Malcolmbru(at)aol.com Guest
Posted: Fri Jun 02, 2006 1:25 pm Post subject: radiator additive ? don S |
what did don S do to his radiator?
dosmythe(at)cox.net Guest
Posted: Fri Jun 02, 2006 1:43 pm Post subject: radiator additive ? don S |
A bunch of things. Modified the engine cowl to remove the left air exhaust
on the bottom pilot side of the engine cowl, fabricated side exhaust vents
on the engine cowl, fabricated a fiberglass radiator cowl that extends full
width and back to the aft crossover tube, double cockpit controlled louvers
on backside of radiator, deflection plate from the front bottom of the
engine cowl directing air into the "P51" type radiator inlet. I could have
built a Kitfox faster than all this took but, it seems to work.
Don Smythe
Posted: Sun Jun 04, 2006 10:36 pm Post subject: radiator additive ? don S |
Got pictures Don?
Kurt S.
--- Don Smythe <dosmythe(at)cox.net> wrote:
| Quote: | A bunch of things. Modified the engine cowl to
front bottom of the
seems to work.
Don Smythe
