Problem with Fuel flow transducer in the tunnel
Goto page Previous  1, 2
rnewman(at)tcwtech.com
PostPosted: Thu Nov 15, 2012 5:31 pm    Post subject: Problem with Fuel flow transducer in the tunnel Reply with quote
Bob, Good question. In my set-up I only have a filter in each wing root,
no filter in the tunnel. The filter in the wing root has the same mesh
size and pressure drop vs. flow values as the standard filter used with the
AFP filter/pump assembly. So I think that's not an issue.
Bob Newman
Page 2 of 2
