dan42101(at)yahoo.com Guest
Posted: Fri Oct 26, 2012 2:25 pm Post subject: Kolb-List:CARB HEAT// Re: 'Tis the Season' Reminder |
Yes, and simple.http://legacy.rotax-owner.com/si_tb_info/serviceinfo/4ul94.pdf
--- On Fri, 10/26/12, Gerry Visel <gcvisel(at)gmail.com> wrote:
Subject: Re: Re: 'Tis the Season' Reminder
Date: Friday, October 26, 2012, 12:42 PM
Is there a carb heat mod for the 503? --Gerry
On Fri, Oct 26, 2012 at 9:48 AM, b young <[url=/mc/compose?to=byoungplumbing(at)gmail.com]byoungplumbing(at)gmail.com[/url]> wrote:
| Quote: | --> Kolb-List message posted by: "b young" <[url=/mc/compose?to=byoungplumbing(at)gmail.com]byoungplumbing(at)gmail.com[/url]>
I had a similar episode last spring... about 60 65 deg f humidity was up ,high but not extremely high, I had been out about an hour and was coming back into the pattern when I pulled the throttle back, I heard some funny/different noises,,, cycled the throttle a couple of times, a bit more noise, and landed promptly. when I shut the engine down I hurried out and could see a very thin film of ice on the outside of the carb.
I have a friend that moved here from florida,,, and he said on a humid day after a rain, carb ice was routine on his 912. he had to add a carb heater or limit his flying days. he was flying a plane in tractor configuration.
boyd young
mkiii 912 utahhttp://www.matronics.com/Navigator?Kolb-Listhttp========================
