a diaphragm carb suffers with carb ice? ( I.e. a Tillotson ) At least there's no slide to stick. Perhaps just reduced air intake, resulting in higher oil-to-fuel ratio? |
In a traditional carb, ice tends to build up on the butterfly, so I assume it would be the same with a Tillotson or Walbro. The oil in the mix and slight puffback of a 2-stroke I think is the main thing that helps us, not the fact that the Bings are slide carbs.
-Dana
--Isaac Asimov
Richard Pike
Posted: Thu Oct 25, 2012 4:25 am Post subject: Re: 'Tis the Season' Reminder |
Years ago my brother in law was flying his Quicksolver MX, had a Cuyuna with a Mikuni on it, and it was a fall day, humid and damp. It was acting up, so we pulled off the aircleaner, tied it down, and let it run for awhile.
After a while, we got to watch a little "half-volcano" of ice crystals build up around the front side of the slide needle as the fuel was coming up around the needle. It never got big enough to close the throat, but it did get big enough to alter the proper airflow function of the carb. If I remember right, it was about 3/8" high, and 1/4" wide at the base.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
zeprep251(at)aol.com Guest
Posted: Thu Oct 25, 2012 3:44 pm Post subject: 'Tis the Season' Reminder |
It seems that carbs that have cross structure down stream of the fuel discharge point ice more readily.The Bing 64 on the Jabiru is the worst I've experienced.Have any of the 912 engines had this issue?
G.Aman MK3 C Jabiru 2200A 765 hrs electric carb heat
Thom Riddle
Posted: Fri Oct 26, 2012 4:19 am Post subject: Re: 'Tis the Season' Reminder |
Gary,
Unless your Jab2200 is a very very early one, the Bing carb on it is a 94 (40mm). They used a 64 model (36mm) for only a short while and it didn't take them very long to determine it was not big enough. However, they are of similar design and function much the same way,
I've not had any carb icing in my Slingshot with Jab2200 but in the 11 years I've been flying Rotax 912 engines, I've had two carb ice incidents. Detecting it early both times, I was able to get rid of it by cycling the throttle idle to WOT, back and forth a couple times. In both cases it was in warm weather with high humidity.
123.45 KB |
13033 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
byoungplumbing(at)gmail.c Guest
Posted: Fri Oct 26, 2012 6:48 am Post subject: 'Tis the Season' Reminder |
I had a similar episode last spring... about 60 65 deg f humidity was up
,high but not extremely high, I had been out about an hour and was
coming back into the pattern when I pulled the throttle back, I heard some
funny/different noises,,, cycled the throttle a couple of times, a bit more
noise, and landed promptly. when I shut the engine down I hurried out and
could see a very thin film of ice on the outside of the carb.
I have a friend that moved here from florida,,, and he said on a humid day
after a rain, carb ice was routine on his 912. he had to add a carb
heater or limit his flying days. he was flying a plane in tractor
configuration.
boyd young
mkiii 912 utah
| Quote: | >>>>>>>>>>>>>>>>>>>
Gary,
Thom Riddle
Buffalo, NY (9G0)
gcvisel
Joined: 23 Oct 2012 Posts: 11 Location: United States
Posted: Fri Oct 26, 2012 9:42 am Post subject: 'Tis the Season' Reminder |
Is there a carb heat mod for the 503? --Gerry
On Fri, Oct 26, 2012 at 9:48 AM, b young <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)> wrote:
[quote]--> Kolb-List message posted by: "b young" <byoungplumbing(at)gmail.com (byoungplumbing(at)gmail.com)>
I had a similar episode last spring... about 60 65 deg f humidity was up ,high but not extremely high, I had been out about an hour and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, cycled the throttle a couple of times, a bit more noise, and landed promptly. when I shut the engine down I hurried out and could see a very thin film of ice on the outside of the carb.
I have a friend that moved here from florida,,, and he said on a humid day after a rain, carb ice was routine on his 912. he had to add a carb heater or limit his flying days. he was flying a plane in tractor configuration.
boyd young
mkiii 912 utah[b]
Posted: Fri Oct 26, 2012 11:44 am Post subject: 'Tis the Season' Reminder |
It must be a 94.Don't see any identification on the casting,just looked like a 64.
G.Aman
Posted: Fri Oct 26, 2012 12:03 pm Post subject: 'Tis the Season' Reminder |
The ice will build at cruise power settings,and the power loss is so gradual that you may not catch it.But you WILL notice when the ice breaks loose and the engine gags on it for a couple of revolutions.It gets me at warm up speeds,1100rpm,and will almost die without heat.If you go to idle it will quit.It must ice over those small ports just aft of the throttle plate as well.You've seen some pictures of the fog we get up here,great flying above the broken stuff but icing down low. G.A.
Posted: Sat Oct 27, 2012 3:23 pm Post subject: 'Tis the Season' Reminder |
Date: Wed, 24 Oct 2012 16:28:26 -0700 (PDT)
Phil,
| Quote: | From the few flights I have with the MZ 34 with a Tillitson carburetor, I
found that it will ice up. Always I make a high approach so that if the
engine quits I can always make the field. This means that one must close
the throttle and spill altitude and results in a cold engine when one
reaches the point of round out and flare. After roll out the engine starts
easily.
Since I use mixed fuel, there is no reason to expect fouled plugs.
To get around this icing up problem, I searched the web and found some small
bolt heater that is used on KTM motorcycle engine carburetors. I drilled
the Tillotson carburetor and mounted one. I have not had a chance, as yet,
to check it out but you can see how it was done at the bottom of:
http://jackbhart.com/firefly/firefly153.html
Jack B. Hart FF004
Winchester, IN
nationcap(at)comcast.net Guest
Posted: Sat Oct 27, 2012 7:37 pm Post subject: 'Tis the Season' Reminder |
When I was flying 172s, the SOP was to turn on carb heat when entering the pattern and pulling the throttle back as there was a greater tendency for carb icing.
Brad
On Oct 26, 2012, at 8:48, "b young" <byoungplumbing(at)gmail.com> wrote:
boyd young
mkiii 912 utah
Gary,
Thom Riddle
Buffalo, NY (9G0)
