Mike Whisky
Posted: Thu Nov 22, 2012 11:45 am Post subject: 500N vs. 600N door lift strut |
I just wanted to share my experience with the different door lift struts.
I have the flush door handles installed as well as the center lock system and covered the inside of the door with fabric. The inside handle is the Aerosport door handle cover. I guess pictures say more than 1000 words.
I bought the 2218LP by the way.
Michael
275.07 KB |
1557 Time(s) |
227.65 KB |
1556 Time(s) |
240.75 KB |
1556 Time(s) |
| 2218LP door struts fit like the original ones |
323.95 KB |
1556 Time(s) |
_________________ RV-10 builder (flying)
#511 |
rv10pro(at)gmail.com Guest
Posted: Thu Nov 22, 2012 1:58 pm Post subject: 500N vs. 600N door lift strut |
Heat - Fuel - Oxygen. Hope you have an advanced Fire Annunciation system beyond VANS. Most use the smoke as the fiberglass resin talks back.
You could consider a Titanium heat shield and a reroute of the fuel as far away as practical.
Let me know if you need the scrap piece for fabricating one (about 2.5 x 5 inches / 64 mm x 127mm and rolled about 45 degrees of arc)
Have a Safe and enjoyable day as we all count our Thanksgiving here.
John Cox
On Thu, Nov 22, 2012 at 11:45 AM, Mike Whisky <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)> wrote:
[quote]--> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Michael
RV-10 builder (interior & finishing)
#511
http://forums.matronics.com/viewtopic.php?p=388614#388614
http://forums.matronics.com//files/doorstruts_4_147.jpg
http://forums.matronics.com//files/doorstruts_3_213.jpg
http://forums.matronics.com//files/doorstruts_2_882.jpg
http://forums.matronics.com//files/doorstruts_1_687.jpg
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
