mitch(at)skybound.com Guest
Posted: Mon Jun 05, 2006 9:06 pm Post subject: Iso Amp Testing |
What is the easiest way to test the iso amp project on the bench? I'd
like to try it out before mounting it in the plane, and I don't have the
radios and audio sources all hooked up in the panel yet.
Thanks - Mitch
nuckollsr(at)cox.net Guest
Posted: Tue Jun 06, 2006 3:49 pm Post subject: Iso Amp Testing |
At 10:00 PM 6/5/2006 -0700, you wrote:
Thanks - Mitch
I used a bench power supply, audio signal generator, load
resistors to simulate headphone and a 'scope. The minimum-equipment
method would call for wiring your headphones to the output and
use some audio device with a headphone output (portable radio,
cd player, etc) to give you a test signal source. You should
hear each stereo channel in one headphone only, and the three
mono channels in both headphones.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
